Author Topic: Ash logs  (Read 1970 times)
Offline CX3
Ash logs
« on: November 26, 2018, 06:11:48 PM »
I have a 40 tree portable ash job to saw. I looked at the standing timber today they are nice trees.
I have not sawn an ash log in my life. I have knocked out a few hundred thousand feet of oak though.
Are there any major concerns headed my way?
Many thanks.
John 3:16
You Better Believe It!
Online WV Sawmiller
    • Green's Sawmill Services
Re: Ash logs
« Reply #1 on: November 26, 2018, 06:27:26 PM »
   I find ash can often have stress so be ready for moving cants. It also tends to gum up my blades so use plenty of lube to clean them. It is very straight grained and can tend to want to split easily. I use 4 degree doublehard WM blades and am well pleased with their performance on ash.
   IMHO it is beautiful wood and the smell reminds me of an old bee tree. Good luck.
Online terrifictimbersllc
    • Terrific Timbers LLC
Re: Ash logs
« Reply #2 on: November 26, 2018, 06:31:17 PM »
Yes, can expect lots of stress, maybe some won't have it.  4 degree bands and be able to keep them clean.  These are the thoughts I have about ash, too.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline GDinMaine
Re: Ash logs
« Reply #3 on: November 26, 2018, 07:29:22 PM »
Smallish logs are the ones that give you the most grief. I had ash lumber, near the pith, split before I finished the cut, but that is about the worst of it. Box in the pith if you can, and cut it out of the lumber. I find it saws nice with WM Turbo 7 blades.
It's the going that counts not the distance!
WM LT-40HD-D42
Online Old Greenhorn
Re: Ash logs
« Reply #4 on: November 26, 2018, 08:06:39 PM »
I have found that it cuts a heck of a lot easier than white oak, it's softer. I love the wood, nice grain. Yes, the logs I have done have some stress, but I don't have enough experience to know if it is because the way they grew, or just the wood in general.
Can You help out the Coleman Veterans Memorial by chipping in a few bucks? Go here for the full story: Can you help this year? in General Board
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline Mad Professor
Re: Ash logs
« Reply #5 on: November 26, 2018, 08:27:26 PM »
It can end check badly.  End seal the logs as soon as bucked, and boards if you trim them.
Maybe I've been lucky but I have not had much problems with movement on sawn ash.  Maybe because the trees were all straight and clear of limbs for 1st 40 feet.
It makes good stock for timber frames if you box the heart.
Powderpost beetles love it.
Offline 1970bcg
  • Member*
Re: Ash logs
« Reply #6 on: November 26, 2018, 08:30:49 PM »
Keep the heart centered in the cant while you're sawing.  Turn more often if you have to in order to keep the timber spring (stress) centered. This will eliminate a lot of the board splitting.  Run water on your blade to stop sap build up.
Offline PAmizerman
  • Just Another Day In Paradise!!
Re: Ash logs
« Reply #7 on: November 26, 2018, 08:55:29 PM »
It is very dusty and the sawdust seems to stick to you. A dust mask can be a good idea. Plenty of lube to keep the band clean.
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline Brad_bb
    • My timberframe blog
Re: Ash logs
« Reply #8 on: November 26, 2018, 09:33:47 PM »
I've cut a lot of Ash in the last 3 years on my LT15, which may not be considered "a lot" to guys with Hydraulic mills.  I've probably milled 200 sticks?  Just a guess.  This included butt logs up to 36" and also included branch logs down to 8" dia.  Those were cut with flats on two sides.  Larger ones that would make jacket boards were kept.
I have NOT noticed much stress or movement in all the Ash I've cut.  I have been attributing that to the face that most were dead on the stump and dried some in addition to how dry ash is to start with.  I'm assuming that process actually helped to make the wood more stable.  I've had logs that were very dry and logs that were still pretty wet in the middle, but usually the outside was more dry.  There was a gradient of moisture of course.  Very few were so green so as they were cut with a full canopy.  Most have very little or no leafing out when they were cut.  All of them were killed by the emerald Ash borer.
I always used a 4 degree double hard blade.  I run water only for lube, though adding a few drops of Dawn doesn't hurt.
I've cut mostly beams and produced a lot of 5/4 jacket boards(boards that come from everything outside of the beams.  I did cut about 6000 BF or 2x8's for T&G last winter and didn't see significant movement.  All machined out well after drying.
