Baltic Abrasives Technologies
Author Topic: Woodmizer cantilever head  (Read 917 times)
Online Crusarius
  • Lost in....
    • RockModified.com
« on: November 30, 2018, 10:36:07 AM »
Does the carriage / mast on the woodmizer cantilever mills use linear bearings? (where the carriage is attached to the bed) Can anyone get me some good closeup pictures of it? I am kinda screwing around with an idea in my head for linear bearings on the carriage but not sue how it will work.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Woodmizer cantilever head
« Reply #1 on: November 30, 2018, 10:43:45 AM »
I can get pics later. They are round bearings. Two on top of the rail. Three on the outside of the top rail, and two on the inside of the bottom rail.
    • My homepage
« Reply #2 on: November 30, 2018, 10:50:36 AM »
Here's a sketch from memory. Some earlier mills had the top bearings at 45° to the main tube.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: November 30, 2018, 11:29:56 AM »
Here is a topic where I replaced my cam followers:  Sawmill maintenance – how to’s and tips. in Sawmills and Milling
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #4 on: November 30, 2018, 12:42:06 PM »
Thanks dave that is a huge help. I was thinking about linear bearings the full 24' length. but I was having second thoughts. Hard to swallow the cost for 48' worth of rails. Still may use them on the slide for the up and down. But the 3 bearings seem to make more sense just need to have a good stainless rail for them to ride on.
MM thanks for the link that was helpful as well. The bracket that had the 2 bearings was the top? by the picture it looked like the bottom?
Wonder if I could get away with V-groove roller on top and simple bearing on the bottom?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: November 30, 2018, 12:47:14 PM »
That was replacing the bottom cam followers.  The last sentence in my reply stated that I had previously replaced my top units.
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #6 on: November 30, 2018, 12:48:57 PM »
oh thanks. I missed that. Huge help though. thankyou.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #7 on: November 30, 2018, 04:16:51 PM »
The woodmizer mills do not use stainless for the rod. We keep them oiled to hold the rust at bay. Stainless would be expensive for sure.
LT40HD, 742b Bobcat, Sthil v170,038, 461. 1952 TEA Fergusan Tractor
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #8 on: November 30, 2018, 05:10:25 PM »
Does that mean there is a scraper / seal on the rail? I would imagine the sawdust buildup would be crazy. rails ever painted or always bare steel?
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #9 on: November 30, 2018, 05:28:49 PM »
What size is that round bar?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #10 on: November 30, 2018, 05:33:55 PM »
Yes there is a Teflon? scraper to prevent sawdust buildup between the rod and cam followers.  Just bare metal after the paint wears off, no problem with rust.  The rod is very much hardened to prevent wearing but earlier models were not hardened and did wear down.  I would not even consider using stainless.
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #11 on: November 30, 2018, 05:38:03 PM »
your probably right. Stainless may be unnecessary. Why wouldn't you use stainless? Just curious.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #12 on: November 30, 2018, 05:42:06 PM »
Not necessary but also the hardness might be an issue with stainless.
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #13 on: November 30, 2018, 06:04:06 PM »
I was kinda wondering about that to. Since I am only sawing for a hobby I doubt the hardness will be an issue for quite a while. Good news is cutting that bar off and replacing it is not that difficult.
Offline Stephen1
    • muskoka Sawmill
« Reply #14 on: December 02, 2018, 11:18:21 AM »
My mill from 1993 had no wear on the bar.Rust yes!, ussually after sitting all winter, even inside. I oil in the fall. In the spring I use a metal brillo pad with TF and scrub the lower rod as it usually has more rust and therefore the electrical contact for the hydraulics can be an issue. Once scrubbed it is good for the season.
Woodmizer head dropping
Started by Kansas on Sawmills and Milling
Last post August 05, 2017, 02:27:02 AM
by GregBuk
Looking for a lt30 woodmizer head
Started by silas1234 on Wanted
Last post January 02, 2015, 09:32:28 AM
by silas1234
Blades for the new WoodMizer Wide Head
Started by DR_Buck on Sawmills and Milling
Last post September 29, 2018, 01:24:00 AM
by redbeard
Woodmizer wide head debarker question
Started by JSTOM on Sawmills and Milling
Last post January 18, 2019, 06:54:53 PM
by Chuck White
