Baltic Abrasives Technologies
Author Topic: Looking for input on future engine upgrade/replacement  (Read 468 times)
Offline Two Trax
« on: November 04, 2018, 08:29:43 AM »
Good day - It's a Sunday morning and hopefully everyone is enjoying the day. I have read several threads here on this subject but did not find the answers to my questions.
First of all there is no immediate need for me to replace the engine on the mill I recently bought. BUT I have come across a very good opportunity to purchase a brand new Briggs Vanguard 35 hp motor at a very attractive price.
It has been my experience that it often pays off to take advantage of good buys when you may not need the item right now rather than trying to buy something when your back is up against the wall.
The mill is a TimberKing B20 with the 25 hp Kohler. It has a 1 1/8 shaft. The Briggs has a 1 7/16 shaft. No problem there as I have a friend with a lathe and a bridgeport. Weight seems like it would not be an issue. May have to drill new mounting holes. Unsure of shaft height differences, maybe a little work getting everything lined up, clearance etc.
I have not sawn a lot of material yet but it seems that when sawing bigger oaks, it makes that Kohler work pretty good. For those with experience on higher horsepower mills, would going to a 35 hp engine make a big difference? My gut tells me yes. Is this engine reliable in sawmill applications? Seems Kohler pretty much owns the sawmill turf, why?
Lastly I would very much like a diesel, but much higher cost and it seems like a lot of mods needed to handle the extra weight, stub shaft fabrication for pulley etc. I read where Ladylake put an Isuzu on his mill and likes it a lot. I am unsure at this point I would ever do enough sawing to justify the cost and effort.
So what do you guys with much more experience think?
Livin the dream!
Offline SawyerTed
  • Summey Lumber Services, LLC
Re: Looking for input on future engine upgrade/replacement
« Reply #1 on: November 04, 2018, 05:07:02 PM »
If I recall correctly, in comparable size engines, Kohler produces higher torque with less hp than the Briggs and Stratton.  It may be worth comparing both hp and torque values.  To me on a sawmill, torque and operating rpm is more important than horsepower.  Torque will aid in maintaining blade speed when load is heavy- hardwoods and knots etc.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline barbender
« Reply #2 on: November 04, 2018, 08:01:03 PM »
There's a lot of variables in engine selection, but "it just has too much power" said no one ever😁
Offline ladylake
« Reply #3 on: November 04, 2018, 08:44:57 PM »
 I've run my brothers 34hp HP Kohler TK 2000, saws a lot faster in the wide cuts than the 27hp Kohler my B20 came with. More difference than you would think, way more torque being 999c vs 750 cc.  Steve
Offline Two Trax
« Reply #4 on: November 05, 2018, 08:39:25 AM »
Some good info, any input on reliability of the Briggs Vanguard big block on a sawmill?
Livin the dream!
Offline motzingg
« Reply #5 on: November 05, 2018, 12:01:57 PM »
Their higher hp vanguard models are pretty well built, iron liners, full pressure lube, etc.   In the last few years they have been trying to get out of competing with china on the low end stuff and put some good design $$ into the higher end market that Kohler has previously owned.
I have run all of them on lawn care equipment, kawasaki and honda are generally the best if you take care of them, the kohlers seem to hold up to abuse better, the briggs are somewhere in between, had some good ones and some bad ones. I think Kohler gets the small manufacturer market because they support their product well and if you're 'bob the sawmill manufacturer' the last thing you want is *pithed off customers calling with problems with engines you didn't make and don't want to spend your time supporting.
Whenever i see a cheap engine, i grab it, never know when you'll need it. More is generally better but going too big on most things will start to tear stuff up downstream.  I went from a 16 hp to 24 hp on a big commercial walk behind mower once, after that it started destroying spindle bearings once a month or more.
Offline barbender
« Reply #6 on: November 05, 2018, 12:38:32 PM »
That's the nice thing on a bandmill, other than the weight of the engine being a consideration, the hp goes right to the blade.
engine upgrade
Started by Engineer on Sawmills and Milling
Last post June 14, 2007, 01:11:53 PM
by tomboysawyer
LT 35 engine upgrade
Started by Southside logger on Sawmills and Milling
Last post April 17, 2018, 08:39:56 PM
by DR_Buck
6-13/6-14 Lucas engine upgrade?
Started by DDobbs on Sawmills and Milling
Last post May 10, 2016, 05:25:54 PM
by DDobbs
Considering engine replacement
Started by kelLOGg on Sawmills and Milling
Last post August 10, 2017, 09:02:41 PM
by kelLOGg
