Author Topic: LT 40 Super Hydralic Fault Code  (Read 564 times)
Offline New Mill
  • Member*
« on: October 28, 2018, 08:46:07 PM »
I have a LT 40 HD Super and after sawing awhile today the mill lost all control function and has shown a fault code of TL module failure.  What is this?  The computer doesn't work for auto cuts needs replaced.  Factory said they would need to replace with newer modle.
Thanks for any ideas.
Offline Water Dogs
  • Mind over Muscle
Re: LT 40 Super Hydralic Fault Code
« Reply #1 on: October 29, 2018, 11:24:53 AM »
Welcome New Mill to the forum. When we got our Lt 40 a few week back it ran like a champ for the demo. About 1hour later she started missing and went dead in the water. Loose wires from vibration wigged connectors and back on line. Later found a lead loose in fuse box not tight from factory? Not sure if this is the same on your Mill hope this helps.
                                      Water Dogs
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #2 on: October 29, 2018, 02:44:24 PM »
Hello,
   TL refers to Top Left. Mosfet module for Setworks. Low battery voltage, loose connections can cause this or replace the mosfet module. TL, BL sometimes does not refer to the exact location.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Online LeeB
« Reply #3 on: March 12, 2019, 05:43:00 PM »
Hello,
Marty
@MartyParsons
Are these mosfet modules still available?
« Reply #4 on: March 12, 2019, 09:42:59 PM »
Yes I have some in stock. They are used.
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #5 on: March 13, 2019, 09:27:31 AM »
Good old boy Marty.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Online LeeB
« Reply #6 on: March 13, 2019, 11:49:26 AM »
I need three of them if you have that many.
05 648 fault code
Started by timberjack 450 on Forestry and Logging
Last post June 04, 2014, 09:41:22 PM
by Firewoodjoe
Kohler 26hp Fault Code
Started by Saga Dan on Sawmills and Milling
Last post April 21, 2016, 04:51:14 PM
by Saga Dan
clamp on hydralic lt 40
Started by pacodog on Sawmills and Milling
Last post July 04, 2005, 09:03:37 AM
by johnjbc
Need hydralic help,fluid way too hot
Started by Skytramp on General Board
Last post December 08, 2005, 07:07:15 PM
by VA-Sawyer
