Author Topic: Timberjack 404 questions  (Read 940 times)
Offline Flyingpig
« on: November 04, 2018, 08:17:17 AM »
Hey guys. I bought a nice straight and clean 404 yesterday. It has a locked up engine (Iím thinking blower issues, he described it as black smoke and then locked up). I happen to have a blower ha ha. Anyway, does anyone know what to use for oil in the transmission? Itís a powershift, I think they were an Allison? Also, what do they weigh roughly? Thanks.
Offline Flyingpig
Re: Timberjack 404 questions
« Reply #1 on: November 04, 2018, 07:29:33 PM »
Alright I guess Iíll add a couple pics...
Itís a really straight, tight machine. Looks like it has had a pretty easy life. Weíll bring it home and see if our hunch on the engine is right and if it is it wonít be long before itís back to work. It is complete too, all the guards and panels are there for it.
Offline bushmechanic
  • Someone else has it worse than you.
« Reply #2 on: November 05, 2018, 04:36:59 AM »
Good score on the old girl, hope that engine doesn't run you into too much money. ;)
Offline thecfarm
« Reply #3 on: November 05, 2018, 05:40:50 AM »
Hope all goes well. Thanks for the pictures.
Offline Flyingpig
« Reply #4 on: November 05, 2018, 07:51:56 AM »
If it does weíll re power it. Weíve got a 6354 Perkins that purrs like a kitten...
Offline larry12
« Reply #5 on: November 05, 2018, 08:58:51 AM »
Good looking old TJ  --sorry can't help you with the weight or  trans. oil type . My engine is locked to, but from water damage --hope yours is just something minor.
Offline Flyingpig
« Reply #6 on: November 25, 2018, 09:23:24 AM »
 The engine was a bit more serious but we are getting a handle on er. They had Ďrebuiltí the front hole with a piston that looks to be out of a 53 series turbocharged engine. It is a way lower compression dome and it has a lot of cylinder wall clearance. Number 3 cylinder was seized and the liner stuck to the piston and broke at the ports. Also itís been packed full of seeds by mice over the two years it has sat. So we are pulling two piston/liner assemblies out of a 353 we have from a 230D and putting them in and going over the rest of the engine. Itís a temporary patch fix, but once it makes us some money we will stop and do a full rebuild on it the next time it hints at trouble.
Offline Flyingpig
« Reply #7 on: December 16, 2018, 12:58:53 PM »
Well, we spent our first day pulling wood in with the old girl yesterday. We spent a few days with the winch and other problems that showed up after we got the engine running. $2,000 all in for a running, functioning skidder. Runs really nice too, has a little blowby until itís warm and then itís good. Takes a small sniff of ether to wake it up at -10. About as good as Iíve ever had a Detroit run.
Online mike_belben
  • Pulp Friction
« Reply #8 on: December 16, 2018, 01:24:07 PM »
For that kinda money one can overlook a lot of flaws.
smiley_thumbsup
Revelation 3:20
1986 350 timberjack questions
Started by cutter88 on Forestry and Logging
Last post March 19, 2016, 09:07:38 AM
by KWood255
240A timberjack winch questions
Started by gotquestions on Forestry and Logging
Last post August 25, 2011, 08:14:00 PM
by ga jones
Questions on older 450 Timberjack engine and trans
Started by Spartan on Forestry and Logging
Last post September 18, 2016, 10:40:12 AM
by treeslayer2003
thumbup
Timberjack
Started by minn firewood cutter on Forestry and Logging
Last post April 10, 2013, 04:54:13 PM
