Baltic Abrasives Technologies
Author Topic: Venting a WM bms250  (Read 1463 times)
Offline PAmizerman
  • Just Another Day In Paradise!!
Venting a WM bms250
« on: December 02, 2018, 10:33:22 PM »
I am in the process of getting my sharpening equipment set up and was wondering about venting the sharpener.
Can I just run a flex hose out the wall or do I need to incorporate a fan into the exhaust line?
What have others used?
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline Southside logger
Re: Venting a WM bms250
« Reply #1 on: December 02, 2018, 11:36:03 PM »
So I had come up with an idea using a foolish number of PVC elbows, a fan vent, a catch, drain, etc then I came across the video below and decided to copy his set up and give it a try.  I did add on a brush to the band inlet and outlet as well.  Before this at night with a back light you could see oil mist coming from all around the machine with the chimney taped over, now there is nothing.  Simple and works very well.  Also - don't try to use your 120V setter on a GFCI protected outlet - you will pull out your hair trying to figure out why it won't work, but the two are not compatible as the setter has a built  in variable frequency drive.
Offline Percy
  • Resident trouble maker
« Reply #2 on: December 03, 2018, 12:07:30 AM »
If that Fan/filter combo works, let us know as I quit with that poisonous oil and switched to hydraulic oil. No mist to speak of with it. Just takes forever to start pumping when its cold.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #3 on: December 03, 2018, 04:37:04 AM »
Please post the Amazon links to that fan and filter if anyone finds them.  That looks like a good setup.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline tawilson
« Reply #4 on: December 03, 2018, 04:46:26 AM »
The links are on his comments below the video. Got them in my cart already.
2017 LT40HDG35 WIDE
Offline PAmizerman
« Reply #5 on: December 03, 2018, 07:44:39 PM »
Thanks Southside. And thanks for the tip on the GFCI. I would have been going crazy here in a couple days cause I have all the power to my shed on a GFCI
WM bms250 sharpener
WM bmt250 setter
« Reply #6 on: December 03, 2018, 08:47:47 PM »
Yup - I had the same set up, now I have one non- GFCI outlet that is dedicated to the setter and is on its own breaker.  On a good note if you ever need to know anything about the wiring or other internal operation of this machine I am a simple phone call away....
« Reply #7 on: December 04, 2018, 04:03:56 PM »
I just ordered the vent stuff too.  Sort of wondering how it will hold up or whether it will be saturated quickly with oil. Will find out.  Any improvement is good.
Offline highleadtimber16
  • Learning Everyday
« Reply #8 on: December 04, 2018, 06:59:10 PM »
Percy, how long have you been running hydraulic oil? I considered switching to it after paying for 3 pails of WM oil.
2011 Wood-Mizer LT 40 hyd w/ 12' Extension, Patrick Model A Loader, 75 Hitachi, Stihl 461, 2X066, & ms 192
Cutting Old Growth Cedar from Queen Charlotte Islands.
Offline PAmizerman
« Reply #9 on: December 04, 2018, 08:11:29 PM »
I just ordered the fan. I'm not going into a filter though. I'm just gonna vent out the wall and see how it works. I got mineral oil from cuttingedge. And a cbn wheel.
I'm getting closer to being up and running. Getting excited!!
WM bms250 sharpener
WM bmt250 setter
Offline tawilson
« Reply #10 on: December 04, 2018, 08:38:10 PM »
I'd put a little pitch in the vent pipe back to the sharpener. Might as well recover as much oil as possible.
You will like it. I just sawed some maple beams with a blade I've run through the sharpener/setter a couple times. I was ready to switch to a factory blade for a smoother cut and didn't need to. It couldn't have been any better.
2017 LT40HDG35 WIDE
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #11 on: December 04, 2018, 11:03:08 PM »
I'm interested also...
So mineral oil or hydraulic fluid works?  How do they affect wheel life?  I much dislike the WM fluid.
