Author Topic: Building interior doors  (Read 1825 times)
Offline dustyhat
« on: November 08, 2018, 09:36:26 PM »
Have any of you guys ever build doors from 2x6 pine for doors ,edge joining ,and doing the x bracing barn door look. my wife is wanting this and i am afraid they would bow and try to warp , any suggestions ? how one could go about this?
Running a custom built stationary bandmill with a slightly modded four cyl jeep go devil engine.
Offline btulloh
Re: Building interior doors
« Reply #1 on: November 08, 2018, 10:00:44 PM »
Use 4/4 rough sawn and shiplapped .Leave some space between for seasonal movement. Use 3/4 for the battens and braces.  If you double up on the edge pieces you can use regular hardware .
Offline dustyhat
« Reply #2 on: November 10, 2018, 07:45:15 AM »
Ok ,thanks btulloh. im gona do some experimenting and try this . i just have never tried big doors and was a little worried about it.
Online Brad_bb
« Reply #3 on: November 10, 2018, 09:24:28 AM »
Use titebond 1 for interior stuff.
Titebond I vs II in General Woodworking
Offline btulloh
« Reply #4 on: November 10, 2018, 01:50:56 PM »
Good idea.  These are the easiest doors you can make.  Just keep experimenting until the architect/wife is happy.
The only thing you really need to watch out for when using these in a cased door opening is seasonal wood movement.  That's not a problem if you allow the outside pieces to expand toward the center.  Otherwise you door could stick in the summer or be loose in the winter.  Not a problem if you account for it.  If you don't mind cracks between the boards you don't even need to do shiplap.
If you're going to use period hardware like H-L surface hinges you don't need to double up the outside pieces.  Period hardware would look better on this type of door anyway.
Here's a quick and dirty one I made out junk laying around, which was pine paneling), just to get by for a few weeks.  Three years so ago.  I wanted to use butt hinges and a lockset I had laying around, so that's why a did it this way.
Online Bruno of NH
« Reply #5 on: November 10, 2018, 07:01:56 PM »
I have built many doors with one inch stock and z braces
Some with shiplap and some t and g
I got a name in my area for building them
I have built many
Have not had a issue with warping
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline muggs
    • Hardins industries
« Reply #6 on: November 10, 2018, 07:18:37 PM »
one of my businesses was building doors, I built them by the thousands. But mine were all frame and panel. So good luck.  Muggs 8)
Offline dustyhat
« Reply #7 on: November 11, 2018, 12:40:57 PM »
Thanks guys , i haven't done much woodworking in a while , so keep the info coming and i like the pics so keep them coming, it gives me ideas. we are building the dream home we want now, and all i can do myself will cost less money. i will probably be building the cabinet doors the same way as well , so all the pointers are appreciated.
Offline btulloh
« Reply #8 on: November 12, 2018, 07:28:03 AM »
Look around and see what was done back in the day.  There's plenty of pictures in the interweb.  Maybe visit a historic building locally.  Most of them were done in the Z style.  The diagonal should run from the hinge side at the bottom end to the lock side on the top.
Offline fishfighter
« Reply #9 on: November 12, 2018, 09:07:08 AM »
Built some out of water oak. Very heavy doors that I had to use extra heavy hinges. :o
This one is like a pocket door.
Offline Lawg Dawg
  • True South Sawmill Lumber
« Reply #10 on: November 13, 2018, 08:26:31 PM »
I built this today, 13/16", two layers, the back boards are ship lapped
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
 John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Online Bruno of NH
« Reply #11 on: November 14, 2018, 04:28:43 PM »
I notch the z brace into the horizontals
Or pin with a tappered dowel or biscuts
Offline dustyhat
« Reply #12 on: November 14, 2018, 07:20:48 PM »
Very good looking doors guys.
Offline tule peak timber
  • roborob
    • tule peak timber
« Reply #13 on: November 14, 2018, 08:07:24 PM »
I also build a lot of doors and like others in this thread pay attention to letting the panels move within the frame - no matter what the door looks like. Just saying.
A door done with pins to allow for movement.
Offline samandothers
« Reply #14 on: November 14, 2018, 08:35:07 PM »
So Dawg how did you allow for movement in the ship lap with cross bracing. I assume the crosses are only on one side.
Tule Peak, are there horizontal slots in the vertical boards the bolts/ pins pass through? Are those vertical boards glued to one another so the door doesn’t rack?
  • roborob
    • tule peak timber
« Reply #15 on: November 14, 2018, 08:50:07 PM »
Good eye,,,,,No glue, but deep dado to keep registration . Rob
Online Brad_bb
« Reply #16 on: November 24, 2018, 08:47:20 AM »
You want to make sure  you know the moisture content of the wood.  If the wood is stored outside, I'd condition it inside where it's going to be used.  Going from 12-15% outside will then go to 7-8% inside over time.  If you have a meter, see where your wood is at.  Maybe check something that has been in your house.  Then bring your door material inside stickered to acclimatize for a month or so.  Winter is the driest time of year, so your board will be the smallest. In summer they will grow a little from higher humidity. Keep that in mind when building them.
Offline dustyhat
« Reply #17 on: November 25, 2018, 05:11:43 PM »
Yes., thanks guys i will try to keep you all posted . right now im laying logs 8x8 12 feet poplar by hand. just about to break me down but i will get the doors done shortly.
  • roborob
    • tule peak timber
« Reply #18 on: November 28, 2018, 02:23:00 PM »
An entry door set we finished today. Fire killed black oak and redwood. The main door panel is a single oak slab that varies in thickness from 1-2 inches with a"wavy"- undulating surface. Heavy !
Offline dustyhat
« Reply #19 on: November 28, 2018, 08:36:22 PM »
You do good work, tule peak timber
solar kiln with building steel interior/exterior
Started by jbuck984 on Drying and Processing
Last post December 31, 2013, 07:25:22 PM
by jbuck984
Framing Doors against Posts (Pre-Hung or Slab Doors)
Started by jb9 on Timber Framing/Log construction
Last post June 22, 2017, 08:02:48 AM
by jb9
spotting interior rot?
Started by limbrat on Sawmills and Milling
Last post June 12, 2007, 05:11:19 PM
by Ron Wenrich
Interior walls
Started by danreed76 on Timber Framing/Log construction
Last post May 09, 2013, 09:18:14 AM
by canopy
