Tally-I/O
Author Topic: Toolkit and jigs required for the chainsaw hobby/bug?  (Read 675 times)
Offline Phil_Oz
  • G'Day from Oz
« on: December 23, 2018, 03:16:48 AM »
Firstly, I would like to thank the senior statesmen here who share their knowledge both here and on YouTube (and sometimes they are the same people).
A question.
I have the basics re tools, but there are some extras required for this hobby.
What are your suggestions?
To try and narrow the scope;
.My first project will be to do a top end rebuild on my old Husky 50 rancher (parts on order).
.I plan to concentrate on Huskys and Stihls. I hope a 372 clone will be my next purchase/project.
.(after that, it may be whatever turns up at garage sales and the like).
I suspect the list will include; A case splitter, Torx set for Stihls. a new impact wrench, maybe a bearing press, dremel?
Stihl MS291, Stihl MS170, Husqvarna Rancher 50 (~86 model).
Offline PA_Walnut
Re: Toolkit and jigs required for the chainsaw hobby/bug?
« Reply #1 on: December 23, 2018, 03:38:42 AM »
You will want a 2-cycle tachometer. A must have for correct tuning!
Have fun.
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Peterson Dedicated Wide Slabber
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
Offline Phil_Oz
  • G'Day from Oz
« Reply #2 on: December 23, 2018, 04:21:05 AM »
Have fun.
Thanks - ordered one off ebay.
Offline weimedog
  • Better to be a "Has Been" than a "Never Been"!
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
Offline Phil_Oz
  • G'Day from Oz
« Reply #4 on: December 23, 2018, 07:55:18 AM »
Thanks M.
Offline weimedog
« Reply #5 on: December 23, 2018, 08:06:43 AM »
AND since you said Husqvarna 372's, the X-torqs have this nasty habit of eating pto bearings...and when you pull them apart,  they leave the outer race stuck in the case....I use heat and the following to get them out:
5pcs Inner Blind Bearing Puller Set Internal Slide Hammer Tool Remover US Stock 681385610130 | eBay
Also saws like the 562 and 576 with stuffers, sometimes the bearing stays on the crank shaft..I use these to pull them off:
14pcs Bearing Separator Puller Set 2" and 3" Splitters Remover and Bearing Kit 614019645673 | eBay
I have an ancient 2 jaw puller that works on flywheels, but could grind one of these to work I guess.
8 Inch 2 Jaw Bearing Puller Car Auto Motorcycle Bushing Remover Extractor Tool | eBay
Offline weimedog
« Reply #6 on: December 23, 2018, 08:14:53 AM »
I modified one of these to do the chain brake springs for both Stihl & Husqvarna
OTC Tools 4592 Truck Brake Spring Pliers | eBay
Offline weimedog
« Reply #7 on: December 23, 2018, 08:16:11 AM »
Seal drivers, I have the OEM Husqvarna and Stihl drivers, but also have the following as a base line:
HFS(R) Bearing Race And Seal Driver Set - 10 Piece And Case | eBay
Stihl Chainsaw OEM Specialty tool MS660 seal installer 066 064 1108 893 2405 | eBay
VERY Usefull!
Husqvarna crankcase seal removal tool flywheel side 362 365 371 372 61 268 | eBay
But that is an over view....and for each saw you can look either to a dealer or on eBay for the seal drivers and things if you get that far into them. Sockets do work, and a cheap harbor freight press also can work, just the chances of putting bearings and cases together without issue is better with the right shop tools....it DOES add up! But you posted this as if you plan to do a few over time....get the right stuff and save a ton of aggravation!
That's my ten cents.
Offline Phil_Oz
  • G'Day from Oz
« Reply #8 on: December 23, 2018, 09:17:03 PM »
M. Thank you so much for unselfishly sharing your knowledge and experience.
I'll work up from the basics. I'm considering another bench for the garage optimised for chainsaw work - maybe a mini something similar to an engine stand that bolts where the bar would go and turns and swivels.
Re the 372, I will take on board the advice not to consider the out of the box clone 'ready to roll' and assess it first.
[Edit to add]
I've put your very useful lists into a word file.
We have different stores here - I checked out what SuperCheap Auto (auto parts and tools store) have and will have a look at Bunnings and Repco after Christmas - and see what I can get at walk in stores vs online. (And the local Saw dealers too).
(I forgot to add - many of those e-bay stores don't ship to Aus/NZ, and sometimes the shipping on those that do is more than the cost of the item - c'est la vie ).
question
Precision Chainsaw plunge cutting - jigs, guides, etc... for mortise and tenons
Started by sleddin on Timber Framing/Log construction
Last post March 04, 2014, 01:33:32 PM
by MattJ
Toolkit for a Woodmizer?
Started by stavebuyer on Sawmills and Milling
Last post May 05, 2011, 07:23:30 PM
by stavebuyer
Dovetail jigs
Started by flip on General Woodworking
Last post January 10, 2008, 07:11:48 AM
by flip
question
Firewood jigs
Started by Paul_H on Sawmills and Milling
Last post February 21, 2006, 09:00:41 AM
by Frank_Pender
