Author Topic: Sharpening  (Read 529 times)
Offline hopm
Sharpening
« on: November 04, 2018, 09:50:45 AM »
I know there's better equipment and methods, but I got what I got.I'm sharpening band blades with the grinder type sharpener from EZ Boardwalk. When I started even blades with multiply sharpenings were perfect. No issues. BUT as time has passed I struggle with efficient sharpening even on blades with their first grind. What has changed? I know it could be many varibles, but I'm missing something. Any suggestions?
Thanks in advance for any replies!!
Offline JB Griffin
Re: Sharpening
« Reply #1 on: November 04, 2018, 10:29:51 AM »
Too many variables for the info you shared. Can you give a run down on your process and pics are always helpful.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Online LeeB
Re: Sharpening
« Reply #2 on: November 04, 2018, 11:39:22 AM »
Maybe a better description of the grinder for those of us not familiar with that brand.
Offline barbender
Re: Sharpening
« Reply #3 on: November 04, 2018, 11:47:32 AM »
It's s chainsaw grinder modded with an index mechanism for the band blade if my memory serves me correctly. So it only grinds the face of the tooth. But yes, we need more info as to what is going on.
Offline Skipper11A
Re: Sharpening
« Reply #4 on: November 04, 2018, 06:54:16 PM »
Barbender's description of the EZ Boardwalk sharpener is correct. But we need a better description of what the problem is.  We would also need to know if the OP is using the red stone or a diamond wheel, and how old they are.  The solution may be as simple as flipping the wheel over to sharpen with a fresh side.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Sharpening
« Reply #5 on: November 04, 2018, 07:00:46 PM »
Not familiar with his sharpener, but does that grinding wheel need to be routinely redressed like the common "drag style" grinding wheels?
~Chuck~
I LOVE MY SAWMILL
Slick sharpening jig, for sharpening slicks.
Started by Dave Shepard on Timber Framing/Log construction
Last post August 21, 2017, 11:15:58 PM
by Andries
Chain sharpening kit or automatic sharpening
Started by NovaSS on Chainsaws
Last post November 22, 2013, 02:29:18 PM
by thecfarm
Sharpening at -2F
Started by Peter Drouin on Sawmills and Milling
Last post December 30, 2017, 07:13:25 AM
by Peter Drouin
To set before or after sharpening
Started by GF on Sawmills and Milling
Last post November 16, 2005, 10:30:03 AM
by GF
