Author Topic: First load of osage logs to be milled  (Read 1513 times)
Offline osage outlaw
« on: December 30, 2018, 09:05:35 AM »
I recently took my first load of osage orange logs to a local mill operator to be cut into slabs.  I was very happy with the results and I can't wait to get started on some projects from this lumber.  I had it cut into 1.25" and 2.25" slabs.  I hope you guys don't mind a lot of pictures.
I don't have any logging equipment.  I get by with my old UTV and a barrel sled.
I added one more log after these pictures were taken.
My log arch trailer worked nicely.
Log arch trailer - YouTube
Osage orange has some beautiful colors.  It can be bright yellow to dark red.
This tree had interlocking grain.  I could see it in the bark before I cut it.  It made some cool ripple waves in the grain.
The black wind checks can make some awesome designs.  I want to make a table out of these two boards
I sealed the ends with several coats of glue before having them cut up.  I stickered and stacked them in my garage for now.  Should I do anything else to them?  I want to minimize any cracking or warping.
Offline sealark37
Re: First load of osage logs to be milled
« Reply #1 on: December 30, 2018, 09:28:24 AM »
A beautiful stack of material.  How much did the sawyer charge for his work?  I notice that you are one of those guys who sweeps his shop between jobs.  Compliments on a nice work area.     Regards, Clark
« Reply #2 on: December 30, 2018, 09:36:05 AM »
He charged $150 but I gave him a little extra.  I thought that was a reasonable price.  My garage is cluttered but I can't stand a messy floor.  I sweep it all the time.  When I'm debarking staves I sweep it twice for each stave.
Offline moodnacreek
  • Sawin by the notches
« Reply #3 on: December 30, 2018, 09:47:03 AM »
As I always say, sticker all the way out even if they don't align vertically. The piles should be high, narrow and very heavily weighted.  Those who do this don't have time to post photos and may not even use computers so it's not apparent. The wrong methods are being copied .
Offline Brad_bb
    • My timberframe blog
« Reply #4 on: December 30, 2018, 11:17:21 AM »
Osage will do what it wants to do, weight or not.  Even 4/4 it's difficult at best to keep it from doing what it wants to do.   Your stuff is thicker, and the thicker something is, the less it usually warps.
Not sure what you're going to do, but I can tell you that Osage can have changing grain direction which can cause tear out when you plane.  If the piece doesn't have changing grain direction, you might be ok.  I've had better luck with belt sanding.
That Osage will turn a rust brown color in time as it oxidizes.  kept inside it might hold more yellow longer.  I love Osage.
Offline lil171
« Reply #5 on: December 30, 2018, 12:44:36 PM »
That is a nice stack of wood. I have always been intrigued by the Osage Oranges. We do not have them up here, but whenever I visit the US, I but a few if in season and available. We were told that they help keep bugs at bay and I don't know if it is just me, but they do seem to work. If I could only get some seeds to try to grow a tree here.
« Reply #6 on: December 30, 2018, 01:17:51 PM »
I'm well aware of the characteristics of osage wood.  I've been making longbows from it for over 10 years.  I cut and hand split around 300 bow staves a year.  It's my favorite tree to work with.  I have osage limbs and leaves tattooed down my right arm.  It will fight you all the way but the end result is beautiful.
I am familiar with drying  osage staves without warping and cracking but these boards are new to me.  I feel like I should seal them with a coat of shellac to slow the drying process down.
« Reply #7 on: December 30, 2018, 01:19:36 PM »
Thank you for the advice.  When I move them to the other location I will cut more stickers and make sure the ends are supported.
Offline DPatton
    • D & S Sawmill Services
« Reply #8 on: December 30, 2018, 05:24:22 PM »
I like the barrel sled, what an inexpensive and great way to keep the logs clean when skidding.You got some beautiful slabs with a lot of color. I personally love the look of hedge when it has been aged and exposed to sunlight allowing it to oxidize, turning it a dark rich amber color.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #9 on: December 30, 2018, 07:05:56 PM »
I drool for logs like those :).  Keyboard is all wet.
Offline Southside logger
« Reply #10 on: December 30, 2018, 08:01:29 PM »
I wish we had hedge like that around here.  Want to trade it for some really nice gum logs?   ;D
Offline OffGrid973
  • Off Grid
« Reply #11 on: December 30, 2018, 09:35:00 PM »
How far south does one need to travel for those beauties?
I think someone drives the sawdust sleigh in the right direction in that shop.
Your Fellow Woodworker,
- Off Grid
Offline Brad_bb
« Reply #12 on: December 30, 2018, 11:28:07 PM »
I just seal the end grain like any other log.  It needs to dry out the sides/faces.
Offline 69bronco
« Reply #13 on: December 31, 2018, 07:33:58 AM »
Wish we had some here! How bout a few bow pics?
« Reply #14 on: December 31, 2018, 08:32:14 AM »
These were cut in Southern Indiana
« Reply #15 on: December 31, 2018, 08:36:01 AM »
I like to use natural flaws  in the wood when I can.
Offline DPatton
« Reply #16 on: December 31, 2018, 09:06:05 AM »
Your work is simply beautiful. It's a good thing its wintertime here cause that snake in the grass photo about gave me the willies.
Offline Carson-saws
« Reply #17 on: December 31, 2018, 09:27:16 AM »
Beautiful...very nice indeed....my favorite wood....
Let the Forest be salvation long before it needs to be
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #18 on: December 31, 2018, 10:09:44 AM »
Nice work! I was not familiar with that wood, had too look it up.
Osage Orange, (Maclura Pomifera), also known as Hedge Apple, Horse Apple, Bodark, or French "Bois D'ark" (bow - wood). Extremely durable and very decay resistant, used for wagon wheels, fence posts, bows, and musical instruments. Also shavings can be put into water to make yellow dye, and is said to produce more BTU's when burned than any other domestic hardwood.
« Reply #19 on: December 31, 2018, 10:46:06 AM »
It is some amazing wood.  A log can lay on the forest floor for decades and it will not rot.  I found a log that was cut and left in the woods for at least 20 years based on the history of the property.  It was black on the outside.  Just under that black surface was golden yellow.  I have made several bows from that log.
Osage is fantastic firewood.  It does put off a lot of heat and can spark like tiny fireworks.  It makes a great dye.  My hands were stained yellow from moving those slabs and I was wearing gloves.  It is also being researched for cancer treatment.  It has anti fungal and anti bacterial properties.
Question about drying those slabs:  How long should I air dry a 2.5" slab before making a table out of it?  They will be stored inside a building out of the rain and sunlight.
pics of milled osage orange
Started by music_boy on Sawmills and Milling
Last post July 09, 2004, 05:15:21 PM
by AtLast
Osage and sycamore logs.
Started by Kelvin on Wanted
Last post July 10, 2009, 10:55:34 AM
by tyb525
New guy with home made log sled and some osage logs
Started by osage outlaw on Forestry and Logging
Last post March 11, 2017, 06:03:19 PM
by osage outlaw
milled my first couple of logs!!!
Started by forgeblast on Sawmills and Milling
Last post April 11, 2018, 08:49:39 AM
by forgeblast
