Author Topic: Zetor Major 80 vs LS MT573  (Read 535 times)
Offline gump
« on: October 27, 2018, 03:00:29 PM »
Looking at purchasing a tractor for around the mill and woodlot. Mainly will be used as a loader for lumber behind the sawmill and loader for gravels to fix up road. Plus many other things as time and implements are acquired!
Any thoughts on these two brands. I like the comfort of the LS plus a few functions. The Zetor is an old style tractor with no DEF or electronics, which I do like for its simplicity. I do worry about the electronics because initially the tractor will be under utilized until I get to spend more time on the woodlot.
Both these are brand new and are about 70HP tractors.
Offline Bruno of NH
Re: Zetor Major 80 vs LS MT573
« Reply #1 on: October 27, 2018, 05:21:25 PM »
I like the Zetor
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline gump
« Reply #2 on: December 08, 2018, 06:30:31 PM »
NOPE! Kubota 8580. Found a good used one!! No electronics, nice tight machine with lots of power.
Yahoo.. just the next piece of the puzzle.
Offline DPatton
« Reply #3 on: December 08, 2018, 07:37:35 PM »
Looks like you did well for yourself on a tractor. Congratulations.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline thecfarm
« Reply #4 on: December 08, 2018, 09:28:31 PM »
Looks like a nice clean one!!
Hours,HP?
I found one that was 8 years old and only had 800 hours on it. :o
Offline gump
« Reply #5 on: December 09, 2018, 05:38:54 AM »
Thanks guys.
I am happy I found a good used one, which saved me a lot of money!!. This is a good tractor even though its got tons of hours on it, 5,000!! New clutch and pressure plate just installed. A few new front end parts, rear tires are loaded. Everything works well with no leaks anywhere. Loader is tight & strong. It has been -12 degrees celsius last few nights and it started right up. This 85 hp tractor should be able to do everything i need it for. Super excited as this is my first tractor. The amount of hours do concern me a little bit but you know the story.."clean oil, clean air and clean fuel" should have many more hours left. I won't be running it hard or very much either.
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #6 on: December 09, 2018, 11:50:21 AM »
You will love it.
My 2007 8540 is a dream to operate and sips fuel, starts well in cold (10 to zero Fahrenheit )
It does take a bit for the hydraulic oil to warm up and function normally at those temps but then I used aftermarket oil instead of the very pricey kubota stuff when I changed it.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
belarus and zetor tractor?
Started by SeaBass on Forestry and Logging
Last post July 06, 2008, 09:28:59 PM
by smoothED
zetor 6245 tractor
Started by 47sawdust on General Board
Last post October 24, 2017, 03:34:40 PM
by whitepine2
4 Major improvements to my LT 40
Started by plasticweld on Sawmills and Milling
Last post September 27, 2015, 12:48:18 PM
by Jim_Rogers
major upgrade
Started by a old timberjack on Forestry and Logging
Last post March 02, 2007, 04:56:12 PM
by Norm
