Author Topic: Old forwarder/skidder  (Read 2734 times)
Offline Wisconsintimber
Re: Old forwarder/skidder
« Reply #20 on: October 30, 2018, 12:25:15 PM »
Thanks for the replies guys.  Yeah I'm a build it, rebuild it mechanical type of guy so I think the process of making it operational again(and putting it to work) would be fun.  Just don't want to buy an endless money pit.  No way to know for sure...
Offline barbender
« Reply #21 on: October 30, 2018, 04:06:16 PM »
I almost avoid dealing with widows. You could offer her $500 less than asking price, get it and dump another $3000 (and your time) into it to get it operational. But you'll still have a reputation around town as "the widow whittler". Don't ask me how I know😂
« Reply #22 on: October 30, 2018, 04:39:37 PM »
Puffergas,  you were referring to a valve to divert the hydraulics?  I was looking for one and couldn't see anything, then I thought it could be a separate pto driven pump so I put the transfer case in neutral and trans in gear, still nothing.  I'm pretty sure it's just the one main pump and it's out of fluid. Now the question is why...
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #23 on: October 30, 2018, 06:47:43 PM »
Look on the back of the engine for a pump.  Detroits have accessory drives there.
Offline azmtnman
« Reply #24 on: October 30, 2018, 08:11:52 PM »
Just a point on forum organization.  The sawmilling section has gotten cluttered with Logging related threads.
I think you have 2 different audiences/ways of doing things between the logging and the sawmill forums.
Some of us sawmill guys are forest-to-finish and require a different point of view.
Case in point--there was a young man posted something about using an old 9N Ford for logging and the loggers answers were "get a skidder for skidding!" Sure! Let's spend $10,000 on a junky piece of heavy equipment that needs special hauling. The old 9N can be pulled on almost any trailer and be bought for $1500. It's not going to skid 10 cords a day--the logging focus. But it will get a few logs to the sawmill--the milling crowd.
2 different perspectives.
1983 LT 30, 1954 Ford NAA, 2006 Polaris 500 EFI, '03 Dodge D2500 Cummins powered 4X4 long-bed crew cab, Cummins powered '88 Chevy R30, Stihl MS250, MS311 and MS661--I cut trees for my boss who was a Jewish carpenter!
Offline mike_belben
  • Pulp Friction
« Reply #25 on: October 30, 2018, 08:49:19 PM »
Find the pump, pull the pressure hose and see if its dry.  If so pour oil in it and try again.  Obviously the reservoir needs oil but an old pump may have too much clearance to siphon when dry.  Lubing the gears will help it pull some vacuum and get flowing.
Puffergas was describing a selector valve.  It would send flow either to the chassis drive/steer or the loader. Look upstream of the loader supply hose.
Revelation 3:20
Offline Cub
« Reply #26 on: October 30, 2018, 11:24:30 PM »
Pretty sure thats the 1 that was on wausaus Craigslist? Its been there for a while. I say go for it if you can pay for it. Tinker with it and fix it as you have extra cash. Get it going and use it and fix the minor things here and there. For the price Id go for it. Yes you may end up throwing 3-4000 at it. But you can buy a used 100,000$ machine and throw 20-30 grand at that pretty fast too.
Offline Skeans1
« Reply #27 on: October 31, 2018, 05:49:26 AM »
Yes and no, a tractor is not made for skidding it gets pretty hard in the center where they bolt together let alone not having guarding. We have both 100 horse tractor with a forwarder trailer and a true forwarder theres a huge difference one is safety, lifting capacity, clearance, and guarding.
« Reply #28 on: October 31, 2018, 10:55:53 AM »
Yes good explanation, that was my reasoning for posted it in the sawmilling section.  I'm not really a logger, and not really looking for production equipment so rarely view the logging topic.  However I do see why it probably fits in here better.
« Reply #29 on: December 07, 2018, 05:53:49 PM »
So, an update on the machine I looked at... In the fist part of November I made and the owner accepted an offer, sent money down and would go to pick it up when I got a trailer lined up. The assumption/hope was that it was low on hydraulic fluid so the hydraulics should work.  A couple of weeks later I borrowed a gooseneck trailer, took some tools and hyd fluid and headed over there, the temps had dropped to in the 20s.  We got there and the starter wouldn't work so I spent a couple of hours tearing it apart and got it to work.  With some starting fluid it came to life. but if I let the clutch out it dies even in neutral.  Must have moisture in the transmission that has frozen(quite common in old tractors and equipment)  Even so, I figured that I should put some hyd fluid in it and see if things work...still nothing.  Not sure what's going on with that, the first time I was there it was above freezing so it should have worked then if moisture was the problem.  The pump is belt driven and is turning, but no noise from the pump or whining on startup, nothing when I try a hydraulic function.
So we are kind of in limbo right now with this being a bad time of year to try to deal with old frozen equipment.  The owner said it can sit till next spring, I don't really like that idea, but?  to be continued...
Offline chevytaHOE5674
« Reply #30 on: December 07, 2018, 06:53:41 PM »
Take a torpedo heater and blast it towards the trans to get everything warmed up and moving. As for the pump if it's reservoir is full then like suggested take the pressure hose off and fill the pump with and then see if it will work. Also try leaving the pressure line loose a turn or so in case it is air locked.
Skidder or forwarder ??
Started by Madman_Mark on Forestry and Logging
Last post May 11, 2004, 02:09:47 PM
by Scott
Skidder vs. forwarder
Started by Atlantic Trader on Forestry and Logging
Last post March 03, 2013, 06:06:34 PM
by craigc
Forwarder vs Skidder II
Started by jrdwyer on Forestry and Logging
Last post May 18, 2004, 02:08:27 PM
by Gary_C
moved
MOVED: Old forwarder/skidder
Started by chet on Sawmills and Milling
Last post October 29, 2018, 10:39:41 PM
by chet
