HELP THE COLEMAN VETERANS MEMORIAL
Look into "Por 15" for painting rusty metal. I don't know what they make the stuff out of but from a wear standpoint it makes Rust-Oleum look like kids finger paint, it is absolutely amazing.
goes dull in the sun
Rust-mort is a rust converter that I've had excellent success using on various items including some farm equipment. A light wirebrushing to remove loose rust is all that's necessary. Rust-mort doesn't do anything to bare metal. Three or four light coats of Rust-mort applied with a brush will convert the rust into black hard surface overnight. Think thin watery coats not a paint like consistency. You can apply the primer/paint system of your choice once you wipe the surfaces with solvent.
For a rust converter I've been using Ospho, which is mainly phosphoric acid.
Quote from: btulloh on November 30, 2018, 01:26:59 PMFor a rust converter I've been using Ospho, which is mainly phosphoric acid. Most converters are phosphoric acid. I've forgotten that I've used Ospho with good results as well.
I have used have Tannic acid and leave an acrylic polymer primer coating ready for paint after 24 hour
Started by Quebecnewf on Sawmills and Milling
Started by wannabeonetoo on Ask The Forester
Started by HSV on General Board
Started by jrkimroxie on Drying and Processing
