Author Topic: band blade tension  (Read 372 times)
Offline Blaszer
band blade tension
« on: November 30, 2018, 07:38:14 PM »
Ive got a band mill that I built and have used for years...  What is a good primitive way to measure the tensionon my blade?My tensioner is a 1 1/2 all thread that pushes the driven wheel away from the drive side wheel...I guess the question is, how much deflection in the bad over a certain distance would indicate proper tension.?
Offline GAB
Re: band blade tension
« Reply #1 on: November 30, 2018, 07:57:12 PM »
Using a 1- 1/4 x .045 thick blade I would aim for at least .001" per inch of length to start and see how it works.
Gerald
Offline Southside logger
« Reply #2 on: November 30, 2018, 09:19:02 PM »
There are cheaper one out there but this sort of gauge will give you an accurate reading, you could calibrate your tensioner this way too.
Band tensioner
Offline DbltreeBelgians
« Reply #3 on: November 30, 2018, 09:23:18 PM »
I hope that .001 is .001 per inch in a  6 span. If hes got a 158 band thats gonna be a whole lot of stretching the way I see it. Maybe Im wrong on that.
Brent
Offline thecfarm
« Reply #4 on: December 01, 2018, 06:12:22 AM »
Push down on the middle of the blade with your thumb. ;D
I have a Thomas mill. Been doing it that way for years. I must have a feel for it. It works. ???
Offline bandmiller2
« Reply #5 on: December 01, 2018, 06:51:07 AM »
Look up the Timberwolf site and try their flutter test. Too much tension is the leading cause of band breakage. It just seems so natural to highly tension a band to force it on a straight path but it doesn't work that way. When a good sharp well set band cuts straight that's the proper tension. My own home built has springs I compress to a certain distance. Frank C.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #6 on: December 01, 2018, 07:07:12 AM »
If your lumber comes out nice and smooth, without a lot of dips and dives or random marks, your tension is most likely good!
~Chuck~
I LOVE MY SAWMILL
« Reply #7 on: December 01, 2018, 07:50:35 AM »
Too much tension also leads to bearing failure, so there is a sweet spot.
Band Saw Blade Tension Meter
Started by MobileSawMilSlo on Sawmills and Milling
Last post January 30, 2019, 01:55:34 PM
by Pabene
Audible band blade tension gauge
Started by StorminN on Sawmills and Milling
Last post June 05, 2009, 12:39:38 AM
by LeeB
Band tension
Started by Larry on Sawmills and Milling
Last post June 19, 2014, 08:55:56 PM
by bandmiller2
band tension
Started by Dan_Shade on Sawmills and Milling
Last post June 06, 2005, 10:29:01 PM
by AtLast
