Author Topic: Tillitson Carb question....  (Read 599 times)
Offline mrcaptainbob
« on: December 28, 2018, 10:52:22 PM »
Doing a rebuild on a Tillitson carb #62. There's a gasket that fits over the diaphragm, but...not sure which side of diaphragm it goes on.
carb body/thick gasket/diaphragm/cover plate
                   or
carb body/diaphragm/thick gasket/cover plate
any ideas?
Offline dougand3
Re: Tillitson Carb question....
« Reply #1 on: December 28, 2018, 11:09:04 PM »
Depends on which diaphragm.
carb body/thick gasket/METERING diaphragm/cover plate
carb body/FUEL PUMP diaphragm/thick gasket/cover plate
Husky: 372xt, 272xp, 61, 55 (x3) Stihl: 026, 011AVT Poulan: 315, 4218 (x3), 2375, 2150, 2055, 2000 (x3) Homelite XL
Offline Al_Smith
« Reply #2 on: December 29, 2018, 08:56:41 AM »
carb---spacer gasket--diaphragm---cover .If you get them reversed it will flood .For future reference if you "google" Tillotson you can find the stack up on just about any carb they made ,trouble shooting etc .
Offline Mad Professor
« Reply #3 on: December 29, 2018, 05:11:23 PM »
These are for the 028 and HS series.
What is a #62 off of?
« Reply #4 on: December 29, 2018, 06:44:14 PM »
It's off of an older Poulan Pro ...um....062A I think. It's in the barn, I'm in the house.
The problem was no fuel. Cleaned things up. A lot! THought I'd check the fuel filter, but could not get it out of the tank. Saw body has a tank cap held in place by a single slotted screw. Hmmmm...there was fuel in the tank, but it was below the fuel filter. The fuel line was about as stiff as if it were made of steel and was holding the filter about mid-height in the tank. Put on a new, more flexible, fuel line. Will fire it up tomorrow to see if there's any success.
« Reply #5 on: December 30, 2018, 06:07:15 PM »
It's a 306A with an 18" bar. It works GREAT now! Well, sorta. Having  bit of a time with the idle. To keep it running it spins the chain. Slowing it down enough to keep the chain only slightly moving and the engine stalls. But it does start right up! Diced up some cherry with it. I'm pleased enough with it.
« Reply #6 on: December 30, 2018, 06:10:16 PM »
By the way.....thank you all for your help.
« Reply #7 on: December 30, 2018, 08:42:32 PM »
Readjust the L screw, then fix the idle.  L is probably rich, turn down idle until it's about to stall (CCW), then turn in/lean L (CW) until idle picks back up.  May have to go back and forth a few times.
When you get it running without the chain spinning, richen L (CCW) until it starts to die, note position, then back in L (CW) until it starts to race/chain spins, note position.  Halfway between the two settings is about right for L, fine tune idle.
If saw stumbles when you gas it, might be a little lean on L, richen L (CCW) at bit.
Carb question
Started by John Vander on Chainsaws
Last post August 04, 2014, 08:30:00 PM
by John Vander
Old Homelite carb question
Started by old2stroke on Chainsaws
Last post February 28, 2016, 05:09:04 PM
by sawguy21
zema carb question
Started by bandmiller2 on Chainsaws
Last post February 14, 2013, 09:30:58 PM
by Al_Smith
Stihl 460 carb question
Started by sweetjetskier on Chainsaws
Last post April 28, 2015, 09:26:14 PM
by sweetjetskier
