Tally-I/O
Author Topic: Wide Mill Build  (Read 3953 times)
Offline charles mann
Re: Wide Mill Build
« Reply #100 on: November 29, 2019, 04:25:24 PM »
Only that you'll be closer to the dust, it'll be put into the wind blowing around right in front of you. Not a big deal really but would have thought away from operator would be better. As said you've got your dogs or stops out of sight whichever side you stand
Keeping an eye on them stops is more important than me not wearing the proper PPE. Plus every WM iv seen is chuting out the operator side and the operators seem to deal with it just fine. Plus got some 4’ 4” flexible spiral wrapped high temp heater duct hose i can use to help direct the dust closer to the ground for the higher cuts.
Weather has been miserable today and standing on a wet 5” sq tubing with a walking boot aint the best choice. Looks like im sol for the next couple days. Nothing but crap weather. I hate having surgery, but this time, its yielding me ample time to drive forward on this build.
Temple, Tx
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Wide Mill Build
« Reply #101 on: November 29, 2019, 07:31:44 PM »
I actually think on version 2 I will also be on the sawdust side. with the sawdust on the opposite side it seems to blow in my face more. My thought is if i am on  the same side there is a good chance that the sawdust will blow but be low enough it will not be in my face.
Offline JoshNZ
Re: Wide Mill Build
« Reply #102 on: November 30, 2019, 05:31:37 PM »
Can always get a buddy to monitor the operator side and push from the dust chute side, see what happens. I prefer the idea of the engaged/exposed bands energy pointed away from me either way. I get a fair bit of dust blowing up in my face too, would depend on the day and what the wind is doing I think. A mask is def the easy answer!
Re: Wide Mill Build
« Reply #103 on: November 30, 2019, 07:28:31 PM »
don't have buddies until they need something from me, and i prefer it that way most of the time. 99.999% of everything that happens at my 2 land locations is done by me. step brother is as useful as teats on a boar hog when it comes to land maint, but enjoys living on the land for free and then its difficult to get the wife away from her dang electronics, let along outside chores when I'm at work for 2 wks. i deff don't get much help out of her in this mill build, and when real work starts after its built, ill only see her if i go in the house. but i will deff see her when the $$$$ comes in from the sale of the slabs.
the plus side, i get peace and quiet and she is supportive of me buying a crane truck to load the logs on the mill and to rescue downed ones from the firewood piles.
crane truck
Temple, Tx
Offline JoshNZ
Re: Wide Mill Build
« Reply #104 on: November 30, 2019, 07:37:57 PM »
Lol sounds like a good arrangement =/.
It actually wouldn't be hard to change the operator side would it. Fairly late in the peace in your build mill. Tighten the throttle lever up so it stays in place then push from both sides, see what you prefer before wiring and welding controls/handles etc
Re: Wide Mill Build
« Reply #105 on: November 30, 2019, 07:58:49 PM »
throttle engagement is electrical, using an high idle solenoid and all the other gages and such are all electrical, so either side will work, just add a few feet of wiring to move the control box that isn't even built yet, to 1 side or the other.
only issue will be belt engagement, unless i use a linear actuator to lift the motor or push/pull on a flat belt idle pulley.
Temple, Tx
Offline Hoopty5.0
Re: Wide Mill Build
« Reply #106 on: December 02, 2019, 10:29:43 AM »
Just wanted to say it was nice to meet you the other day and this mill is incredibly impressive. I'll keep an eye on the updates. Thanks again for the pecan
Re: Wide Mill Build
« Reply #107 on: December 03, 2019, 07:12:22 PM »
it was great meeting you too. ill keep an eye out in my area for more "free" woo that is to small for me to mess with and drop it off to you when i have a job in that area.
Temple, Tx
Re: Wide Mill Build
« Reply #108 on: December 03, 2019, 07:33:58 PM »
RH tensioning and idler sprockets
Had to hang test a UHMW rub block to help take stress off the outer sprockets that are attached to the tensioners. I think i'll work. Im gonna run the sawed all the way to the top and see if the block will interfere with the blade guards, that are not even built yet. but i can guesstimate where the guards will sit.
basically the same as the right side. The plans called for only 1 side to apply tension, but i planned for such issues and decided to make both outer brackets to adjust. at full "IN", i was 1 dang link off. iv got 2 quick links together, so when i tear it all down to clean and paint, ill bust a link out somewhere else already marked and move the quick link.
i reconnected the couplings so they would engage the lift rods and lift the sawhead with the band wheels installed. it took 18 ftlbs of force to keep it moving and 20 ftlbs to to start movement.
tomorrow will be spent getting the carriage lifted off the mill bed and turned 180° so i can access the back of everything and get the carriage under cover and still be able to work, plus get the eng yarded out of the cart, using the existing cart frame as an eng stand, and possibly weld it to the sawhead.
please provide +/- criticism of this lifting system.
