Tally-I/O
Author Topic: Need a beam  (Read 1089 times)
Offline moosehunter
  • Every once in a while
    • Saw it Coming
Need a beam
« on: January 01, 2019, 03:49:04 PM »
I need a 6"x10"x38' hemlock beam. I know it can be done on my WM but it is a LOT of work. I can source a log if I can find someone to cut it. I am also willing to just buy the beam. Anyone in southern central NY with that kind of length capacity?
mh
I will of course send the FF 5% of whatever fees/costs are associated with this project if a fellow member can help me out.
If it is true that we learn from our mistakes, I must be Brilliant!
Offline Brad_bb
Re: Need a beam
« Reply #1 on: March 12, 2019, 07:00:01 PM »
Do you really need a one piece 38 footer or can  you do a scarf joint to make a 38 from two shorter pieces?  You can be shown how to cut a scarf joint in the timberframe section.  Just an option.
Offline AZ_builder
Re: Need a beam
« Reply #2 on: March 12, 2019, 07:12:48 PM »
Would a glue lam be stronger at that length?
Online GAB
Re: Need a beam
« Reply #3 on: March 12, 2019, 07:28:41 PM »
I believe there is an outfit in or near the Danville, VT area that can saw 50 footers.
If it is of interest to you I'll try and find them.
Gerald
W-M LT40HDD34 w/6' ext & SLR, JD 420, JD 950w/loader and Woods backhoe, V3507 Fransguard winch, Cordwood Saw, 18' flat bed trailer, and other toys.
Offline Don P
    • Calculator Index
Re: Need a beam
« Reply #4 on: March 12, 2019, 08:55:17 PM »
To answer that one,
Bending strength of Hemlock beam and stringer stock in #2 is 750 psi
Glulam Fb runs around 2800 psi, so, oh yeah.
Offline AZ_builder
Re: Need a beam
« Reply #5 on: March 12, 2019, 09:04:25 PM »
To answer that one,
I thought so, just not smart enough to have the numbers lol if 38’ is needed for looks alone I’d think a facade could be used on a glue lam or steel beam, unless it’s some sort of traditional building code area.
Offline moosehunter
    • Saw it Coming
Re: Need a beam
« Reply #6 on: March 12, 2019, 09:07:15 PM »
Both builders I am getting quotes from say that they can scarf a joint over a portion of the rafter system that will support the joint. I am relying on their expertise which will allow me to cut two twenty one footers that they can use.
 Glue lam is my last choice. It just wouldn't look right. To me anyway.
Thanks for your input.
mh
Offline scsmith42
    • Whispering Pines Farm
Re: Need a beam
« Reply #7 on: March 13, 2019, 06:57:01 AM »
Know any flat bed truckers that run between you and Raleigh, NC?  I could cut you some 38’ SYP boards that you could apply over the glue lam beam.  You’d have your strength, as well as the look.
Tom's 3638D Baker band mill
