Author Topic: Installing a New CB Edge 750 HD this weekend!  (Read 1773 times)
Offline DDW_OR
Re: Installing a New CB Edge 750 HD this weekend!
« Reply #20 on: December 30, 2018, 07:01:54 PM »
I got the Flir C2
I used Paint to increase photo size by 300%
top left = temp in center circle
Right side = Max and Min temp
will re-take the photos tonight
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline DDW_OR
« Reply #21 on: December 30, 2018, 08:34:39 PM »
same locations after sunset
photos have not been modified
Offline boilerman101
« Reply #22 on: January 03, 2019, 09:28:57 PM »
I wonder it those photos are good or bad? Looks like hottest areas around the various door panel accesses which I would expect. I wonder what other heating objects look like? Or what an outdoor furnace insulated with fiberglass batts would look like?
Offline DDW_OR
« Reply #23 on: January 04, 2019, 12:56:53 PM »
more insulation = less heat loss
here is my laptop
my chihuahua
OWB heat exchanger
and the regular photo of the heat exchanger
Offline panolo
« Reply #24 on: January 04, 2019, 02:23:40 PM »
Cool camera pics!
I have a 1st gen 550. I clean ash every two weeks and do a deep clean at the end of the season. Check my primary elbow every month. I run a 20 degree difference (172-192) as it seems to help with creosote.
« Reply #25 on: January 19, 2019, 07:27:29 PM »
My Edge has now been running for 11 weeks and I'm totally impressed with how easy it is to run and more forgiving on coalbed depth. As long as I keep the coals below the firebox side and front air holes and push the rod through the coals once a day, that is about all I have to do. About every 3 weeks I remove 3-4 small square faced shovels of powder ash out of reaction chamber through the front and rear access. Nothing but a little light powdery ash on the rear exhangers. That hinged rear access door sure eliminates the rear exchanger cleaning issue knock that most gassers have had over the years. Still no creosote buildup on the side or front air channels inside as it seems to just burn off. As previously stated, the stainless seems to operate much drier. My intent is still to not pull off the primary elbow or channel covers until spring shut down unless performance says I need to. Continuing to get 1,000+ reaction chamber temps every burn cycle. Even with colder temps it does not seem to be burning any more wood than previous. At current usage I should have wood from my estimated 2018 allotment carrying over for next season. I could not live without the XP wifi after having it on my smart phone showing me current temps and history charts. It becomes addicting and almost like a game trying for new high reaction chamber temps and performance charts! Will keep you posted as we go through the 2nd half of the heating season.
Installing a 750 Edge HD Titanium
Started by 747mopar on Firewood and Wood Heating
Last post March 31, 2018, 04:24:32 PM
by 747mopar
To edge or not to edge is that a question?
Started by glgdiggs on Sawmills and Milling
Last post July 16, 2009, 10:16:58 PM
by Percy
Installing The New OWB
Started by levans on Firewood and Wood Heating
Last post October 28, 2012, 01:38:52 PM
by levans
installing log siding
Started by sbishop on Timber Framing/Log construction
Last post June 09, 2010, 04:40:51 PM
by ARKANSAWYER
