Author Topic: Found a Beauty  (Read 7082 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Found a Beauty
« on: November 06, 2018, 08:18:27 PM »
To a sawyer a Beauty has to be a log right?  I was at my property today after voting and found this Cherrybark Red Oak on the ground.  Saturated ground, tall tree, and wind does not mix very well.  :-\
The butt swell is well over 3' and the butt log DBH would easily push 30"+.
I have admired this beauty many times in the past.
52' to the first fork and from there two stems (12"-15") still going up with relatively no side limbs.
The dilemma is that I have no use for any lumber.  I have plenty already sawn and stickered for my barn restoration/refurbishing project.  This thing contains two years worth of firewood, but it is begging to be sawn.  :-X
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Found a Beauty
« Reply #1 on: November 06, 2018, 08:22:43 PM »
If you don't saw it, I will come and get it :).
Online Southside
Re: Found a Beauty
« Reply #2 on: November 06, 2018, 08:28:37 PM »
Any parenchyma bands present?   :D Or perhaps a Mariachi band instead?  smiley_trap_drummer  smiley_guitarist horn_smiley
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Found a Beauty
« Reply #3 on: November 06, 2018, 08:35:13 PM »
It was being closely guarded by these guys:
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Found a Beauty
« Reply #4 on: November 06, 2018, 08:41:36 PM »
Saw you some Mantels and store them.
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
Re: Found a Beauty
« Reply #5 on: November 06, 2018, 08:57:46 PM »
Now you have too show us all what's inside that beauty
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Found a Beauty
« Reply #6 on: November 06, 2018, 09:00:07 PM »
This one will present several challenges the first of which will be extraction.  Any kind of reasonable length logs will be crowding/exceeding 4K lbs. which is much more than my JD 1530 e/w my Tajfun logging winch can handle.  :-\
Offline Brad_bb
Re: Found a Beauty
« Reply #7 on: November 06, 2018, 09:11:15 PM »
MM, Firewood logs are meant to be firewood (but oftentimes live edge braces in my case).  Saw logs are meant to be sawn, and veneer logs are meant to be sawn if we get our hands on them first.
That would be a good tie beam log given its length and qualities. Or RRQS logs.
Don't you know anyone with a boom forklift or a big skid steer to help you get it out? Firewood would be a sin.  You gotta mill it.
Offline Don P
    • Calculator Index
Re: Found a Beauty
« Reply #8 on: November 06, 2018, 09:20:05 PM »
Brad beat me to it, that thing looks nice.
If the twist isn't too much that looks like it would grade very well as a large, long, red oak beam. That's the kind of tree we were scouring the woods for last year for our barn repair projects.
We made the beams in the woods with a CSM... if there is anyone in your neighborhood who is doing that or a timberframe they could do that. The beam came out easier than the log and then we bucked the large slabs and took them out to the sawmill in board lengths easily.
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Found a Beauty
« Reply #9 on: November 06, 2018, 09:21:18 PM »
Lynn,
   Sorry you lost such a nice wildlife tree. Hope you can salvage some good lumber out of what is left.
    How far will you have to snake the logs out to a spot you could reasonably get and set up your sawmill?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Found a Beauty
« Reply #10 on: November 06, 2018, 09:32:50 PM »
It would take a skidder to get the entire stem out and that ain't happening.
Offline SawyerTed
  • Summey Lumber Services, LLC
Re: Found a Beauty
« Reply #11 on: November 06, 2018, 10:41:39 PM »
I feel your pain - 20 or so hardwood trees came down in TS Michael. The biggest are white oaks and hickories.  Im stuck with the dilemma of how to get some of them out of the woods as well.  Our farm is extremely steep so the dilemma is compounded.  I do have the opposite problem- plenty of firewood and a need for lumber.
One red oak produced 5 9 saw logs with the smallest end 18.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline DelawhereJoe
  • Trapped in Delawhere
Re: Found a Beauty
« Reply #12 on: November 06, 2018, 10:44:25 PM »
You probably have 2 years worth of firewood just in the branches with as far south as you live. It would be sad to see that beautiful straight tree chopped up into firewood when you have a sawmill just sitting around.
Offline Ianab
Re: Found a Beauty
« Reply #13 on: November 07, 2018, 01:23:18 AM »
Need to find someone with a little swing blade mill  ;D
I'm a bit far away, but I'd saw up a tree like that where it's laying and haul the boards out with whatever machine you had handy, quad bike or bigger.
Offline WDH
  • Forester
Re: Found a Beauty
« Reply #14 on: November 07, 2018, 07:56:26 AM »
I have the same problem courtesy of Hurricane Michael.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Found a Beauty
« Reply #15 on: November 07, 2018, 08:59:48 AM »
In 2010, I lost these two Cherrybark Oaks due to lightening:
They were both over 36" DBH.
And then in 2014, these two fell in opposite directions.  The closest was a Water Oak and the other a Cherrybark Oak.  Both were well over 40" DBH.
Sadly I was unable to recover any of them due to their location.  I have learned to accept that which I can not control.  :-\
Offline Rhodemont
  • Logging and milling just a hobby
Re: Found a Beauty
« Reply #16 on: November 07, 2018, 10:24:30 AM »
I have not yet come to terms as you have MM.  With a tree that nice i would be waiting for ground to freeze and going after it.  Probably making a mess and looking like a fool doing it like I did with a particular log last winter.
Woodmizer LT35HD    JD4720 with Norse350 winch
Stihl 362, 039, and now an Echo CS-2511T
Offline derhntr
  • Sawing lumber is addicting
Re: Found a Beauty
« Reply #17 on: November 07, 2018, 12:55:23 PM »
Split the trunk with black powder to size your winch can haul out.
2006 Woodmizer LT40HDG28 with command control (I hate walking in sawdust)
US Army National Guard (RET) SFC
Re: Found a Beauty
« Reply #18 on: November 07, 2018, 02:05:15 PM »
Rhody,
   By the time the ground froze in hard enough in Mississippi to get heavy equipment in to that log it would likely have already rotted to sawdust on it's own. :D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Found a Beauty
« Reply #19 on: November 07, 2018, 02:11:40 PM »
Correct Howard, our ground does not freeze.
I talked with Marty and it appears that the lumber is destined to become flooring in his home.  I also talked with my kiln/milling guy to verify the length and widths that he prefers.  I will saw, sticker, and air dry before delivering it to him in March.  We now have a plan.   :)
Re: Old Beauty
Started by scottr on Chainsaws
Last post December 15, 2004, 07:48:20 PM
by Lewis Brander
Isn't she a beauty
Started by WoodSmith on Sawmills and Milling
Last post October 27, 2004, 05:54:32 AM
by Minnesota_boy
Something to think about. Old is Beauty.
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 07, 2015, 06:23:49 PM
by fishfighter
Beauty and boardfeet
Started by bandmiller2 on Sawmills and Milling
Last post December 21, 2008, 09:26:12 PM
by Meadows Miller
