Author Topic: Need help with Allis Chalmers 514 forklift  (Read 456 times)
Offline Trapper John
  • Location: Galena, Ak. 200 miles west of Fairbanks on Yukon River
  • Trying to learn circle milling
« on: November 04, 2018, 12:48:15 AM »
Thinking of buying an Allis 514 forklift but there some issues that worry me.  It has been sitting for a long time but I did get it running.  Its a 4 speed but I cannot get it in the upper right position (grinds gears) and it wont stay in the lower left position.  Runs OK in upper left and lower right positions.  Maybe old fluids?  Its missing the dipstick under the operators right leg so I don't know the level in that section.  The dipstick further back on the left side near the hydraulic pump shows adequate  fluid but after running the lift the dipstick shows whitish and foamy fluid.  I have no manuals and I don't know much about the machine.  The hydraulic pump seems to make a lot of noise, can you still get parts for something this old?  I have found manuals on line for an Allis 510 forklift but not for the 514.  Are they the same machine?  Also what is a good way to clean the gas tank?  So much gunk in  tank its plugging up the outlet.   Any help or advice greatly appreciated.
Offline Den-Den
    • Dennis Wood Art
Re: Need help with Allis Chalmers 514 forklift
« Reply #1 on: November 04, 2018, 08:54:08 AM »
I don't know any specifics about the machine.
It sounds like the transmission has some water in it.  There is a good chance that rust is causing the shifting problems.  Don't buy this unless you are willing to open the transmission and plan to use it intermittently.  Would it be possible to fabricate a replacement gas tank?
Offline mike_belben
  • Pulp Friction
« Reply #2 on: November 04, 2018, 02:07:13 PM »
Your shift fork engages that slot on the sliding clutch or sliding sleeve if its synchronized.  It locks the floating gear of the gearset to the intermediate shaft while all other floating gears float.  You can only lock one gear at a time to the intermediate shaft. Thats a new clutch.
The grind is when the clutch splines and matching splines in the gear have worn down and no longer actually mesh.  Either by a bad operator or worn out synchros that are failing to bring the shaft rotational speeds together for a smooth shift.  A syncro is basically a floating brake inside a gearbox.
Straight gearboxes are much cheaper and simpler than syncrhronized ones to repair.  But either is a full trans out and teardown.  Pull the top cover off the trans before you buy and inspect the teeth for being round over like this.  Double clutching will help .. Or be downright mandatory to access those gears.
The squeeling pump is probably from the air in the system.  It doesnt tell you whether the pump is good or bad as air will make a squeeler out of both.  But frothy fluid is air going through the pump gears or vanes and imploding as it goes from negative pressure to very high.
Lowball'm on this one.
Revelation 3:20
allis chalmers acc40 forklift brakes
Started by trim4u2nv on General Board
Last post December 09, 2013, 07:33:43 PM
by trim4u2nv
Allis Chalmers 190 XT
Started by ely on For Sale
Last post February 04, 2014, 03:54:45 PM
by ely
Allis Chalmers Payloader
Started by 4x4American on General Board
Last post June 18, 2016, 12:04:20 PM
by 4x4American
allis chalmers hd5 dozer
Started by bigred1951 on Forestry and Logging
Last post December 03, 2015, 12:32:34 PM
by M_S_S
