Author Topic: LT70 Super Sewing Mochine  (Read 2495 times)
Offline moodnacreek
  • Sawin by the notches
Re: LT70 Super Sewing Mochine
« Reply #20 on: November 01, 2018, 07:44:58 AM »
Is there room for a taper lock pulley?
Offline Percy
  • Resident trouble maker
« Reply #21 on: November 01, 2018, 09:30:56 AM »
I assume you are speaking of the in/out motor and not the business unit. I had lots of problems with the in/out mechanism on my 2003. About 5 years ago I switched over to an air cylinder and a screen door closer for in/out./ It has worked very well for me. It has been refined since this vid(was still developing/refining). I use the stationary house air compressor(big unit) and an airline through the cat track that now supplies air pressure though a regulator to my air bladder for blade tensioning.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #22 on: November 01, 2018, 09:44:31 AM »
Now I'm ruined.  I get to go use my very nice LT35 at about half that speed!   :D  That's some nice sawmill!
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline longtime lurker
« Reply #23 on: November 01, 2018, 06:18:03 PM »
So Im looking at the dust extractor, and the greenchain on the outfeed side, and a few other changes I see you've made since the last "how it fits together show" and I got to say it's starting to look like a sawmill mate. Thats a pretty impressive demonstration of the real world capacity of that mill, and you've got some flow happening: theres a whole lot of capacity increase happens just with that flow increase and I imagine you're getting a whole lot more work for a whole lot less effort because of it. Congratulations!
Whats next? 72" McDonough double sided band headrig? Gangsaw? Quad with chipper reducers? The mind boggles at what you'll be able to achieve by the time you get to 200. :D
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #24 on: November 01, 2018, 07:36:22 PM »
lmao thanks LL!
Next is a Hurdle mill with 3 blade vertical edger.  Already put deposit down on one.  1995 mill.  Just waiting for the loan stuff to clear.
Boy, back in my day..
« Reply #25 on: November 02, 2018, 02:18:17 AM »
I've seen tubevids of the hurdle in action: they're a producer if you got the right logs to feed it. Of course you'll end up right back where you were before in terms of needing a whole whack of expanded support gear to make it run at capacity but.... thats what we do right? Everything the hard way until we bed it down then off on the next expansion :D
I had a guy was a bit of a mentor to me in another industry years ago. His advice was "bite off more then you can chew then chew like hell before it chokes you". He never mentioned the indigestion that comes with it at times, but nothing ventured nothing gained and all that. I'm just about back on my feet after that hiding at the start of the year, and when any sane person would be consolidating just to take a breather I'm bidding blocks of timberland that I've got no idea how I'd process the volumes, but guaranteed supply is the best kind of problem IMHO.
I've said it before : this industry isn't a career or a job - its a disease!
Offline Southside logger
« Reply #26 on: November 02, 2018, 07:25:40 AM »
4x4 Was that the mill you told me about?
Offline moodnacreek
« Reply #27 on: November 02, 2018, 08:05:07 AM »
lmao thanks LL!
Wow, that's not a toy.
Offline Percy
« Reply #28 on: November 02, 2018, 09:21:27 AM »
lmao thanks LL!
OH MY!!!! This is just the cheapo 2 blade version....
Online YellowHammer
  • Work = Force X Distance
    • Hobby Hardwood Alabama
« Reply #29 on: November 02, 2018, 11:18:48 AM »
Now that will be a real sewing machine!
HobbyHardwoodAlabama.com
Offline moodnacreek
« Reply #30 on: November 02, 2018, 12:16:01 PM »
Hope you can get it set up about 8' off the ground as this solves many problems.
Offline Busysawyer
« Reply #31 on: November 02, 2018, 09:40:55 PM »
You gonna get a debarker and metal detector? What happens if you hit metal with one them blades?
Even a blind squirrel finds a nut every once in awhile
« Reply #32 on: November 02, 2018, 10:11:28 PM »
Elevated construction sure makes life easy but the setup $ hurts. Pays in the long term though.
