Author Topic: Cold weather stop you sawyers?  (Read 3450 times)
Offline welderskelter
« on: December 28, 2018, 11:43:17 AM »
Its 5 degrees here right now. Dont want to go out in the cold. Things dont seem to work right when it is too cold. What is your temp at which you go back inside. Just curious. Harold
Offline SawyerTed
  • Summey Lumber Services, LLC
Re: Cold weather stop you sawyers?
« Reply #1 on: December 28, 2018, 11:54:29 AM »
We don't get frigid temperatures here often or for long. If it's going to be below 30-35 for a high temperature I doubt I run the sawmill but I will cut firewood. Five degrees is time to stay in beside the fire!
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline woodworker9
    • Elite Concrete Raising Co.
« Reply #2 on: December 28, 2018, 11:56:34 AM »
I'm good down to about 20, give or take a few degrees, as long as it's not windy.  Problem is, in Northern Illinois, it's almost always windy......like today. 30 to 35 mph gusts all day.
03' LT40HD25 Kohler hydraulic w/ accuset
MS 441, MS 290, New Holland L185
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #3 on: December 28, 2018, 12:14:38 PM »
YES   :D
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #4 on: December 28, 2018, 12:41:55 PM »
When I ran the big circle head saw our rule of thumb was -5 if we knew the temp was going to climb.  Anything colder than that and stuff started breaking. At about ten below you can usually break the cast iron housing off a failed pillow bock bearing with one good blow of an 8lb hammer. The failed bearing was probably from trying to run at ten below.  You can get your body used to working in 0 to 20 degrees, but its really hard on equipment. There were times when we had orders that gave us no choice but to work in sub-zero, and most always we would pay a price.
Offline ladylake
« Reply #5 on: December 28, 2018, 12:50:07 PM »
  5 above f here with climbing temps and not a lot of wind.  I have sawed at -5  but that was nasty.  Steve
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #6 on: December 28, 2018, 12:51:03 PM »
It is a judgement call for each individual sawyer when it's too cold to work. Especially when you work for yourself, and you decide if it is worth the aggravation. If it is too cold, I try to find inside projects too work on. As I mentioned in another thread, sometimes you have too work outside to pay the bills, whether it is cold or not. Minimizing exposure, working shorter hours (noon till 4 pm), and stopping to warm up frequently also help (and is safer). Where I live having temps below freezing may be bad for sawyers, but is actually beneficial for loggers. As otherwise too wet areas freeze solid, and they can get wood out.
« Reply #7 on: December 28, 2018, 01:20:14 PM »
Shows 2 degrees and falling. Supposed to be 19 below tonight. My mill will be lonely. Ha
Offline Kwill
  • Cedar cutter
« Reply #8 on: December 28, 2018, 02:40:10 PM »
I only cut in colder weather. Don't like dealing with the ticks and snakes.
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
Offline longtime lurker
« Reply #9 on: December 28, 2018, 03:10:25 PM »
Gets around about 45 and I start to shiver and shake. Everything is relative.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #10 on: December 28, 2018, 03:35:46 PM »
Customers usually draw the line at 25F or lower.  If they're up for it at these colder temps it is the more enthusiastic ones, I can accommodate.
If it is Peterson work I draw the line at has to be mid 30's in the morning with at least in the 40s during the day. I'm not crawling around on the ground when its freezing or chain slabbing frozen logs.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline goose63
« Reply #11 on: December 28, 2018, 03:42:54 PM »
My mill will be lonely for a long time
And the wild turkeys are hungry
goose
thank you to all the vets
« Reply #12 on: December 28, 2018, 03:46:52 PM »
If you saw really cold you will find out the things that need fixing on your mill.  And how good your battery is.
Also if it rains and then freezes, and  you go out sawing, you will be reminded of how the cat track is put together.
Offline jimbarry
    • WoodchuckCanuck
« Reply #13 on: December 28, 2018, 03:58:11 PM »
Nope. Rain, sleet or snow doesn't bother me much. The wife, who likes to come along and work along, tends to stay indoor once it drops below 0C, or if its windy or raining or snowing... she' missus out on a lot. :)
It was -11C (12F) today, spent the better part of the day out in the yard, and waiting for this to show up.
Jim
2017 Nyle L200
8ft x 10 ft x 20ft bldg
3.5-4" 2lb closed cell spray foam, Demilec brand HeatLok Soya Spray Polyurethane Foam Insulation
Online Bruno of NH
« Reply #14 on: December 28, 2018, 04:07:44 PM »
I'm good to 20f if there is no wind chill.
In the winter if it's a sunny day it's much better.
When you spend half the day getting things up and running I would rather do shop work or firewood.
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #15 on: December 28, 2018, 06:46:30 PM »
If it's cold (40 or colder) I'm not sawing!
I usually put the mill away for the Winter around the end of October (it's Hunting Season), then it comes out of hibernation around the end of March!
~Chuck~
I LOVE MY SAWMILL
Online Ron Wenrich
« Reply #16 on: December 28, 2018, 06:58:12 PM »
I was always good for 10.  Anything less was time for things to break.  I had heaters for the hydraulics, so that helped.  I always told the help that I would be the second guy to leave.  Wind was always a deal breaker.  The first cold spell is usually the worst, as logs have frozen and unfrozen areas.  You'll be cutting two types of wood.  After the logs freeze solid, its not as much of a big deal.
The loggers would love the cold.  No need to worry about mud or wet areas.  Logging with cold weather and little snow and those guys would fill the yard up.
We had a debarker which makes things easier if the debarker man took off the bark.  Frozen logs won't dull the saw so much as what's frozen onto the bark.
Online Jeff
  • Fearless Leader
« Reply #17 on: December 28, 2018, 07:58:14 PM »
Ha! Aint that the truth!
Offline bandmiller2
« Reply #18 on: December 28, 2018, 08:04:31 PM »
The worst thing about the cold is thinking about it, once your working your OK. What Jeff says low temps are hard on diesels and cast iron. Twenty and below you work if you have to if not do something in the shop. Frank C.
Offline btulloh
« Reply #19 on: December 28, 2018, 08:05:28 PM »
Yes.
But this the year the rain is stopping me often than the cold.
HM126
Head cold. Make it stop...make it go away!! Man, I turn into a baby...
Started by maestro on Health and Safety
Last post September 16, 2008, 03:56:29 PM
by Riles
Need some cold weather!
Started by reswire on General Board
Last post August 26, 2014, 10:00:36 AM
by red oaks lumber
Cold Weather Starts
Started by Greenedive on Forestry and Logging
Last post February 09, 2007, 03:33:07 AM
by arojay
Very Cold Weather and Accuset
Started by Percy on Sawmills and Milling
Last post January 07, 2004, 06:24:31 PM
by Wes
