Author Topic: LT30 belt guard  (Read 414 times)
Offline jb616
  • Hobby Sawyer
LT30 belt guard
« on: December 01, 2018, 09:02:39 PM »
Well, the original belt guard won't fit with the Onan on it now. What i need is advice to help the belt slip when there isn't any tension on it between cuts. The belt wants to grab a bit on the engine pulley and you can smell it burn slightly. I was wondering if I could put longer bolts in the bearing flange of the motor with lock nuts holding the bearing flange and then the bolts extending out past the belt. This might help the belt to stay up and off the pulley when there isn't any tension on it. Any other ideas out there?
Offline Southside logger
Re: LT30 belt guard
« Reply #1 on: December 01, 2018, 10:28:09 PM »
My 70 has two belt guides that are at about the 2:00 and 7:00 position, they are smooth and are adjusted to be 1/4" off the belt, they extend the full width of the belt best I can figure they force the belt to remain lower to the pulley which keeps it from dragging back down into the pulley and pulling like you are describing.  I will get a picture of them in my manual to better explain it, they are under the guard so a photo of the real thing is all but impossible.
Offline Chuck White
  • Sawing Mobile since 2005
Re: LT30 belt guard
« Reply #2 on: December 02, 2018, 06:57:00 AM »
Don't remember what it's called, but there should be a pin positioned about an eighth [1/8"] from the belt (when tensioned), just after the belt comes around the pulley!  The belt will touch this pin when the blade is disengaged!
~Chuck~
I LOVE MY SAWMILL
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
Re: LT30 belt guard
« Reply #3 on: December 02, 2018, 08:17:48 AM »
I think the pin or pins keep the belt radius smaller so that is doesnt engage with the engine pulley
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
Re: LT30 belt guard
« Reply #4 on: December 02, 2018, 09:46:55 AM »
Hello,
 The lower cover also helps hold the belt up off the engine pulley.
This picture is from a diesel but it serves the same purpose.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline 47sawdust
Re: LT30 belt guard
« Reply #5 on: December 02, 2018, 04:10:33 PM »
The part you are referring is available from WM.I don't have my parts book in front me or I would give it to you.You would simply remove the top flange bolt and install the part,adjust the gap to specs and your good to go.It's basically a piece of flat stock with a hole on one end and piece of 3/8'' rod welded on the other end at a right angle.
Mick
Offline jb616
  • Hobby Sawyer
Re: LT30 belt guard
« Reply #6 on: December 03, 2018, 11:47:56 AM »
just called them up and ordered it. No sense in trying to reinvent it for $15. Thanks!
Offline sparks
  • Sponsor
  • Woodmizer Electrical Tech
Re: LT30 belt guard
« Reply #7 on: December 04, 2018, 02:20:42 PM »
Part number is A12243
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
question
Homemade belt guard question
Started by kip on Sawmills and Milling
Last post March 25, 2003, 06:40:51 PM
by kip
LT40 drive belt jumped over, only half of belt on pulley.
Started by Delawhere Jack on Sawmills and Milling
Last post June 10, 2014, 08:20:25 PM
by woodmills1
never let your guard down
Started by timbuck2 on Forestry and Logging
Last post December 05, 2011, 06:00:45 PM
by customsawyer
Bandwheel Drive Belt One belt or Two.
Started by William1961 on Sawmills and Milling
Last post May 03, 2018, 08:29:46 AM
by mike_belben
