Author Topic: What type of blade is this ( pic)  (Read 1423 times)
Offline Quebecnewf
« on: November 05, 2018, 04:22:09 AM »
 A buddy of mine received 10 of these with his new mill . Never seen this type of profile before
What type!?
Who makes them ?
What are they designed to saw?
Any other info or comments..
Quebecnewf
Offline ely
Re: What type of blade is this ( pic)
« Reply #1 on: November 05, 2018, 06:02:15 AM »
From the picture, I guess band saw is type,maybe cooks brand silver tip, made to saw wood. I know that's pretty vague but it's my guess.
Offline Satamax
« Reply #2 on: November 05, 2018, 06:28:45 AM »
You know i'm a DIYer, and don't know much. But isn't that what they call "rake" teeth? Just checking some pics, it's not far from skip tooth type either.
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #3 on: November 05, 2018, 06:40:24 AM »
What brand of mill, won't that be the brand of blade?
If you said Woodmizer I would guess those are 10 degree double hards. Is the tooth spacing 7/8"?
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline PAmizerman
  • Just Another Day In Paradise!!
« Reply #4 on: November 05, 2018, 07:41:22 AM »
Is that actually a double tooth or is that the band behind it?
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline moodnacreek
  • Sawin by the notches
« Reply #5 on: November 05, 2018, 07:53:14 AM »
In wood cutting band saw blades there are an endless number of patterns.
Offline barbender
« Reply #6 on: November 05, 2018, 07:58:05 AM »
I think Lennox makes one called the "Chipsweep", with that double tooth pattern. I think they are for frozen wood.
Offline Southside logger
« Reply #7 on: November 05, 2018, 08:02:35 AM »
Using my phone I could zoom in, looks like a regular 10 degree band, there are a couple stacked together, thus the odd looking tooth arrangement.
Offline Quebecnewf
« Reply #8 on: November 05, 2018, 11:30:15 AM »
Going to get a better pic. I thought they were double tooth but now I'm not sure
Quebecnewf
Online LeeB
« Reply #9 on: November 05, 2018, 11:49:41 AM »
One blade stacked on another. Fooled me too at first glance. Seems like if it was a double tooth like that it wouldn't cut very well. You surely wouldn't be able to sharpen it.
Offline barbender
« Reply #10 on: November 05, 2018, 01:58:24 PM »
You guys are right, those blades are stacked.
Offline barbender
« Reply #11 on: November 05, 2018, 01:59:14 PM »
That profile isn't much different than that chipsweep, though.
Offline ladylake
« Reply #12 on: November 05, 2018, 05:30:51 PM »
Offline Bill Gaiche
  • Home built bandsaw, Kioti ck30. Sthil 211 & 361.
« Reply #13 on: November 05, 2018, 07:36:12 PM »
Double stacked side by side with a little offset. Besides, who has a sharpener that would grind those teeth. bg
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #14 on: November 06, 2018, 12:56:05 AM »
Yep. The glare in the photo makes it hard to see. If you closely you can see the gullet in the front blade under the tooth in the back blade.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Blade type
Started by revid on Sawmills and Milling
Last post March 12, 2018, 08:24:03 PM
by starmac
question
band blade type
Started by DDW_OR on Sawmills and Milling
Last post May 12, 2018, 03:13:29 PM
by WV Sawmiller
Skidder type blade for FEL?
Started by DeerMeadowFarm on Forestry and Logging
Last post December 03, 2016, 08:41:26 PM
by thecfarm
need help choosing blade type
Started by dirtmotor on Sawmills and Milling
Last post February 08, 2017, 09:20:36 PM
by dirtmotor
