Author Topic: JD winch not holding  (Read 1940 times)
Offline HuZzEy
« on: October 28, 2018, 09:28:52 AM »
Hey everyone the JD winch on the tree farmer the other day I was twitchin some big poplar and I could only take 2 at a time. The winch cable kept creeping out, is there an adjustment inside I can do I donít have a manual on the winch I believe itís off a 540 John Deere thanks all
Offline Maine logger88
  • Don't force it get a bigger hammer
Re: JD winch not holding
« Reply #1 on: October 28, 2018, 04:05:26 PM »
Is the swivel fitting leaking oil on the band? Thatís fairly common on those winches I usually replace mine every couple years for preventative sake. I canít remember the adjustment itís been a long time since I put a band on my 540.
Offline HuZzEy
« Reply #2 on: October 28, 2018, 10:51:09 PM »
There no external leaks from any hoses. I havenít took any covers off yet to see
« Reply #3 on: October 28, 2018, 11:53:26 PM »
External leaks wouldnít cause the winch to slip but it doesnít take more than a small drip inside to get on the band for it to slip
Offline BargeMonkey
« Reply #4 on: October 29, 2018, 01:29:57 AM »
Which model is it ? 3305 or 3325 ? The 25 can be temperamental until they are just right. Staring at the back the right side is wet, left is dry. I keep a small rag folded up inside the cover as an oil indicator but normally it's to late, once the band gets soaked your out of luck. Slip you can adjust but you want to see what kind of shape your bands in, its probably glazed and why its slipping.
Offline Cub
« Reply #5 on: October 29, 2018, 08:55:23 PM »
The farm I worked on had a 440A. One year the winch wouldnít hold. We found some oil on the 1 side. We took it all apart. The band and fiber discs were full of oil. We brakecleaned the heck out of tge discs and band. Found a small crack in the housing. Put some jb weld on the crack and reassembled it adjusted it and it never missed a beat. Far as I know the jb weld is still holding. Thatís was 17-18 years ago. Although we only pulled maybe 300 cord a year. But all big stuff.
Offline BargeMonkey
« Reply #6 on: October 31, 2018, 05:24:14 PM »
I've tried everything possible and the band is never right. Baked them in the oven, break clean, score the lining. I'm on my 2nd reman band from Harold's in ME and the only way to go.
Offline teakwood
  • Switzerland
« Reply #7 on: November 01, 2018, 09:10:08 AM »
I second Barge's comment, when i was new to the FF i had the same problem with a wet brakeband. although several members here told me to just get a new brake band i did try everything because i'm as stubborn as a mule and finally ended up buying a new band. Lesson learned!
Offline HuZzEy
« Reply #8 on: November 02, 2018, 11:40:11 AM »
Barge I believe itís a 25 the right side has the pinion and oil. Iíll try to take the cover off on the left in a week or so thanks guys. A friend of mine has a book on his 540 but since his diagnosis with bipolar he donít talk much
« Reply #9 on: November 02, 2018, 07:17:15 PM »
 I am still on the same band that I put on in 2010 and I donít baby the machine lol! Granted I havenít used it much this year but up until I got my grapple skidder this past winter it was my main horse. The only thing Iíve done to it is keep fairly new swivel fittings on it so I donít get oil on it.
Offline BargeMonkey
« Reply #10 on: November 02, 2018, 10:47:20 PM »
 I'm willing to text the entire winch book section if someone needed it. Picture there isnt the best. 4-11/16 is the magic #.
 Harold's in ME has been great about parts, a band from Nortrax was 1080.00 last time I checked and fell over. The next time my winch acts up she is getting the 4000S transplant.
Offline leeroyjd
« Reply #11 on: November 03, 2018, 04:41:36 AM »
I cannot remember if it was the cost of a new band, or the wait time for delivery, but a logger I used to work for would put baking powder on it as a band aid. It did work for a while. This was on a 540B
Offline teakwood
  • Switzerland
« Reply #12 on: November 03, 2018, 08:01:25 AM »
If the band is soaked in oil forget baking or baby powder, this will dry the band just superficially.
I had mine redone in a Brake repair shop for 70$ and i scratched my head for how long i tried to fix the old one. But i don't know if you guys have brake shops in the U.S. Here if you can't get original brakes or they are as usual too expensive (because in CR every thing is overpriced) you go to a brake shop and they cut and fit new linings on your brake part, what ever it is. shoe, band, disk, wet or dry
Offline snowstorm
« Reply #13 on: November 03, 2018, 05:29:23 PM »
i found some old notes form years ago about the price of a deere brake band $220 from deere. how long ago do you think that was?
« Reply #14 on: November 03, 2018, 09:11:56 PM »
1985?
Offline HuZzEy
« Reply #15 on: November 06, 2018, 01:09:44 AM »
Thanks guys. Iím taking it easy on her hoping to dig into it next week
Offline Nemologger
« Reply #16 on: November 08, 2018, 08:10:30 PM »
The band slips on my 440d so about every 2 years I spray the band good with belt dressing. It will hold good for about 2 years then I have to give it another dose. Told a friend of mine about using it for his winch that had slipped ever since he had the machine, he said it holds great now. Id try that before I tore into it.
Clean and Sober
Offline tom h
« Reply #17 on: November 11, 2018, 08:16:30 PM »
I have a jd54ob skidder was having the same problem after replacing the band.I replaced the two springs Barge Monkey shows in reply no. 10 and it fixed my problem tom h
Offline NWP
    • Nicholson Wood Products LLC
« Reply #18 on: March 07, 2019, 01:09:15 PM »
How thick would new clutch disks be on a 3025 winch?
1999 Blockbuster 2222, 1994 Duratech HD8, 1997 Duratech HD10, 2011 Case SV250, 2000 Case 1845C, 1990 Peterbilt 378 w/ Hood 7000 loader, 2001 Chevrolet, 2005 Chevrolet, several trailers, and Stihl saws.
Okay, Who's holding out?
Started by Gilman on General Board
Last post October 07, 2005, 11:20:37 AM
by Gilman
How you all holding up?
Started by Drew62 on Chainsaws
Last post March 30, 2019, 11:27:25 PM
by doc henderson
HAS JEFF BEEN HOLDING OUT ON US?
Started by shopteacher on General Board
Last post June 20, 2004, 09:07:11 PM
by shopteacher
NORM! 49 and holding...
Started by Patty on General Board
Last post July 07, 2005, 04:44:33 PM
by Ernie
