Author Topic: Building log cabin with green logs  (Read 1623 times)
Offline barbender
Re: Building log cabin with green logs
« Reply #20 on: December 27, 2018, 03:17:27 PM »
I don't like the idea of screws as they can cause settling problems. If you provide relief for them, unless you have springs under them they're not providing any "hold down". On hand scribed log homes, wooden dowels provide the lateral resistance. So will the window and door backs you install. If you want something that will resist uplift, threaded rod that goes all the way from the top plate to the bottom plate is the way to go.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #21 on: December 27, 2018, 03:31:36 PM »
And if you are like me and too cheap to spring for the whole threaded rod, you could do this...top and bottom.
bottom is hilted in with epoxy.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline Don P
    • Calculator Index
« Reply #22 on: December 27, 2018, 05:10:35 PM »
Thanks everyone! Would anyone know about the shrinkage in that? Like would my logs individually separate some or would the entire wall just shrink together? I really appreciate all the positive feedback! How would I go about putting my roof on if the walls shrink and windows etc.? Again thank you all!
Some things to think about. It's going to sound like I'm being fussy but bear with me for a minute and think about what is going on. Shrinkage and settlement are not the same thing. Shrinkage is the wood shrinking as it loses moisture. Settlement is the logs moving downward, in response to shrinkage. But settlement can be caused by more things going on. In a scribe fitted home like firefighter's there are a few more things causing settlement, compression of the thin edges of the scribed lateral joints. Those edges are bearing on tangential grain which has about twice the shrinkage of radial. The coped laterals spreading as the check forms in them, also called slumping. For anyone interested you can find all of this described in more detail in the log home standard.
The 1/4" per foot I mentioned is from the prescriptive radial settlement table in that standard, for a milled white wood log in a warm humid climate drying from fiber saturation point, green to dry.  Can you go more, in most cases it doesn't hurt anything. During the development of that code a number of us wrote in to disagree with the logic behind that table, in the real world the settlement is actually less. Why. First, the settlement allowance is based on shrinkage data from the USFPL. Those shrinkage numbers were based on very thin radial and tangential samples, free to move in response to moisture changes. A full sized timber doesn't shrink as much as a piece of veneer because it is somewhat bound internally by differing stresses and rays. Second, when a check forms the wood has indeed shrunk but the dimension of the timber has not changed as much as the amount of shrinkage. Part of the shrinkage is in that check.
Will your wall shrink uniformly, all together and remain perfectly tight or will there be some separation. There will probably be some separation. For one the shrinkage numbers are averages, each log is an individual and will shrink somewhat differently. Not all will be straight grained, some will twist to a greater or lesser degree. Some will have knots, ever notice in a dried board that the knots are proud, longitudinal grain perp to the axis of the board.
To settle around a fastener, any fastener, the rows of fasteners need to be plumb. If they wander around at divergent angles nothing is settling. If a log twists as it dries it is certainly going to put friction on the fasteners before allowing any settlement. Can a 2500 lb spring overcome the twist and bow of a large drying timber? Can you stack an entire wall of such timber and then successfully tighten it all? Will all members be in plane? One group of chink builders intentionally builds log homes that do not settle. They drive rebar at opposing angles from row to row to lock the height. The logs shrink individually but are hung in place on the opposing pieces of rebar.
The roof springs from the top course of the log walls, assuming it is only bearing on the logs, as they settle the roof is simply along for the ride. As long as the logs settle somewhat uniformly and that it isn't tied to something that doesn't settle, like a chimney, the roof remains in plane.
Offline Nsp0005
« Reply #23 on: December 27, 2018, 07:19:07 PM »
Yeah thatís why Iím doing butt and pass method to avoid that.
Offline pappy19
« Reply #24 on: January 02, 2019, 07:34:58 PM »
Why not just use standing dead? I used standing dead Idaho white pine and have lived in our log home for 18 years. Swedish cope round logs, 3 stories and no movement whatsoever.
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
Offline arky217
  • Member*
« Reply #25 on: April 21, 2019, 07:23:21 PM »
Some of my logs are over 40 feet long and maybe 20Ē diameter at the big end.  There is almost no visible checking anywhere in the house.  That is because of the saw kerf that is run down the middle of the joint.  I would look for a foam gasket that has adhesive on one side.  Place that close to the inner edge and close to the outer edge.  When the house is done, use a caulk like Big Stretch and run a bead along the outer seams and you should not need it inside.
I'm building a small (12'x12') log cabin out of green southern pine using sort of the same strategy.
Using approx. 10" logs, I'll be milling 3/4" off the tops and bottoms.
This leaves the log 8.5" thick with a 5.5" wide flat on top and bottom.
Then I'll cut a kerf 3.5" deep on the bottom to help prevent checking. I'll use a modified butt & pass
method in that I'll drill a 1/2" hole thru the top log and 5" into the bottom log. Then I'll enlarge the
hole in the top log to 5/8".
Then I'll drive a 13" length of 1/2" rebar so that's it's recessed 1/2" into
the top log. This way the rebar will be tight in the bottom log and will allow the top log to settle and
stay snug to the bottom log.
But I have a question about using a 1/8" thick x 5.5" wide strip of sill foam between the logs.
I plan to lay down the strips as I assemble the logs since the logs should stay snug to each other
which would make it hard to wedge in the foam strip after assembly.
But the question is, will the foam strip hinder the purpose of the kerf cut by sealing it off.
Perhaps I should forget about the foam strip and just caulk the outside joints after assembly.
I would like to use the foam strip but not at the cost of checking.
What do you think?
Offline Don P
    • Calculator Index
« Reply #26 on: April 21, 2019, 08:12:39 PM »
Foam really needs somewhere to live to be able to recover. It doesn't recover if smashed flat. You also don't really want it creating dimension.
Centered on the bottom flat, straddling your kerf, run a power planer a couple of passes up the length of the underside of the log, creating a plowed out wide, shallow groove. Stick the foam in that, then it doesn't interfere with log height and the foam is not crushed. Flat faces  become convex as the timbers dry, this will keep the logs bearing on the outer edges of the plowed groove. Fastening the logs down with screws in counterbored pilot holes lets you get them tighter to begin with, something I've never been able to do with any dowel type connector, pins, spikes, rebar. At least take that out of the gapping equation. Allthread drilled in as you go can allow you to keep tightening the stack later.The foam will not prevent the drying stress from concentrating on that weakest radial part of the log, it is a stress concentration point rather than a drying point.
Building a cabin with green lumber?
Started by GDinMaine on Sawmills and Milling
Last post July 10, 2013, 07:55:00 PM
by drobertson
Got a question on building with green logs
Started by Treeclimber on Timber Framing/Log construction
Last post June 06, 2016, 10:08:48 AM
by Treeclimber
building logs for house or cabin
Started by arojay on Forestry and Logging
Last post March 20, 2008, 04:25:48 PM
by arojay
Using green live edge beams in a lake cabin
Started by duaneb on Drying and Processing
Last post March 31, 2012, 04:14:01 PM
by D L Bahler
