Author Topic: Enjoying my New Wood-Mizer  (Read 994 times)
Offline richhiway
  • Rich
« on: December 03, 2018, 05:18:56 PM »
Enjoying the new Woodmizer. Great piece of equipment.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Offline richhiway
  • Rich
Re: Enjoying my New Wood-Mizer
« Reply #1 on: December 03, 2018, 05:19:21 PM »
Woodmizer LT 40
Stihl Chainsaws
Offline richhiway
  • Rich
« Reply #2 on: December 03, 2018, 05:21:17 PM »
The simple set is amazing. A time saver!
Woodmizer LT 40
Stihl Chainsaws
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: December 03, 2018, 05:48:01 PM »
   Yep, I love my SS too. I'm attaching a copy of my cheat sheet I use so I land on my mark every time.
 I open the first face, flip 180 and saw to the final width of the boards I will produce, flip 90 degrees, saw all the round off till I have completely square corners on the cant and flip 180 to the final face and start on whichever mark on my cheat sheet will give the boards I want. Save me an extra cut on almost every cant without leaving a thick or thin dog board too. Enjoy.
BTW - the cheat sheet allows/assumes 1/8" kerf so my SS setting for 1" boards is 1-1/8", 2" boards is 2-1/8", etc.
Offline richhiway
  • Rich
« Reply #4 on: December 03, 2018, 06:26:27 PM »
Thanks!
Woodmizer LT 40
Stihl Chainsaws
Offline Brad_bb
    • My timberframe blog
« Reply #5 on: December 03, 2018, 09:00:56 PM »
Is this your first experience milling?
Offline Crossroads
  • lets make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #6 on: December 03, 2018, 11:17:23 PM »
Enjoy, its the most work youll ever enjoy
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins
Offline richhiway
  • Rich
« Reply #7 on: December 04, 2018, 06:03:33 AM »
I had a Logosol csm for a number of years. This is my first bandsaw. Sort of like a model T racing a top fuel dragster!
Woodmizer LT 40
Stihl Chainsaws
Offline YellowHammer
  • Aerospace Engineer Owner Full Time Lumber Business
    • Hobby Hardwood Alabama
« Reply #8 on: December 04, 2018, 11:13:26 AM »
Nice job and mill.  I cant see the gauge too clearly on the video but it looks like your blade tension is quite low, with the point of the needle at the 12 oclock position?  Maybe not, I cant see it well.
The blade tension is akin to the blood pressure of the mill, too low or too high, bad things happen, just right and its magic.
Have fun!
HobbyHardwoodAlabama.com
Offline richhiway
  • Rich
« Reply #9 on: December 04, 2018, 05:05:08 PM »
I noticed you have to keep an eye on the tension. Thanks!
Woodmizer LT 40
Stihl Chainsaws
Offline JamieK
« Reply #10 on: December 05, 2018, 02:44:26 PM »
I'm experiencing sawmill envy
Wood-Mizer LT28, BMS250, BMT100
