Author Topic: Need a beam  (Read 946 times)
Offline moosehunter
  • Every once in a while
    • Saw it Coming
Need a beam
« on: January 01, 2019, 03:49:04 PM »
I need a 6"x10"x38' hemlock beam. I know it can be done on my WM but it is a LOT of work. I can source a log if I can find someone to cut it. I am also willing to just buy the beam. Anyone in southern central NY with that kind of length capacity?
mh
I will of course send the FF 5% of whatever fees/costs are associated with this project if a fellow member can help me out.
If it is true that we learn from our mistakes, I must be Brilliant!
Offline Brad_bb
Re: Need a beam
« Reply #1 on: March 12, 2019, 07:00:01 PM »
Do you really need a one piece 38 footer or can  you do a scarf joint to make a 38 from two shorter pieces?  You can be shown how to cut a scarf joint in the timberframe section.  Just an option.
Offline AZ_builder
Re: Need a beam
« Reply #2 on: March 12, 2019, 07:12:48 PM »
Would a glue lam be stronger at that length?
Offline GAB
Re: Need a beam
« Reply #3 on: March 12, 2019, 07:28:41 PM »
I believe there is an outfit in or near the Danville, VT area that can saw 50 footers.
If it is of interest to you I'll try and find them.
Gerald
Offline Don P
    • Calculator Index
Re: Need a beam
« Reply #4 on: March 12, 2019, 08:55:17 PM »
To answer that one,
Bending strength of Hemlock beam and stringer stock in #2 is 750 psi
Glulam Fb runs around 2800 psi, so, oh yeah.
Offline AZ_builder
Re: Need a beam
« Reply #5 on: March 12, 2019, 09:04:25 PM »
To answer that one,
I thought so, just not smart enough to have the numbers lol if 38 is needed for looks alone Id think a facade could be used on a glue lam or steel beam, unless its some sort of traditional building code area.
Offline moosehunter
    • Saw it Coming
Re: Need a beam
« Reply #6 on: March 12, 2019, 09:07:15 PM »
Both builders I am getting quotes from say that they can scarf a joint over a portion of the rafter system that will support the joint. I am relying on their expertise which will allow me to cut two twenty one footers that they can use.
 Glue lam is my last choice. It just wouldn't look right. To me anyway.
Thanks for your input.
mh
Offline scsmith42
    • Whispering Pines Farm
Re: Need a beam
« Reply #7 on: March 13, 2019, 06:57:01 AM »
Know any flat bed truckers that run between you and Raleigh, NC?  I could cut you some 38 SYP boards that you could apply over the glue lam beam.  Youd have your strength, as well as the look.
Tom's 3638D Baker band mill
Timber Frame / Post and Beam supports for ridge beam and loft
Started by clayhillsfarm on Timber Framing/Log construction
Last post May 27, 2014, 10:51:05 PM
by clayhillsfarm
Tie Beam to summer beam connection/ problem /questions
Started by windfall on Timber Framing/Log construction
Last post July 15, 2016, 03:06:05 PM
by windfall
Beam questions for Post and Beam Structure
Started by rodney757 on Timber Framing/Log construction
Last post September 06, 2016, 10:45:39 AM
by rodney757
Beam value
Started by ts64511 on Forestry and Logging
Last post January 07, 2016, 03:05:23 PM
by beenthere
