Author Topic: flat tire and tire pressure for jd 440  (Read 413 times)
Offline Frozendozer
  • Frustrated wood cutter
« on: October 28, 2018, 12:29:10 PM »
got a flat on my jd 440 .  I tried putting a pump on it how ever it would pump to 45 psi and then shut off.   I thought these tires would not need this much pressure.  is perhaps the valve faulty ?   any suggestions would be nice.
Offline teakwood
  • Switzerland
Re: flat tire and tire pressure for jd 440
« Reply #1 on: October 28, 2018, 12:57:08 PM »
I use 30psi because my tires are very old. I have heard that people use 35psi in newer tires
Offline Frozendozer
« Reply #2 on: October 28, 2018, 01:01:25 PM »
perhaps the tire valve is hooped?
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #3 on: October 28, 2018, 03:49:50 PM »
I used to run 25psi because it rode a lot better but I had several flats because of it. The tire place said to run 40 but I ended up going with 35 and it seems to be working ok
Offline Grandpa
« Reply #4 on: October 29, 2018, 08:02:20 AM »
I run 25 in mine but I'm a "go light, go often" kind of guy.
Trailer tire bandwheel tire pressure ?
Started by HOGFARMER on Sawmills and Milling
Last post September 21, 2006, 08:41:06 AM
by Modat22
Flat tire on the Peterson
Started by terrifictimbersllc on Sawmills and Milling
Last post April 02, 2012, 09:19:34 PM
by Okrafarmer
Flat tire on my table saw!
Started by 47sawdust on General Board
Last post September 07, 2015, 07:13:18 PM
by submarinesailor
Skidder tire Flat?
Started by groundguy on Forestry and Logging
Last post January 02, 2010, 01:32:10 PM
by timberjack240
