Author Topic: stihl 661  (Read 1121 times)
Offline Cub
stihl 661
« on: October 30, 2018, 11:51:07 PM »
What are your options about them? You guys have good luck with them? Any and all opinions welcomed.
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
Re: stihl 661
« Reply #1 on: October 31, 2018, 08:48:05 AM »
I have the MS661-C M-tronic. I like it a lot!
It replaced my old 066 and has more power and weighs less.
I use it with and Alaskan mill to mill wide slabs the biggest so far was a 42"wide red oak.
If I want to go wider Ill need to get a longer bar.
I'm for it.
Jon
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline Cub
Re: stihl 661
« Reply #2 on: November 03, 2018, 08:19:17 AM »
Ok thanks. My 064 keeps giving me fits and Im about ready to leave it in the garage as a conversation piece and replace it with a 661.
Offline HolmenTree
Re: stihl 661
« Reply #3 on: November 03, 2018, 11:18:05 AM »
Rebuild that 064 with OEM parts and keep it for backup.
MS661 I've demoed and love it but waiting for the 80cc MS500i
Offline Cub
Re: stihl 661
« Reply #4 on: November 03, 2018, 12:57:46 PM »
So your saying I should just get a 661? Hahaha!!!
Offline HolmenTree
Re: stihl 661
« Reply #5 on: November 03, 2018, 08:34:32 PM »
Well if you're man enough cub, go for it. :laugh:
Offline Cub
Re: stihl 661
« Reply #6 on: November 03, 2018, 09:17:00 PM »
I think I can handle it :D. I only use it to drop trees. The job Im on now is big ash maple and basswood. The 440 doesnt quite have the beans to pull a 28 inch bar through a 46 inch maple. (I mean it does work and I could by). So Id use the 064 to drop and buck the 1st few logs then use the 440 for the rest. I like a powerful saw with speed when it comes to dropping them big guys.
Offline D2 Cody
Re: stihl 661
« Reply #7 on: November 04, 2018, 10:59:57 PM »
I have been wondering about the 661 also. I would like to buy one so i can put a 36 inch bar on it to bore bigger cottonwood and walnut. I would also like opinions and more detail from a few others. I thought about going with the 461 but for 200 some more dollars i can get the 661. Any thoughts or opinions?
Are you just going to lay there and bleed or get up and do something about it..Wyatt Earp Tombstone
Echo-Stihl-Caterpillar-Dodge-Craftsman-Lincoln
Offline YellowHammer
  • Work = Force X Distance
    • Hobby Hardwood Alabama
Re: stihl 661
« Reply #8 on: November 04, 2018, 11:26:36 PM »
Its a good saw and the one I reach for most times.  A 28 bar balances it perfectly, and allows me to walk with the tip horizontally by the carrying handle, with no unsafe tip down and I can bury the blade in a log and not care.  Plunge cuts, bore cuts, buck cuts, whatever, its fast and will just drop through a log.  Noticeably more power and zip than my old 660 which I traded for this one.  Not even close to my old 440 Magnum.  I also use a 32 on it for cutting wedding cookies.
We also use it to split and buck the occasional big logs with a 52 bar and skip tooth chain.   I should get an 880 but this works fine.
HobbyHardwoodAlabama.com
Offline leonid123
Re: stihl 661
« Reply #9 on: January 03, 2019, 09:51:33 AM »
I bought 661 this summer, and I can say that it is valid beast. For thick trees just right. Good luck will not regret.
Offline hedgerow
Re: stihl 661
« Reply #10 on: January 03, 2019, 05:37:42 PM »
How many hours do you have on it? I think I have decided I am going to start shopping for a 661 in 2019. I sold my Solo 694 because of no compression release and my shoulder is not good. Kind of ruled out a husky as there seems to be no dealer support in my area.
Does Stihl have a different mount size at the studs for bigger and smaller Stihl
Started by quietrangr on Chainsaws
Last post October 09, 2011, 08:25:11 AM
by Al_Smith
Mounting Cannon S2 (big Stihl) 42" bar on MS661 (small Stihl)
Started by neildorin on Chainsaws
Last post September 11, 2017, 06:01:44 AM
by Al_Smith
Trading in a Stihl saw to a Stihl dealer?
Started by gus1957 on Chainsaws
Last post January 01, 2008, 11:42:12 PM
by sawguy21
There are Stihl dealers then there are Stihl sellers.
Started by Ward Barnes on Chainsaws
Last post January 31, 2012, 11:16:22 AM
by tcrew
