Author Topic: Buying used saw - checking crank  (Read 324 times)
Offline MNBobcat
« on: December 23, 2018, 07:11:42 PM »
I'm going to buy a used saw and put a big bore kit on it.  I know how to check bearings on each side of the crank for play.  Is there any way to determine if a saw is likely to end up with a spun crank?  Just wondering what I should  check on the crank before buying.
Offline hamish
Re: Buying used saw - checking crank
« Reply #1 on: December 23, 2018, 07:49:15 PM »
Crank failure is nearly non existent on saws that have a big bore kit available to them.
Crankbearing failure yes, but a spun crank I have never seen in a chainsaw in over 25 years of servicing them.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Offline MNBobcat
« Reply #2 on: December 23, 2018, 09:17:40 PM »
Hamish,
Thank you!  That's good to know.  I appreciate the info!
Crank On A 395 XP
Started by Autocar on Chainsaws
Last post November 16, 2010, 02:56:45 PM
by Autocar
046 won't crank
Started by moodnacreek on Chainsaws
Last post March 12, 2018, 03:45:30 PM
by Al_Smith
Hand Crank
Started by Upper on Sawmills and Milling
Last post October 16, 2015, 12:23:29 PM
by Skip
Crank seals
Started by Robert Lehman on Chainsaws
Last post January 17, 2014, 05:20:54 PM
by Robert Lehman