I've seen guys here post about powerpost beetles loving Ash, but I see their frass piles below my oak, and I'm not sure I ever see it from my Ash.  Just the same, the 2x8 T&G mentioned above was treated with Permachink's shellguard (alcohol borate)
Offline SawyerTed
  • Summey Lumber Services, LLC
Re: Ash logs
« Reply #9 on: November 26, 2018, 10:18:36 PM »
I recently had a job that included three ash logs out of a single tree.  Two sawed just like a green red or white oak.  One was ugly, lots of stress and lots of flipping 180 degrees.  I boxed the heart and actually threw it in the burn pile.  The 4x6 heart was moving as I ditched it.  The other two logs sawed fine.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline barbender
Re: Ash logs
« Reply #10 on: November 26, 2018, 10:30:30 PM »
I've sawn Green Ash, it is one of my least favorite to saw. I attribute most of the problems to the very low m.c. of the wood, it takes the edge off of blades fast and it takes a sharp blade to saw it straight. The sawdust is nasty dry stuff, it irritates my eyes. I also found some "timber break" in it, once you get the log opened up you find it is fractured👎 Aside from all of that, it made nice lumber. We also have black ash, that's a completely different animal. Saws beautifully and pleasant to work with all around.  I doubt you have black ash down there, though.
Offline Hooterspfld
  • I'm a sucker for a chainsaw!
Re: Ash logs
« Reply #11 on: November 26, 2018, 10:40:27 PM »
Where abouts in SW Missouri? I'm in Springfield, just getting into wood cutting.  Would like to see a mill in action if your close by.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Ash logs
« Reply #12 on: November 26, 2018, 11:33:33 PM »
Ash is one of the most splintering woods Iíve sawn.  When itís green its not too bad, but will occasionally try to splinter and stab you for the fun of it..
When its dry, it really turns mean, and I canít remeber the last time I handled dry ash, planed or unplaned, when it didnít splinter or stab me somehow. Often it will go through a glove like a porcupine.  Had some cut the palm of a glove a couple days ago when edging.  Donít push boards around with your thigh, or slide them through your gloves when stacking or coming off the mill.  If you see a punji stick developing on the edge of a sawn board, whack it off with a hatchet immedialty.
I know a guy who was planing ash, no big deal, done it a thousand times, when a small splinter just grabbed the cuff of his glove and split off into a spike, where ran down inside the cuff of his glove and then through his hand, requiring significant wood from hand surgery.
Ash is beautiful stuff, but itís cranky, so just watch it so it donít get ya.
HobbyHardwoodAlabama.com
Offline moodnacreek
  • Sawin by the notches
Re: Ash logs
« Reply #13 on: November 27, 2018, 07:49:53 AM »
It is like sawing immature red oak. Also has pitch like conifer and can gum up the saw. Sometimes mixing a few maple logs in the run cleans off the gum.
Offline 69bronco
Re: Ash logs
« Reply #14 on: November 27, 2018, 08:56:51 AM »
Stress in ash🤔
Re: Ash logs
« Reply #15 on: November 27, 2018, 08:59:14 AM »
If you want to talk splinters, eastern hemlock.........
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
Re: Ash logs
« Reply #16 on: November 27, 2018, 09:10:55 AM »
Right on th money 69bronco
Brings back bad memories
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline alan gage
Re: Ash logs
« Reply #17 on: November 27, 2018, 10:31:48 AM »
I'm still pretty new to milling but after reading people complaining about sawing ash I was very happy when I milled about 1000bf of it this fall and it behaved very well. Not much movement at all from the cants or boards. It was very dusty though and did put a little buildup on the blade if I didn't use lube.
Over half of that was from a couple large, clear, and straight logs and the rest came from less perfect logs that are destined to be flooring in my house. The ones for flooring air dried with very little defect and have been processed into strips. One of the logs had a lot of cracking as it got close to the heart so there will be a  lot of waste from those boards but most were fine.
I believe we have both green and white ash here and I'm not sure which I milled (both for all I know).
Alan
Timberking B-16
Offline CX3
Re: Ash logs
« Reply #18 on: November 27, 2018, 04:20:50 PM »
Bruner. Not far from Springfield. Stop by anytime
John 3:16
Offline OffGrid973
  • Off Grid
Re: Ash logs
« Reply #19 on: November 27, 2018, 08:39:38 PM »
Keep it thick seems to be ok...my 2x4 framed wall on the barn build danced all over the place when put together green. I would stay away from framing until it has a chance to dry.
Your Fellow Woodworker,
- Off Grid
Wanted - small diamater low grade walnut logs and pallet logs ...
Started by Wes Lyon on Wanted
Last post August 12, 2006, 10:31:53 PM
by Wes Lyon
blue stain pine logs,aspen logs, Colorado
Started by logloper on Wanted
Last post February 23, 2010, 09:52:24 PM
by logloper
8 ft logs vs vs split logs for seasoning firewood
Started by Christopher7789 on Drying and Processing
Last post March 30, 2017, 10:45:58 PM
by GeneWengert-WoodDoc
What to pay for logs
Started by millstead on Sawmills and Milling
Last post December 23, 2012, 08:23:27 AM
by Okrafarmer
