Author Topic: LT70 Super Sewing Mochine  (Read 2543 times)
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: LT70 Super Sewing Mochine
« Reply #40 on: November 03, 2018, 10:22:13 PM »
moodna crick I like that idear..except for 2 things..if they miss a good piece, kiss it goodbye.  Maybe one of the pullers needs to take a leak and the sawyer dont notice.  It wont accumulate on a green chain, itll just be chipper food.  I like the idea of having a slab dump at the end trimmer.  That way the end trimmings and the slabs find their way to the chipper in one spot, and the trimmer main gives you more bang for your buck, and gives sawyer one less thing to keep track of.  I know of multiple guys who saw solo with a vertical edger, and they love it.  Its two steps instead of three, saw cab, green chain, saw cab, green chain...cut lumber in one shot from the saw cab. niice
Boy, back in my day..
Offline JB Griffin
« Reply #41 on: November 04, 2018, 10:42:33 AM »
4x4, none of the products you mentioned demand much in the of accuracy.  For example,  pallet cants down here +/- 1/4" unless they get picky on us, crane mat timbers +/- 1/2" and don't even have to be all that square, grade +/- 1/8" unless its a special order, primary breakdown just take the bark off and make it squareish, dimension lumber all gets run thru a 4 head moulder anyway.
As you can see WAY different specs in the south where those mills are made.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline JB Griffin
« Reply #42 on: November 04, 2018, 11:00:00 AM »
When we get an order for bridge timbers we saw them on the the Dominator cause the meadows can't hold the +/-0 tolerance they want.
Offline moodnacreek
  • Sawin by the notches
« Reply #43 on: November 04, 2018, 03:58:20 PM »
4x4; the sawyer would have a push button or foot pedal to stop/start the belt. [I have a overhead lever] I could never figure out a way to handle v. edger output on my set up.    Am very interested in your project.                        P.S. The old timers always called it the 'crick'.
Offline longtime lurker
« Reply #44 on: November 04, 2018, 05:07:22 PM »
Do they have a linebar? You can do a lot to improve dimensional tolerance if you have a linebar: SOP here with this springy eucalypt stuff is to vary the pressure on your carriage knees against the linebar to compensate for log spring, which gets rid of a lot of the thick and thin issues that cause dimensional variations.
https://www.fwpa.com.au/images/processing/PNB291-1112A_processing_methods_for_SW_products_euc_plantations.pdf
diagram on page 15.
Offline 4x4American
    • Website Link
« Reply #45 on: November 04, 2018, 05:59:41 PM »
Yea Im not really worried about it for what Im doing..what I mainly cut is cants grade and ties.  None of which have to be perfect.  The pallet shop I sell to now sends the important size cants through a sizer first anyways.
Woodmizer Super LT70
Started by John S on Sawmills and Milling
Last post December 24, 2014, 09:59:16 AM
by Dave Shepard
What are the advantages: WM LT40 Super vs. LT70?
Started by Curly_Woods on Sawmills and Milling
Last post March 17, 2006, 08:22:57 PM
by Percy
LT70 Super Dust collection
Started by mjl_2007 on Sawmills and Milling
Last post October 24, 2016, 10:03:04 AM
by Carson-saws
Timber King 2500 vs WM LT70 Super Wide
Started by footer on Sawmills and Milling
Last post April 21, 2017, 08:57:09 AM
by chardin