Temple, Tx
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Wide Mill Build
« Reply #109 on: December 04, 2019, 06:56:17 AM »
looks like your running 2 separate motors for lifting? If that is true are you concerned about one side lifting more than the other? Or do you have them connected somehow?
Offline Vautour
Re: Wide Mill Build
« Reply #110 on: December 04, 2019, 07:18:17 AM »
.... looks good nice work .. if your installing that diesel, acme rods were probably your best bet for lifting that weight... thumbs-up
the Gospel is WANTED by the people in 52 Countries but made illegal by their Government
Re: Wide Mill Build
« Reply #111 on: December 04, 2019, 09:32:38 AM »
They are connected with chain
Temple, Tx
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Wide Mill Build
« Reply #112 on: December 04, 2019, 09:38:49 AM »
ok. figured they were but didn't see it.
Re: Wide Mill Build
« Reply #113 on: December 04, 2019, 10:45:19 AM »
as of now, yea, i think I'm "stuck" with with this lil cummins. but on the vertical shaft/horz mill topic, someone said attach a genny and go elec. i think that'll be next my next upgrade. get a 30k mil genny, already 3ph and 1ph, so i can power a 240 and 120v ac motors, and set the genny on the back like i was gonna do when i had plans of going complete hyd. plus once this build is done, have a lil spare money/time for a project auto, I'm gonna start a chop top 20s-30s era build and install the cummins in it, so, ill have to find an alt power plant means for the mill. i think elec might fit that bill.
Temple, Tx
Offline Hoopty5.0
Re: Wide Mill Build
« Reply #114 on: December 04, 2019, 11:10:33 AM »
I think that's a great idea to go electric and would solve a lot of weight and/or clearance issues.
Re: Wide Mill Build
« Reply #115 on: December 04, 2019, 03:12:00 PM »
OMG, for only 20ft lbs of tq required to lift the system as it sits, my air ratchet with 60ft lbs of tq struggled/stalled trying to power raise, my IR 1/2” impact said NO!!!!, but im guessing that it bc its hammering more than twisting. I raised it using an 18” 1/2” ratchet, which worked nearly effortlessly but good gosh, it took FOREVER at 0.20” per rotation and raising it 4 feet.
As for extending the rods, i might as well had not spent the $$ to do it, since it only gained me 3” of extra height, but the nuts engaged the added rod with no noticeable extra effort, and by the time i got there, my arms were already burning from 10 min of ratcheting, and im sure i would have noticed an extra effort turning through the engagement.
Will post a 40 sec vid when my internet decides it want to work.
I did forget to measure the top of drive wheel to guesstimate where the guards will be in relation to the chain tensioning mechanisms and the guide block. Glad i didnt lower it all the way, only 6-8” from the top. But i did take a measurement from the top of the sawbeam to the bottom of the tensioner. I can extrapolate an estimated distance on the guards from the tensioner.
Temple, Tx
Re: Wide Mill Build
« Reply #116 on: December 04, 2019, 03:32:55 PM »
lets see if this work. IDK what the deal is. every time i post something, the dang pic turns sideways.
link edited. i deleted the first vid and uploaded a new vid and ensured it would be made public.
https://www.youtube.com/watch?v=G_ADWPDDQLQ&feature=youtu.be
Temple, Tx
Online btulloh
Re: Wide Mill Build
« Reply #117 on: December 04, 2019, 03:37:16 PM »
It’s marked private. You need to mark it public so we can view it.
@charles mann
HM126
Re: Wide Mill Build
« Reply #118 on: December 04, 2019, 03:59:52 PM »
@charles mann
huh. ill log back and see if i can change it to public.
thanks for letting me know.
Temple, Tx
Re: Wide Mill Build
« Reply #119 on: December 04, 2019, 04:03:39 PM »
@btulloh try now. if it doesn't work, ill have my wife mess with it when she gets home. idk much about this tech stuff. i still believe in the steam gauge so to speak
Temple, Tx
question
what mill to buy? lt15 wide or lt40 wide
Started by markymark on Sawmills and Milling
Last post January 28, 2019, 07:58:32 AM
by stanmillnc
Long and wide build started
Started by thinwater on Sawmills and Milling
Last post November 27, 2018, 07:29:18 PM
by thinwater
LT15 Wide, LT70 Wide, where's the Wide Edger?
Started by Dave Shepard on Sawmills and Milling
Last post March 25, 2018, 11:53:41 PM
by Darrel
Wide cutting mill
Started by epiphoneprs on Sawmills and Milling
Last post April 21, 2014, 01:40:29 PM
by wwsjr