HobbyHardwoodAlabama.com
Offline JamieK
« Reply #12 on: December 05, 2018, 02:30:29 PM »
I currently use the WM fluid and would love to switch to something less smelly
Wood-Mizer LT28, BMS250, BMT100
Offline PAmizerman
« Reply #13 on: December 05, 2018, 06:04:45 PM »
Richard told me that he uses mineral oil and many others. I'll give it a try and see how it works.
I plan to run the vent hose high on the wall and down on an angle back to the sharpener to hopefully recapture any oil that makes it out.
WM bms250 sharpener
WM bmt250 setter
Offline Percy
« Reply #14 on: December 06, 2018, 12:51:35 AM »
I been using hydraulic oil for a long time. The mill shack is clean and has no smell. I havenít noticed any problem with the cbn wheels. The problem with it is if you are in a colder climate, it takes a while to start pumping and if you donít  keep at it all day, the oil will thicken and the process starts again. Iíve since installed a wood stove in my mill shack so that alleviates the condition. Iím interested in how well this filter works
Offline gmmills
« Reply #15 on: December 09, 2018, 02:04:16 AM »
  Those of you that are looking for an alternative to the smelly WM oil, convert to mineral oil. The WM oil is nothing more than a industrial base light cutting oil. I have been using mineral oil for over 3 years now. Prior to changing to mineral oil I used the WM oil for many years. Will not even consider going back to the WM oil.  Do not be concerned with overall wheel life using mineral oil. Not a factor when using a quality CBN wheel. There are no strong noxious fumes directly related to the oil. After all, mineral oil basically equates to using a large  amount of baby oil in your grinder lube tray.
  PAmizerman, I also purchase my mineral oil and CBN wheels from Cutting Edge. You will be happy with the performance of both these Kasco branded products.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Offline PA_Walnut
« Reply #16 on: December 09, 2018, 05:11:29 AM »
Great thread!! I am wandering through the weeds with my WM sharpener and setter.
That vent/filter thing is a nice idea. Check out his other videos on YouTube...dude is a mad scientist and had more toys than Santa's workshop! Anyone know if he's a member here?
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline tawilson
« Reply #17 on: December 09, 2018, 06:25:30 AM »
Just a fyi, my clamp came adjusted too tight from the factory. It caused the roll pin on the motor that advances the blade to work its way out after a couple blades. I backed it off to what seemed reasonable and has been fine.
2017 LT40HDG35 WIDE
Offline jimbarry
    • WoodchuckCanuck
Jim
2017 Nyle L200
8ft x 10 ft x 20ft bldg
3.5-4" 2lb closed cell spray foam, Demilec brand HeatLok Soya Spray Polyurethane Foam Insulation
« Reply #19 on: January 02, 2019, 04:26:15 PM »
I set up the fan/filter setup as mentioned in the above posts.   After using it for a half dozen hours of sharpening I am not sure whether it works or not.
Two conflicting observations.
With the filter off, I held a white piece of printer paper over the fan output opening while the sharpener was running for a minute or two.  I could not detect any discoloration of the paper which would indicate that oil is escaping in the fan exhaust.   This seemed to be a very positive test.
However, in the dark, with the sharpener running and the filter in place,  when I held a flashlight at the right angle on the outside of the filter, I could easily see a cloud of what looked like escaping oil mist leaving the filter.
So I am not sure that this really works as opposed to looking like it does.  It is hard to understand how effective this fan is at extracting oil mist.   I think it would be better to duct it to the outside or use the sharpener in a breezy open area.
BMS250 Sharpener 220 to 110?
Started by 123maxbars on Sawmills and Milling
Last post June 25, 2018, 04:17:49 PM
by Crusarius
Just venting......
Started by Just Me on General Board
Last post January 21, 2011, 01:43:13 AM
by ErikC
Gas tank not venting?
Started by Mikeinkaty on Chainsaws
Last post August 01, 2016, 09:12:07 AM
by Ox
Venting on a Logger
Started by just_sawing on Sawmills and Milling
Last post July 08, 2012, 03:01:03 PM
by beenthere
