Author Topic: Lt28 wood mizer  (Read 670 times)
Offline George Decker
Lt28 wood mizer
« on: January 05, 2019, 08:37:42 PM »
Trouble with my lt28 wood mizer losing its prime over night any thoughts to why
Online Southside logger
Re: Lt28 wood mizer
« Reply #1 on: January 05, 2019, 09:14:06 PM »
My guess would be an air leak in the fuel line.  Check the connections at the carb, filter (connections and housing itself), and tank.  Also check for a crack in the line.  Welcome to the Forum.
Online doc henderson
Re: Lt28 wood mizer
« Reply #2 on: January 05, 2019, 09:18:13 PM »
I have a diff. brand.  Welcome .  if your tank is lower than your engine, might have an air leak.  I assume you are talking about fuel.  There will be some with your brand that can prob. be more specific.  check for cracks or loose clamps.
Offline WLC
Re: Lt28 wood mizer
« Reply #3 on: January 05, 2019, 09:20:25 PM »
I also have an LT28 but haven't had that problem yet.  I will second what Southside said though.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Re: Lt28 wood mizer
« Reply #4 on: January 05, 2019, 10:22:27 PM »
Thanks to you all for replies I will check all lines and I am thinking about changing the fuel filter . Also thanks for the welcoming hope to learn some tips from some pros here since I have only had my mill for a few months
Offline Chuck White
  • Sawing Mobile since 2005
Re: Lt28 wood mizer
« Reply #5 on: January 06, 2019, 07:45:15 AM »
Welcome to the Forestry Forum, George!
If your mill has a removable fuel tank, check the O-ring inside of the quick-disconnect on the tank!
If it is left connected for long periods of time, the O-ring can develop flat spots around it where it contacts the removable part, and will develop an air leak!
When I'm done sawing for the day, even if I'm going to leave the fuel tank on the mill, I always disconnect the tank!
~Chuck~
I LOVE MY SAWMILL
Offline thecfarm
Re: Lt28 wood mizer
« Reply #6 on: January 06, 2019, 11:18:44 AM »
George,welcome to the forum.
Been sawing long? :D
Saw for others?
Re: Lt28 wood mizer
« Reply #7 on: January 06, 2019, 01:37:19 PM »
Just to clarify, and I had to read it several times.  And correct me if I am wrong and missing the joke.  I think the c farm meant to have an a in the word swing, poss. sawing.  LOL.  I know that NC and Maine are a distance away, but we mostly the same on this forum.  Might at least stimulate a little more conversation. lol
Re: Lt28 wood mizer
« Reply #8 on: January 06, 2019, 03:36:53 PM »
Doc - got stories from your youth about going to the dollar store and picking up a fishbowl??   :D
Offline 47sawdust
Re: Lt28 wood mizer
« Reply #9 on: January 06, 2019, 04:05:16 PM »
Dollar store?,fishbowl?Swinging?....I'm confused
Mick
Re: Lt28 wood mizer
« Reply #10 on: January 06, 2019, 04:09:04 PM »
I thought I had a dry sense of humor.  come on guys, help us out. say_what
Online terrifictimbersllc
    • Terrific Timbers LLC
Re: Lt28 wood mizer
« Reply #11 on: January 06, 2019, 07:34:34 PM »
Give @thecfarm a break, he has nightmares about grits. 🙀
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline thecfarm
Re: Lt28 wood mizer
« Reply #12 on: January 06, 2019, 07:36:12 PM »
Been swing long? :D
Saw for others?
There I quoted myself so others would understand.
Thanks doc and terrifictimbersllc,all fixed. :-[
Last time I had nightmares about grits someone from VT came to see me.   ::)
Online GAB
Re: Lt28 wood mizer
« Reply #13 on: January 06, 2019, 08:25:43 PM »
Hi Ray:
If you're a needing more of that southern hospitality staple just let me know.
There are some mighty fine Southern Gentlemen that just might rise to the opportunity to get you another autographed box to go with the last one.
Gerald
Newbie having issues with wood, and his Wood Mizer LT28
Started by Kyblacksmith on Sawmills and Milling
Last post July 28, 2014, 06:07:35 AM
by ladylake
thumbup
Another new mill from Wood-Mizer - the LT28
Started by Bibbyman on Sawmills and Milling
Last post July 29, 2005, 06:20:50 PM
by Bibbyman
LT28 wood block broke
Started by Qweaver on Sawmills and Milling
Last post August 29, 2016, 06:50:33 PM
by drobertson
Lathe-Mizer - Writing article for The Wood-Mizer Way and need input
Started by bcornelius79 on Sawmills and Milling
Last post February 08, 2011, 02:59:24 PM
by bcornelius79
