Author Topic: Jack Sorbon Timber Frame Project (Modification)  (Read 1019 times)
Offline CJ
  • I'm new and green!
Re: Jack Sorbon Timber Frame Project (Modification)
« Reply #20 on: January 07, 2019, 07:36:10 AM »
 Dually noted. I have those set pins for my framing square, but have never used them. I could also just buy a Construction Pro calculator that has all the functions on it to do the calculations, but these calculators are a bit pricey.
Those of you who say you use Sketchup, do you have the free version of it or did you actually pay for the software. I watched how it works on line yesterday and thought that I would try the free version of it. However, the free version seems a bit difficult to use, as it only has a few of the available functions available to allow you to do certain tasks. I am pretty tech savvy, but trying this free software application was a bit tedious. I was very impressed with the product overall after having watched the tutorials.
Offline flyingparks
  • If my dog doesn't like you, I don't like you.
« Reply #21 on: January 07, 2019, 09:09:58 AM »
Free version of sketcup is great. Watch the official sketchup tutorials...in order. It does not work like other drafting software. It can get really frustrating if you try to teach yourself...but it is a wonderful program.
Offline Don P
    • Calculator Index
« Reply #22 on: January 07, 2019, 07:31:24 PM »
I use the free version too, I'm stuck at the 2016 version, that's as modern as my graphics card can handle. It does everything I need. I got Sketchup for dummies and it helped me get going.
One trick with square nuts, set the square with the marks you want in line with the edge of the board where you want them to be. Then while holding the square there, slide the nuts on till they hit the board and are bedded on the square and tighten. They may not be quite on the marks depending on the angles you are setting up but they are holding the square on the marks. To avoid pencil thickness accumulated error when stepping off I use a knife to scribe my marks on the wood. Be careful, a knife can hop up on the square and take the side of your thumb off in a heartbeat.
Offline curved-wood
« Reply #23 on: January 07, 2019, 08:30:51 PM »
Well,  if you have a lot of fun to play around with software there is quite a few out there and the number are growing : revit, auto cad, solidworks, etc . I like to built in curve  ( see some of my constructions  at : claudedrolet.com ) so Sketchup is a bit limited for my use. But I know quite a few people that are well satisfied with it.  I use more complex software and the learning curve goes with it. So for a square building, straight line that is, I am much faster to use a scale drawing on the standard 1/4 '' graph paper than trying to learn the steps of a new software. I will get all the info I want,  providing you have a little bit of math knowledge. But when I am dealing with curved roof or even just a curved door, the software will give me a precision that will take me hours to calculate. My point is that if you are a tech passionate go for it,  but just don't forget that a simple graph paper with a scale drawing could do a very good job specially with a structure like yours. Choose your way and have fun
Offline Brad_bb
    • My timberframe blog
« Reply #24 on: January 14, 2019, 11:34:42 PM »
FYI it's "Sobon", pronounced So-bun.  Not Sorbon.
