Baltic Abrasives Technologies
Author Topic: Most efficient way to make stickers  (Read 1163 times)
Offline Cypress Man
« on: November 30, 2018, 09:15:10 PM »
Hi everyone.  I'm looking for advice on an efficient way to RIP stickers from my edger tailings. What are some of the ways you do it. Types of gang saws etc..
LT70 wide head electric, IC5 Power conveyor, transfer table, Stop and Load Log Deck, Catapiller 360B Telehandler, Cat tl642c Teleloader, Cat TH514 Telehandler, Woodmizer EG400 edger, Logosol PH360 moulder, Extrema 26" Planner, Grizzly 16" dual conveyor resaw, Prentice 285 log loader
Offline PAmizerman
  • Just Another Day In Paradise!!
Re: Most efficient way to make stickers
« Reply #1 on: November 30, 2018, 09:27:14 PM »
I use my edgings to make stickers. It takes some time but I figure why burn it if I can use it.
I use a radial arm saw with a fence to cut the edgings all to 4' then run them through the table saw. It works best to have a helper return the pieces that will yield another sticker back to you. And stack the stickers. All in all it's not too bad a job.
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline carykong
  • Installing my roof ridge metal
    • Have Mill Will Travel
« Reply #2 on: November 30, 2018, 10:04:29 PM »
Your LT70 is more efficient at making sticks than your edger.  Saw your logs in a way that minimizes edging material.    When you want sticks,saw specifically for that mission with your mill.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: November 30, 2018, 10:47:52 PM »
When I need to make a huge pile of stickers I use a sacrificial log.  Square it and saw through, turn 90° and saw through.  Very fast and no lost time piddling with edgings.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #4 on: November 30, 2018, 11:51:53 PM »
I turn a few side boards into stickers as I go if I can.  The chainsaw or skill saw cuts to length depending on the situation.  Sometimes an entire log becomes a cant and the cant becomes stickers.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Online WLC
« Reply #5 on: December 01, 2018, 12:15:04 AM »
I do as Magicman does.  Sacrifice a log.  Slab it to a cant, cut through,  turn 90°, saw to the bed.  I use a chop saw to cut to length.  Can make a pile in short order.  I generally cut mine at 4/4.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Offline Southside logger
« Reply #6 on: December 01, 2018, 08:02:47 AM »
I do recover stickers with my edger when it's there using the right side fence, figure it reduces waste, but for volume I just sacrifice a low value log or cut a 4' piece of sweep out of a log and do as MM says.
Offline pineywoods
« Reply #7 on: December 01, 2018, 09:21:49 AM »
Add 1 small step to Magicman's method. saw a cant, saw through, flip the stack vertical, Then cut in 4 ft lengths with chainsaw,BUT stop the cut 2 inches from the bottom of the board stack. Each pass of the saw head yields a whole stack of cut to length stickers. Be prepared to work an off-bearer into the ground. So cheap and easy, I don't even charge customer for stickers..
Offline Sixacresand
  • John and Nancy
« Reply #8 on: December 01, 2018, 09:31:53 AM »
If cutting acuminated 1 by's:  strap a bundle together at one end, measure and mark lengths, cut with chain saw starting at end opposite of strap.
Spend twice as much time picking them up, rehandling and stacking neatly.
Offline Cypress Man
« Reply #9 on: December 01, 2018, 10:28:40 AM »
Thanks for all the responses and advice.  My problem is that I only saw high cost cypress logs.  It would not be cost effective for me to saw the logs into stickers. On other hand, we create large piles of tailings from our edger that  makes perfect stickers but is very time consuming using the fence and eg 200 edger. Thinking of finding a 12in multi rip gang saw, that would be inexpensive to buy, that could have 4 or 5 blades to rip tailings into 1.25in wide stickers.  Anyone using this method? If so what gang saw would you recommend.
Offline barbender
« Reply #10 on: December 01, 2018, 03:17:32 PM »
Can't you get access to some lower cost wood, like pine, to saw stickers out of?
Online tawilson
« Reply #11 on: December 01, 2018, 03:56:44 PM »
Okay I am going to have to try this, tomorrow.
2017 LT40HDG35 WIDE
Offline DPatton
« Reply #12 on: December 01, 2018, 04:16:24 PM »
I too like the sacrificial log method when available. Stickers from edgings is slower and much more of a pain.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #13 on: December 01, 2018, 04:27:00 PM »
Since I edge on the sawmill, most of the time I can produce enough stickers by dropping down in one inch increments as I edge.
I do realize that I have not added anything that would be beneficial to Cypress Man.  :-\
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #14 on: December 01, 2018, 08:13:09 PM »
   I was about to suggest adding one step to the MM sacrificial log process of tying the boards together at one end so they will stay bundled when you cut them into stickers then to length then I realized what was going to happen the first time the blade passed through the first stack. ??? :D
   I guess it might help to stack them on upright on end in something like a 12" diameter piece of pipe or tall box as you take them off the mill, tie the ends above and below the cut and then cut them in pipe/box then go sticker them.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #15 on: December 01, 2018, 08:29:21 PM »
I just saws them and as you can see, the customer is in charge of stacking them.  ::)
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #16 on: December 01, 2018, 10:51:33 PM »
We used to cut our KD edging waste into stickers with a power feed and dado head to profile and cut them.
I learned the trick from a company who also makes H profile stickers out of waste by the thousand.  They have a top and bottom 20” molder setup with a special geometry cutting blade set, it looks like a bunch of half “H” profiles, that take a board of any width and the top cutter cuts the top half of the “H”and just a hair of an inch short of meeting midway on the outside of the legs of the “H”.  The bottom cutter profiles the bottom half of the “H” and the cutter just almost meets the cut along the outside leg of the “H”.  So any width board can be run and out comes a board with many “H” profiled cuts and each sticker either falls off or is snapped off by hand where the two cutters basically meet on the legs of the “H”.
Very effective and fast and doesn’t care how wide a board is, the molder profiles both faces, whatever the width and makes “snap off stickers”.
HobbyHardwoodAlabama.com
Offline Cypress Man
« Reply #17 on: December 02, 2018, 06:13:55 PM »
Thinking of trying a woodmaster gang saw but think the feed speed will be too slow. Anyone have know of a better saw?
Offline tule peak timber
  • roborob
    • tule peak timber
« Reply #18 on: December 02, 2018, 06:21:48 PM »
I used to pay a guy to stand and run endless pieces through my resaw. Then I started buying plaster lath strips from a big box store. I'm now at a point I recycle stickers and don't need anymore.
Offline carykong
« Reply #19 on: December 02, 2018, 07:07:10 PM »
Cypress Man,
Your wood is high dollar as you pointed out.   If you are considering a gang rip saw,you must have plenty of edging material over 3" in width? If that is the case, you are reducing a good cypress board to its lowest value by ripping it into sticks.
Do you have a market for narrow width cypress boards under 5"?
Stickers!!! How do you make them?
Started by DanMc on Sawmills and Milling
Last post October 31, 2016, 12:04:45 AM
by Rougespear
What's your favorite way to make Stickers?
Started by jpgreen on Sawmills and Milling
Last post October 31, 2007, 09:27:52 PM
by cantcutter
How do you make stickers and Edge on the mill?
Started by DR_Buck on Sawmills and Milling
Last post January 30, 2004, 06:20:26 PM
by Oregon_Sawyer
Most efficient way to heat????
Started by York0044 on Firewood and Wood Heating
Last post January 10, 2017, 06:56:33 AM
by woodshax
