Author Topic: Timber Harvester info needed  (Read 547 times)
Offline 1woodsman
« on: November 01, 2018, 01:31:49 PM »
Hello, I have a Timber Harvester Sawmill I have been working on for a couple years and am very anxious to get it up and running. I am new to sawing I had purchased the sawmill at an auction and it was in rough shape my problems are it did not come with log clamps so I need to make them, I believe it had hydraulic motor clamps so I am trying to find some specs- hydraulic motor type, type of steel used to make them. If anyone knows of someone that has a timber harvester sawmill I can get some pics or specs or I can even take a trip to look at the sawmill. I am in Western NY. Also the sawmill did not come with the part that raises either end of the log for leveling it (Not sure what it's called) I will have to make those also. Any advise on these issues or pointing me in the right direction will be very much appreciated. Thanks
Offline dutchman
  • Sawyer SW PA TimberHarvester 30HT
Re: Timber Harvester info needed
« Reply #1 on: November 01, 2018, 04:15:26 PM »
I own a 1995 timberharvester 30HT. Would send photos when I get
back to milling.
Iím in sw Pa.
Right now Iím hunting most of the time.
Offline 1woodsman
« Reply #2 on: November 04, 2018, 03:55:55 PM »
That would be great Dutchman, Thank you and good luck hunting.
Offline Brad_S.
« Reply #3 on: November 04, 2018, 04:52:47 PM »
 I am in Victor New York. You are welcome to come out and look at/measure/photograph mine.
Offline 1woodsman
« Reply #4 on: November 06, 2018, 11:54:33 PM »
Brad, Thank you so much. You are only an hour and a half away from me. I can come out asap just let me know when. I have been stressing for some time to get this mill done and start cutting wood. I really appreciate your help.
Offline york
« Reply #5 on: November 07, 2018, 06:51:19 AM »
Too bad you can`t find an old TH that is being parted out...The way TH built the dogging is complex and costly..
Much needed help/info needed-230TJ
Started by riverlogger on Forestry and Logging
Last post February 14, 2014, 07:24:58 PM
by riverlogger
harvester heads options and inpute needed
Started by mark686 on Forestry and Logging
Last post February 19, 2017, 08:21:17 PM
by wannaergo
LT 300 WM info needed
Started by Quebecnewf on Sawmills and Milling
Last post March 27, 2005, 08:05:22 PM
by D._Frederick
timber harvester
Started by mac37 on Sawmills and Milling
Last post April 27, 2018, 02:59:57 PM
by mac37
