Author Topic: Material for under posts  (Read 628 times)
Offline glen_h
« on: November 05, 2018, 11:59:10 PM »
Hi,
I'm looking for recommendations for what to put under my posts and they will be on patio stones (not the best but ...).  I hope to be hoisting a 10x12' timber frame Gazebo this weekend and the 4 posts are 8x8" white cedar.
I'm concerned about:
  • rot due to soaking up the rain (from the ground)
  • to help spread out the load
  • to protect the patio stones from damage
I've read about people using metal washers to add a bit of space to keep the post elevated a bit off the ground but I'm concerned they might damage the patio stones or possibly rust.  Costco is selling garage mats that are made from recycled tire rubber(?) and are about 1/2" thick.  If the bottom is sealed by the rubber will that cause an issue since water can't run out the bottom of the post?  Also, how to attach the rubber (or whatever) to the bottom of the post?  Galvanized outdoor wood screws?
The patio foundation is 18" of crushed stones (compacted) with 2 1/2" (?) patio stones.  Currently I don't have a great plan for how to anchor the gazebo to the ground but I was hoping to do it after it is raised.
Glen
Online Don P
    • Calculator Index
Re: Material for under posts
« Reply #1 on: November 06, 2018, 07:18:17 AM »
Correctly you would remove or saw thru the patio stone and pour a footing. In that pour you could put something like a Simpson post base with a ~1" thick plastic standoff. They have one with a hidden knife plate that works well.
Offline mike_belben
  • Pulp Friction
« Reply #2 on: November 06, 2018, 09:47:28 AM »
A big square hunk of concrete (or poured chair.  They sell forms for this at the big box) with a redhead anchor pounded into center standing proud, then an asphalt shingle, then a post with a mating hole bored in center over it.
I motor oil the grain of butt ends to keep termites from eating it up.  The shingle is a cheap moisture barrier to keep post from wicking it out of the block. Grit side down.
Revelation 3:20
Peg Material
Started by S.Hyland on Timber Framing/Log construction
Last post March 04, 2014, 05:16:56 PM
by Tom King
log bed material
Started by bedway on Wanted
Last post December 06, 2006, 08:36:03 PM
by 4woody
Peg material
Started by DWM II on Timber Framing/Log construction
Last post March 21, 2008, 09:12:16 PM
by peter nap
New wonder material?
Started by TeaW on Forestry and Logging
Last post September 08, 2012, 10:02:23 AM
by barbender
