Author Topic: How Yukon Men and Women Get Big Logs into the River - Stan Zuray  (Read 1789 times)
Offline stanzuray
    • rapidsresearch.com
« on: November 02, 2018, 02:50:25 AM »
Many logs are gotten out of the Yukon River for lumber cutting, firewood and fish wheel rafts as they float down after getting washed out of spring time flooded rivers. Many others are washed up during the high water and stranded when the water goes down later and are jacked, winched and pried laboriously to get them back in the water. This is a video of an easier way - that is if everything goes okay.  Enjoy, Stan
Offline Ianab
Re: How Yukon Men and Women Get Big Logs into the River - Stan Zuray
« Reply #1 on: November 02, 2018, 03:54:09 AM »
Love it when a plan comes together.  ;D
Offline olcowhand
  • I'm new- ish!
« Reply #2 on: November 02, 2018, 04:44:41 AM »
Very Cool, Stan. Looks like you took some Yankee Ingenuity with you when you left Boston.
(Spoiler Alert): Your timing regarding the comment about occasional rope breakage was perfect and aligned with my thought process as I was watching (mentally, I was getting ready to move to my right).
They say the mind is the first to go; I'm glad it's something I don't use!
Ezekiel 36:26-27
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: November 02, 2018, 07:31:41 AM »
Does the abrasiveness of the heavy silt cause any extraordinary wear on the engine's water pump, etc?
Offline stanzuray
« Reply #4 on: November 02, 2018, 02:08:48 PM »
I get about 150 hours out of a water pump liner from running in the Yukon but in the Tanana River (comes into Yukon by the village) which is maybe 2-3x siltier it's worse. A guy I know lives and runs all the time on this smaller VERY silty river and he wears down aluminum props very noticeably. Other than that it's not a problem and we drink the water in a pinch and in winter it clears and is the preferred drinking water in the village.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #5 on: November 02, 2018, 05:51:33 PM »
Stan,
   I saw people fishing in and knew they drank that run-off from the glaciers but I admit it would be hard for me to get used to since it looks exactly like the gray water off so many projects I have worked on around the world. I still don't see how a fish would ever see a lure in it. Thanks for posting. I love to watch you guys build then use then dismantle for other purposes those log rafts.
Offline Autocar
« Reply #6 on: November 02, 2018, 07:07:45 PM »
Pretty cool way to log  :D with my luck I would take off with my boat and when the line got tight it would rip the back of the boat out and I would watch my motor go to the bottom of the Yukon which  I would follow pretty quick  ;D Keep up the good work and be safe !
Online Jeff
  • Fearless Leader
  • I intend to live forever ... So far, so good.
    • THEE Forestry Forum
« Reply #7 on: November 03, 2018, 09:31:28 AM »
Stan, did you pick up some video editing tips from the production guys from the show? Your video's are very well done and a pleasure to watch. I love that the "music' is simply the natural sounds surrounding you.
Offline sawguy21
« Reply #8 on: November 03, 2018, 12:08:55 PM »
That was my first thought. :D It had to be hard on the boat and your neck. My hat is off to you and others that live and work in the north, you need to be resourceful to survive.
Offline stanzuray
« Reply #9 on: November 03, 2018, 04:05:16 PM »
I should say that although the stress seems pretty mild when the rope tightens and the boat comes to a stop or not (if it goes in water in one try) you really need a long rope to do it without that sharp, fast yank that could damage things and I would not do it with the riveted on handles that are on riveted boats. The Alweld boats we use have heavy welded on handles on the rear corners. Stan
Offline stanzuray
« Reply #10 on: November 03, 2018, 04:47:47 PM »
Yes it was very interesting to be around them and see the cameras they used etc. I used to try to film things though even long ago with the old 8mm tapes and cameras that had no stabilization. Little by little I'm learning how to use the editing software. I visited the editing rooms back in New York and saw the big time editing of the TV show. One of the biggest things is keeping the cameras steady and not moving around a lot from scene to scene. Or edit that part out.
Offline nativewolf
« Reply #11 on: November 03, 2018, 04:53:08 PM »
Much enjoyed, both fishing and logging videos.  So what will you do with this stick?  Is it all for firewood or do you save some of the longer poles like this for construction or for sawing?  Anyone in the village have a bandsaw mill?
Liking Walnut
Offline Don P
    • Calculator Index
« Reply #12 on: November 03, 2018, 10:56:10 PM »
That looks like fun 8)
I don't know if it would work but I've rolled some sideways that I couldn't just drag like this, wrap as much as it takes to get to your destination plus a wrap or three. This was 60' x about 3'
Offline stanzuray
« Reply #13 on: November 04, 2018, 02:17:57 AM »
That's a huge tree and about as big as we ever see around here. Pretty ingenious - basically winching the log where you want it to go. Where there is a will and no perfect tool there is a way. Stan
Offline Hilltop366
« Reply #14 on: November 04, 2018, 08:22:13 AM »
For some reason this video instantly reminded me of the old Canadian TV show The Beachcombers.
Online Jeff
  • Fearless Leader
« Reply #15 on: November 04, 2018, 09:16:29 AM »
After watching I see why!
Offline Mooseherder
« Reply #16 on: November 04, 2018, 10:13:32 AM »
I had forgotten about that show.  Growing up on the Canadian border we got to tune that in. Canadian channels were half on what came in on the antenna. Back in the day when you had to get up to change the channel.  Sadly, with digital they don't work anymore. I miss Canadian programming.
Lane Circle Mill
Offline D2 Cody
« Reply #17 on: November 04, 2018, 10:48:59 PM »
Hi Stan,
Welcome to the forum. That is a pretty sweet video, it always interests me to see different logging methods from around the country. Next time I start to complain about how hard i have it  skidding a turn i the cold snow and mud I will think back to your video and that will shut me up quick lol. I remember watching on the show guys going with snow machines and sleds gathering firewood and saw logs, it was crazy. Keep up the good videos and pics so a guy like me who always wanted to go to Alaska can at least watch it on here. Be safe and take care.
Are you just going to lay there and bleed or get up and do something about it..Wyatt Earp Tombstone
Echo-Stihl-Caterpillar-Dodge-Craftsman-Lincoln
Offline thecfarm
« Reply #18 on: November 05, 2018, 05:51:50 AM »
A nice thread to see how others haul wood.
Offline timberking
« Reply #19 on: November 05, 2018, 08:26:01 AM »
Welcome Stan, like the boat.  You run your boats like we do our trucks.
Yukon men, Stan Zurray CS milling vid
Started by Roland on Sawmills and Milling
Last post November 04, 2018, 08:34:24 AM
by Lko67
River Logs
Started by Rockn H on General Board
Last post March 04, 2005, 07:56:12 PM
by Fla._Deadheader
getting logs across a river
Started by madmari on Forestry and Logging
Last post January 15, 2016, 03:53:12 PM
by madmari
sawing and drying river recovered logs
Started by johngrlc on Drying and Processing
Last post September 23, 2012, 12:51:17 PM
by Den Socling
