Author Topic: Best blade for sawing cypress  (Read 366 times)
Offline Cypress Man
« on: November 01, 2018, 07:21:55 PM »
I run a LT70 DCS sawmill with a 25hp electric motor and only cut cypress.  I've been using the 1.5x.055x10degree 1 1/8 tooth spacing blades for years now.  I recently tried a 1.5x055x7degree 7/8 tooth spacing turbo blade. It performed well. Stayed flat even through big knots but has to be pushed very hard to produce any speed. Is this spec. blade made in a 9 degree that may cut faster without pushing it so hard and stay flat? What blades do you other guys use to saw cypress with?
LT70 wide head electric, IC5 Power conveyor, transfer table, Stop and Load Log Deck, Catapiller 360B Telehandler, Cat tl642c Teleloader, Cat TH514 Telehandler, Woodmizer EG400 edger, Logosol PH360 moulder, Extrema 26" Planner, Grizzly 16" dual conveyor resaw, Prentice 285 log loader
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Best blade for sawing cypress
« Reply #1 on: November 01, 2018, 08:28:39 PM »
I have no 9 blade experience but I seem to remember that they may have a sorta shallow gullet.
My Cypress sawing had always been with the 10 blade but now virtually all of my sawing is with 7 Turbos.  Matter of fact, I do not even own a 10 blade now.  It has taken a bit of learning and speed adjusting on my part.
I have about a dozen 4 blades that I saved for White/Post Oak but the last Post Oak that I sawed was with a 7 Turbo.
Offline tmbrcruiser
« Reply #2 on: November 05, 2018, 07:29:03 AM »
I have been using 7 degree turbo's also, like them for almost everything I cut.
Once you get sap in your veins, you will always have sawdust in your pockets.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: November 05, 2018, 08:24:42 AM »
(I know, not Cypress) but I sawed two Post Oak logs this past week with a 7 Turbo after sawing a large Red Oak.  It held true through some fairly large knots.  smiley_thumbsup
Online Percy
  • Resident trouble maker
« Reply #4 on: November 05, 2018, 09:38:02 AM »
I cut mainly softwoods up here in northern Canada so Im not sure what Cypress is. I have experimented with the tall tooth blades that Woodmizer sells(the turbo 7 and the 13 degree) For me, the 13 degree is the only blade I use. With your power, the 055 would be my choice. Get WM to send you one to try.....you may like it...
Sawing cypress
Started by slider on Sawmills and Milling
Last post January 19, 2014, 06:51:21 AM
by nomad
Cypress Sawing
Started by Randy on Sawmills and Milling
Last post October 23, 2005, 07:08:16 AM
by ellmoe
Best blade config for cypress?
Started by woodhick on Sawmills and Milling
Last post December 15, 2006, 06:41:50 AM
by woodhick
Cypress sawing restrictions ?
Started by VA-Sawyer on Sawmills and Milling
Last post August 30, 2004, 08:07:56 PM
by Wudman
