Author Topic: Help me with a Kiln  (Read 625 times)
Offline GC88
Help me with a Kiln
« on: December 25, 2018, 03:04:28 PM »
I live in North Florida and have cut a bit of Pecan in to 8/4 slabs that are about 13 feet long and now I need to dry them.
I have been looking to build a solar kiln. My father in law said he has a 2000 gallon steel tank that maybe we could cut the top off and make it work a solar kiln. Itís 8 feet wide by 20 ft.
I basically need help with the process of making one. For my understanding I would need to cut a hole in the top and replace it with transparent plastic and paint the inside black. Stack the wood inside and seal to the top with a barrier with fans that runs during the day to push the hot air through the stack. If thatís correct it seems kinda simple in theory.
Where would I get a timer that turned the fans on when the suns up? Or what do yíall use?
Iím basically looking for advice of what would be the most simple and achievable way to dry my wood in the Florida climate, we have plenty of sun.
Offline Escavader
  • Sawmill/Planermill operator since1984
Re: Help me with a Kiln
« Reply #1 on: December 25, 2018, 06:12:13 PM »
Could you use a thermostat to a furnace to tell your fans when to work?
I like the tank idea
Alan Bickford
Hammond lumber company/Yates American A20 planer with dbl profilers Newman feed table multiple saw trimmer destacker automatic stacking machine Baker resaw MS log corner machine  4 large capacity Nyles dehumidification kilns JCB 8000 lb forklifts
Offline GC88
« Reply #2 on: December 25, 2018, 10:01:07 PM »
I just donít get what people use to turn the fan on, are people using the thermostats or light percentage like automated car lights sensors. What turns the fans on day in and day out?
Offline scsmith42
    • Whispering Pines Farm
« Reply #3 on: December 25, 2018, 10:25:45 PM »
My 4 solar kilns all use a standard water heater type of timer.  Three of them run off of one unit; the fourth has it's own.  However, for what you're trying to do a simple timer for Christmas tree lights should work fine.
Virginia Tech has a lot of great info on building a solar kiln, and on kiln drying in general.
If your pecan is freshly milled,  you might want to consider air drying it for a few months before putting it into a solar kiln.
Tom's 3638D Baker band mill
Offline GC88
« Reply #4 on: December 26, 2018, 01:09:47 PM »
I just got a WM meter and it says the pecan is at 20%.
I have looked at the Virginia Tech info and it does have some good info.
Offline scsmith42
« Reply #5 on: December 28, 2018, 04:34:35 PM »
8/4 pecan will usually take at least 9 - 12 months to fully air dry.  How long ago were your slabs milled?
Pre-build solar kiln questions(Photos of kiln building progress)
Started by caveman on Drying and Processing
Last post April 17, 2016, 06:35:35 PM
by caveman
All the experienced kiln driers. Solar kiln or power?
Started by woodjunky on Drying and Processing
Last post December 13, 2014, 09:52:31 PM
by GeneWengert-WoodDoc
converting a bulk tobacco kiln into a lumber kiln
Started by Bryce on Drying and Processing
Last post February 18, 2010, 11:09:27 PM
by scsmith42
Kiln cart and shipping container kiln.
Started by Mike_M on Drying and Processing
Last post June 26, 2007, 08:57:21 PM
by Furby
