Baltic Abrasives Technologies
Author Topic: Chomper firewood processor  (Read 1481 times)
Offline Mike J
« on: November 01, 2018, 07:58:15 AM »
First I would like to say thanks for adding me! Now hopefully someone can help steer me in the right direction. I知 looking at a Chomper 14 for sale locally, the guy selling it says that the auto option works sometimes but not always. I知 curious if anybody here knows what might be wrong? Chomper is out of business so calling them isn稚 an option. The seller says he thinks it is a sensor. Are these sensors available? Where would I get one? How much are they? Thanks in advance for any response. Mike
Offline hedgerow
Re: Chomper firewood processor
« Reply #1 on: November 01, 2018, 09:00:25 AM »
Welcome Mike J
I haven't owned a Chomper firewood processor I looked at a couple a few years ago and decided I didn't have enough of the right size logs for it to work for me. If you buy one you are going to have to be a guy that can make or fix anything or as you found out the company is out of business. What I read about them when I was looking was it was a love or hate thing with them. Seems like there are a few this year for sale. Just remember in firewood processors you are not seeing a lot of shear style processors.
Offline Mike J
« Reply #2 on: November 01, 2018, 09:26:24 AM »
Thank you Hedgerow, luckily i have access to plenty of smaller wood, I am just curious what kind of sensors they used and if they are readily available. If that is what is wrong with the machine. Thanks, Mike
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #3 on: November 01, 2018, 10:01:49 AM »
Welcome!
I guarantee you the sensor is a commercial off the shelf product.  They just didn't make millions of these to justify a specially built sensor.
Now whether it is a mechanical microswitch, optical, magnetic, pressure....  No clue.
Figure out what it is, then google the numbers that are probably stamped or etched on it.  Could just be dirty and need cleaned even.
And I don't mean this to be rude, but long term to help your wallet: If you have concerns over retrofitting a sensor, your money may be better spent on something with factory support.  We're happy to help, but an online forum can only do so much.  (Please disregard if you are comfortable with mechanical and hydraulic repairs but electrical leaves you scratching your head.)   ;)
Offline Mike J
« Reply #4 on: November 01, 2018, 10:22:38 AM »
TKehl, I understand what you are saying, I知 pretty mechanically inclined, I just wouldn稚 want to buy something and find out it would be a special order switch/sensor. I like the idea of a one man operation machine. Thanks, Mike
Online mike_belben
  • Pulp Friction
« Reply #5 on: November 01, 2018, 10:38:28 AM »
First off.. Sellers of broken machines dont usually have a clue whats wrong with it or theyd be selling a fully functioning machine for top dollar. Its always just a little carb cleaner or tuneup or needs fresh gas with sellers of broken junk.
Its probably got a cabinet with a basic PLC of some sort to run the cycle. PLC is a little programmable controller that looks at input parameters to generate outputs.  Then any number of switches or prox sensors are laid out for the input side and the PLC uses these inputs to run a sequence of outputs.   Thats it.. A little box of I/O's programmed to do whatever you punch in from a laptop based software package.
Theres probably a hundred ways this automation can be interrupted.  And theyre all small/simple if you know automation.  black magic if you dont.  If the machine runs completely in manual, thats a pretty good sign it can be fixed cheaply by someone who knows what theyre doing.  Proxes and limit switches are pretty universal and cheap.  Its more about knowing what youre doing than spendy parts.  The builders probably bought as affordable a set of components as they could.
Digi-key, ebay, grainger, automationdirect.com etc
Revelation 3:20
Offline Mike J
« Reply #6 on: November 01, 2018, 10:46:40 AM »
Mike belben, the owner says everything works manually and it works auto till a certain function. I guess when I look at it I値l bring some 10-12 sticks with me and see what happens. I apparently your response. Sounds like from feedback I知 getting it should be a replaceable part. Thanks, Mike
Online mike_belben
  • Pulp Friction
« Reply #7 on: November 01, 2018, 03:47:13 PM »
If part of the auto works the PLC should be fine which is a big bonus.  So it probably lost an input or connection to an output circuit.. You should be able to manually supply that input or output with a jumper to verify.  When you get into the cabinet youll see more what i mean.  Watch the owner run it with the cabinet open.  PLCs usually have blinky lights to show what theyre "seeing" and "doing."   If so, take a video.  Youtube users could probably walk you through a repair via comments.
Look around for build schematic inside the cabinet.  Usually stuffed inside.
Revelation 3:20
Offline Mike J
« Reply #8 on: November 01, 2018, 08:27:16 PM »
Thanks Mike, I am going to look at it on Saturday. I値l keep this in mind. Thanks, Mike
Online mike_belben
  • Pulp Friction
« Reply #9 on: November 02, 2018, 12:01:59 AM »
Youre welcome, mike.   :)
Revelation 3:20
Offline barbender
« Reply #10 on: November 02, 2018, 12:12:07 AM »
You should have wrote that "You're welcome, Mike- Mike" 😁
Offline hedgerow
« Reply #11 on: November 04, 2018, 09:43:29 PM »
Mike J
Did you buy a firewood processor Sat?
Offline Mike J
« Reply #12 on: December 02, 2018, 09:09:40 AM »
Sorry I haven稚 gotten back to you, but no I passed on the processor. Thanks, Mike
Offline hedgerow
« Reply #13 on: December 03, 2018, 03:07:43 PM »
So Mike J what didn't you like about the Chomper? Still looking for a processor?
Offline Mike J
« Reply #14 on: December 03, 2018, 04:22:20 PM »
Hedgerow, To be honest my financial situation changed, I never got to look at it, if it痴 still available in a few weeks I will try to go see it.
Offline Puffergas
    • Puffergas
« Reply #15 on: December 03, 2018, 07:15:46 PM »
I have the manual version. Bought it well broke-in, so to speak. Too slow for a commercial operation but a sheared chunk of wood dries faster. It would be nice if the blade is not cracked, common problem. It will be a vertical crack in the middle. You can buy a spray can of visible penetrant and remover to test for cracks.
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, IHC 300 Utility, Timberjack 225D, Burg Bandsaw mill, Steiger Bearcat II
Offline Mike J
« Reply #16 on: December 03, 2018, 07:48:20 PM »
That sounds like a good way to find a crack!! Thanks
Chomper firewood processor - What happened to Rainier Hydraulics?
Started by SteveR.3621 on Firewood and Wood Heating
Last post May 13, 2017, 04:35:50 PM
by sawdust
Processor Build, Home Made Firewood Processor
Started by Higgo on Firewood and Wood Heating
Last post September 17, 2018, 08:52:41 PM
by hedgerow
firewood processor
Started by sjfarkas on Forestry and Logging
Last post September 16, 2009, 12:10:26 AM
by Randy88
firewood processor
Started by J-Bar on Forestry and Logging
Last post February 15, 2009, 09:23:11 AM
by TeaW
