Baltic Abrasives Technologies
Author Topic: Cold weather stop you sawyers?  (Read 3358 times)
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
Re: Cold weather stop you sawyers?
« Reply #20 on: December 28, 2018, 08:38:29 PM »
After 31 years of having to work outside, no matter how cold or hot it got (law enforcement), I retired and bought my bandsaw mill.  Rain, snow, wind chills below freezing or heat indices above 100ー, you'll likely find me in a heated or air-conditioned environment.  Doesn't always work out but that is the plan.  ;D
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Offline ladylake
« Reply #21 on: December 29, 2018, 05:44:20 AM »
 I don't even have to think about going out today,,   It's -19 f right now with a high of around + 5 .  Steve
Offline moodnacreek
  • Sawin by the notches
« Reply #22 on: December 29, 2018, 08:11:49 AM »
I would like it to be above 10 degrees but the wind and sun play a part. Sawing below 10 things start to happen like the teeth coming out of the saw. Half frozen logs can cause a lot of mis sawn lumber. If your in a long cold spell you have to deal with it but if it's going to warm up, wait.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #23 on: December 29, 2018, 08:19:11 AM »
I have sawn in the mid teens a few times but generally my customers will put a stop to sawing long before I will.  Sawing when  it is below 40ー is iffy and below 30ー is almost certain to be a no.  Yes, wind is killer.   :-\
Offline pineywoods
« Reply #24 on: December 29, 2018, 08:26:01 AM »
Yep..My mill is cold natured. Won't run if the temp is below 45ー. The operator freezes up and becomes erratic. ;D
Offline Ed_K
« Reply #25 on: December 29, 2018, 08:30:38 AM »
 Below 25ー and the mill won't start manual pull cord at 22ー the skidder won't start without lots of extra work, find generator to use block heater, jumper cables to juice up cold batt. After 10ー I'm next the the furnace adding wood ;D
Offline Jwswan
  • Forward!
    • boatshoptricks.com
« Reply #26 on: December 29, 2018, 12:12:35 PM »
agreed on all the above.  Also, depending on how much finger dexterity I need vs. working in heavy chopper mitts, I can reliably add on 15-50% when there is decent snow on the ground and the temps are teens and less. I'd like to work out some clever ratio.  And at 38, I'm already pretty soft and prefer to head into a very cozy shop.  I love winter for the cross country skiing, no so much for outside work.  I've decided there's no need to be a hero when it gets cold.
Keep 'em guessin'.
Online thecfarm
« Reply #27 on: December 29, 2018, 01:30:04 PM »
I don't have to work outside. I just play around getting firewood. I wear certain clothes. If that don't keep me warm I head for the house. I think I can tell when it's 10ー and 16ー. 16ー I am fine,but that 10 is a, I am cold and heading for the house.
Years ago I worked for the state working on low income homes. Now that's a cold job. Blowing insulation and standing on a ladder. At least cutting wood I can keep warm.
Offline nybhh
« Reply #28 on: December 29, 2018, 07:19:01 PM »
 I値l take a sunny 20 over humid 90 all day long and be be thankful for it.  i saw for myself though so below 20ish with no sun or lots of snow or wind and I値l ussually find something else to do.
I like to fire up the incenerator/burn barrel below freezing and burn off some slab wood while working too.  Makes breaks, and the end of day beers a lot more enjoyable as well!  ;D
Woodmizer LT15, Kubota L3800, Stihl MS261
Offline Kwill
  • Cedar cutter
« Reply #29 on: December 29, 2018, 08:03:13 PM »
Mid 30s here today. I sawed all day in it not much wind so it was about right.
Built my own log arch
In the process of building my sawmill
Offline Kindlinmaker
« Reply #30 on: December 29, 2018, 08:57:47 PM »
Across the river in Dutchess with the same usage needs and same sawing guidelines.  Must be a Mid Hudson thing.  Enjoying this warm spell after falling behind with the hot, wet summer we had; woodshop needs boards and some nice figured logs going to firewood if we don稚 get to them soon.
Offline Old Greenhorn
« Reply #31 on: December 30, 2018, 12:44:42 PM »
Ditto what NYBHH and kindlinmaker said. The humidity here can be terrible in both winter and summer with fall not far behind that. If it is dry, sunny and 10ー I can still be good with a couple of breaks and a little slab fire to check in with every once in a while. It's all about my feet, If they are comfortable than I am good. There are a lot of benefits to working in the colder months, like no mosquito's, fewer ticks, easier skidding, no leaf cover on the trees, etc. We get very damp, overcast days here before mid-January and it can be hard to stay focused when that chill gets in your back.  It's 32 and damp out right now and it is killing me to be sick, and in the house for the last 3 days.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #32 on: December 31, 2018, 01:22:46 AM »
I don't saw when ....
A) It's -10 ーC (or colder) -- that's 14 ーF.
B) It's snowing heavily (snow packs between the bed and the cant).
C) Snow on the ground is more than a foot deep.
D) I've got nothing to saw.
Right now C & D apply :).
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #33 on: December 31, 2018, 08:54:15 AM »
This is the 1st year I have sawn past December 1st. The new mill caused this as I am getting the bugs out of the new mill by  sawing wood for my adition to my cottage.
I do not mind around the -5 or so and sunny. The snow on the ground is the biggest problem I find. I have a small yard and I have to stack all the unfinnished bundles of wood when I am finnished for the day. I then have room to plow snow in the morning, unpile my bundles and then saw wood. br>
LT40HD, 742b Bobcat, Sthil v170,038, 461. 1952 TEA Fergusan Tractor
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #34 on: December 31, 2018, 11:13:43 AM »
I could and did mark timber to well below zero, of course I havent done that since 2006, but saw?
Not under about 35.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline boonesyard
« Reply #35 on: December 31, 2018, 11:59:53 AM »
There's an orange mill under there somewhere ??? Right now we're in a blizzard warning, -40 windchill, supposed to get down to -21 temp tonight. Milling will have to wait.
LT50 wide
"I ain't here for a long time, I'm here for a good time"
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #36 on: December 31, 2018, 03:13:30 PM »
   I hope its a manual mill because I don't see the loading arms raised up so the feet don't freeze to the ground. That's a trick I learned here. If there is a remote possibility of freeze before I will saw again I make sure to lift my loading arms at the end of every sawing session. Has saved me from some headaches several times.
Offline moodnacreek
« Reply #37 on: December 31, 2018, 07:23:24 PM »
Way up north, circle mills that operate below 0 use solid tooth saws I am told.  These saws are thinner than insert tooth style and sometimes use more guides.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #38 on: December 31, 2018, 07:35:27 PM »
I'll bet it's that new LT50, I can make out the loading arms!
Too darn cold anyway!
~Chuck~
I LOVE MY SAWMILL
Offline Bandmill Bandit
« Reply #39 on: December 31, 2018, 07:52:29 PM »
I used to saw down to about minus 10C but now I like it above freezing a few notches.
The joints don't like the cold so much.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
Head cold. Make it stop...make it go away!! Man, I turn into a baby...
Started by maestro on Health and Safety
Last post September 16, 2008, 03:56:29 PM
by Riles
Need some cold weather!
Started by reswire on General Board
Last post August 26, 2014, 10:00:36 AM
by red oaks lumber
Cold Weather Starts
Started by Greenedive on Forestry and Logging
Last post February 09, 2007, 03:33:07 AM
by arojay
Cold weather tips
Started by anchorhd on Sawmills and Milling
Last post December 14, 2013, 12:47:33 AM
by Andries
