Author Topic: I'm Believer - Diesel To Cut Pitch  (Read 1392 times)
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
Re: I'm Believer - Diesel To Cut Pitch
« Reply #20 on: November 30, 2018, 12:26:20 PM »
I run a Norwood Lumbermate 2000 that I bought new in 2002. I mill mostly hardwoods and the blade doesn't heat up or get loaded with sap so a couple of years ago I stopped using lube completely. I run my blades dry and have had no problems.
A couple of months ago I was cutting some white pine and right away noticed a buildup on the blade. I used a squirt bottle filled with diesel and just before entering the cut, with the blade spinning Id shoot 2 shots on the blade. Works great. Nice shiny blade with no build up and you don't need a special delivery system.
Jon
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #21 on: November 30, 2018, 04:43:54 PM »
I use the pinesol/WW. I find new blades need no lube, used blades seem to need lube.
Offline Sixacresand
  • John and Nancy
« Reply #22 on: November 30, 2018, 07:39:07 PM »
I apply diesel to the blade as needed with a shop oil pump (squirt can) via a plastic tube.
Offline barbender
« Reply #23 on: November 30, 2018, 07:41:09 PM »
Six, I like that!👍
Offline farmfromkansas
« Reply #24 on: November 30, 2018, 08:54:51 PM »
My Cook MP32 mill came with a tiny tank for diesel with a gravity feed.  Just have to set it for a drop every couple seconds, and it keeps everything clean, lubed, and no hot blades.  I smelled the wood, as the enviro nuts seem to think wood contains diesel fuel, and seems all the diesel is in the sawdust pile.  The local people who handle burn permits will not allow you to burn any lumber, just brush piles.
Offline redneckman
« Reply #25 on: December 01, 2018, 06:10:53 AM »
Are you using the same lube tank?  Just wondering how that stands up to the fuel.
Yes sir.  I put it right into the lube mizer tank.  So far, no problems.  I have read where people have questioned doing this.  To me, I dont see it much different from soap and water.  And, the DF will help keep every thing lubed in the lubemizer system.  Not sure about the seals in the pump, but if they are good enough for the chemicals in soap, I figure they are good enough for DF.
Offline bandmiller2
« Reply #26 on: December 01, 2018, 07:31:03 AM »
If anyone is anal about the diesel smell buy a gallon of unscented kerosene or lamp oil. Diesel is the best and what everything else is compared to. If applied with a wick or felt no drips and a gallon will last a long time. Frank C.
I'm a believer
Started by proteus on Health and Safety
Last post January 28, 2013, 12:21:39 AM
by gjersy
New true believer
Started by Frank_Pender on General Board
Last post July 14, 2005, 10:53:24 AM
by Mike_P.
New Blue Creeper Believer
Started by Jason_AliceMae Farms on Bluecreeper
Last post March 11, 2014, 11:08:37 AM
by Tam-i-am
MF135 Diesel Tractor --- Diesel leaking into crankcase
Started by Left Coast Chris on General Board
Last post May 25, 2008, 08:29:56 AM
by zopi
