Author Topic: Using grand fir for beams and joists  (Read 280 times)
Offline IanPNW276
  • Member*
« on: December 18, 2018, 02:00:32 PM »
New member here based out of the Pacific Northwest. I'm working on milling up some timbers for a small cabin, and wondering what folks think about the utility of Grand fir. We've got lots of it, which is the main reason I'd like to use it if it's good enough. Specifically, I'm thinking about making some 5x8 floor beams out of it, as well as potentially some joists. The floor won't be bearing a lot of weight, but obviously want it to be solid and long-lasting.
Thanks in advance, cheers
Offline Don P
    • Calculator Index
Re: Using grand fir for beams and joists
« Reply #1 on: December 18, 2018, 05:04:37 PM »
Welcome Ian,
Toolbox calcs to the lower left of the page, scroll to the bottom of that page, hit the beam and column link, second calc down is heavy timber.
Grand fir is under the Hem-Fir design values on the drop down when you're figgering. Most floor loads for residential are 40psf live + 10 psf dead  for a total of 50 psf design load.
I'm east coast, some of the western sawyers will need to chime in about what it is like to work with.
grand fir post and beams
Started by snowman on Timber Framing/Log construction
Last post December 31, 2006, 12:22:14 PM
by kderby
Rough sawn green doug fir for exposed ceiling joists and floor joists
Started by Sedgehammer on Timber Framing/Log construction
Last post February 14, 2019, 12:14:18 AM
by Sedgehammer
I-joists
Started by fiddle1 on General Woodworking
Last post June 13, 2011, 04:32:30 PM
by ljmathias
joists log sizes??
Started by shad on Timber Framing/Log construction
Last post March 09, 2010, 06:38:22 AM
by ljmathias
