Baltic Abrasives Technologies
Author Topic: CNC  (Read 496 times)
Offline DDW_OR
CNC
« on: December 26, 2018, 01:33:44 PM »
have been thinking of getting a CNC or 3D printer or laser engraver.
did some searches and discovered that there are all-in-one machines
has anyone ever used one?
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline ronwood
  • Enjoy Making Sawdust !!
Re: CNC
« Reply #1 on: December 27, 2018, 10:13:40 AM »
I have a cnc from Digital WoodCarver for 5 years. The CNC was designed and built by an engineer that use to work for Woodmizer. Good machine for the money. Not as heavy built has a shop bot or some of the other cnc routers. Just have to run a bit slower. Busybeaver also has the same unit.  If you decide to buy a cnc  I feel that the software used to design and generate the gcode is important. I use VCarve Pro for designing projects and producing gcode.  If you like to discuss via phone I will be happy to send my contact info via pm
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Offline low_48
Re: CNC
« Reply #2 on: December 27, 2018, 05:18:15 PM »
If you want to use the laser for cutting, should be okay. If you want to use the laser for engraving, it will be incredibly slow. Traditional laser engravers almost have a flying head. A CNC can not duplicate those speeds because the Z axis is usually too heavy. 3D printers need to be more than just an extruding head to be successful. You need a heated bed to get the first layers to stick. Just like I think a Shopsmith is a horrible table saw, but with a fairly nice horizontal drill, an all in one CNC will definitely have compromises.