I've been tossing my "one day" greenmill setup around in my head for years, which involves a series of benches cut into the side of a hill. Log yard at the top, head saw on the first bench, resaw on the next one down, then drop a level to docker or edger or whatever, final level being stacking area and an open yard behind it for storage. Gravity assisted chains going down the hill from station to station etc etc Bays probably 25' wide which makes for cheap shed construction, floor bench levels say 5' elevation difference... but you could recess back into the next bench up for sawdust extraction including walk beside access to the scraper chains or to get at the bottom wheel of a big vertical band etc.
I saw the original idea in a US Forest Service or similar article from the 50's or so about mill layouts and I never have been able to find that article again.... but I remembered thinking how sensible it was to make use of gravity to flow your material, and being able to get at the underside of gear without either a pit that wants to fill with water when it rains or the one time cost of elevated construction. The big problem with elevated construction aside from cost being of course that you kinda gotta start with a plan and its pretty hard to vary from it once you've installed the first piece of gear.
I think for all of us it'd be nice just once to be able to set up right at the start wouldnt it?  I can afford the dream, anyway.
Offline 4x4American
    • Website Link
« Reply #33 on: November 03, 2018, 07:43:04 AM »
Gonna try to get my neighbors debarker..mainly for exporting logs though but will also use it for tie logs or really dirty logs.  If you hit metal you just change the couple bits that got nicked and keep going.  Can swadge them later on to reuse.
Offline 4x4American
    • Website Link
« Reply #34 on: November 03, 2018, 07:44:50 AM »
Most likely..I been thinking about getting one for a couple years.  I tried to convice the pallet guy to buy one a few years back and have me run it but he said heís in the biz of making pallets not sawing lumber.  He has a scragg mill though
Offline 4x4American
    • Website Link
« Reply #35 on: November 03, 2018, 07:46:34 AM »
Room for it where and for what?  There is an unused pulley on the arbor
Offline moodnacreek
« Reply #36 on: November 03, 2018, 09:00:12 AM »
Though you said a pulley was roll pinned on a shaft and failed.      Will this be the first hurdle in n.y.s.?
Offline moodnacreek
« Reply #37 on: November 03, 2018, 09:14:39 AM »
 4x4, the last time I watched an automatic carriage/ vertical edger run they dropped everything on a belt that ended into the mouth of a chipper. Two men pulled the lumber off this belt and never touched the slabs or sticks. More than once I have passed up buying a v. edger because I often saw alone so I accumulate flitch boards and edge latter. Sawing with a v. edger slows the sawyer down some but is much more productive.
Offline JB Griffin
« Reply #38 on: November 03, 2018, 10:01:44 AM »
Hurdle makes tie mills, they have one purpose rip a 7x9 out of the log as fast as possible,  and ties have a tolerance of +/- 1/4". Maybe a good reason you don't see any in the land of high dollar hardwood.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline 4x4American
    • Website Link
« Reply #39 on: November 03, 2018, 10:14:23 PM »
I would agree, JB, that a 40í 2HB Hurdle is mainly a tie mill, yes.  They also make 48í 3HB and 60í 4HB mills that are designed for more than just ties, like pallet cants, crane mats, grade, primary breakdown feeding a resaw/gang, dimension lumber, etc.  Having a 3
blade edger, I could pump out toober fours like a bat outta hell.  They even offer a top saw and lo-pro vertical edger from the factory.  Simple setup, simple transportation.  Best modular mill Iíve know of.  If you see one in person youíll see itís beefy, like that one in your neck of the woods I almost bought.
Woodmizer Super LT70
Started by John S on Sawmills and Milling
Last post December 24, 2014, 09:59:16 AM
by Dave Shepard
What are the advantages: WM LT40 Super vs. LT70?
Started by Curly_Woods on Sawmills and Milling
Last post March 17, 2006, 08:22:57 PM
by Percy
LT70 Super Dust collection
Started by mjl_2007 on Sawmills and Milling
Last post October 24, 2016, 10:03:04 AM
by Carson-saws
Wood Mizer LT70 Super Wide (Vidjayo on da way)
Started by 4x4American on Sawmills and Milling
Last post June 20, 2018, 08:26:24 PM
by 4x4American
