Author Topic: Husq 353G rebuild, blown cylinder  (Read 288 times)
Offline jimbarry
    • WoodchuckCanuck
« on: January 06, 2019, 01:09:20 PM »
Could a fella who's new to repairing saws get some help on where to buy, what to replace and how to do a rebuild? I read a couple parts sources online, they all go by year. Does it say somewhere on the saw what year it was made?
Jim
2017 Nyle L200
8ft x 10 ft x 20ft bldg
3.5-4" 2lb closed cell spray foam, Demilec brand HeatLok Soya Spray Polyurethane Foam Insulation
Offline dougand3
Re: Husq 353G rebuild, blown cylinder
« Reply #1 on: January 06, 2019, 04:57:34 PM »
Whew, that's ugly. Was it on the bottom of a lake? You've got to disassemble and examine - remove jug first. Depends on what the inside of crankcase looks like but I wouldn't trust big rod bearing or crankcase bearings/seals. So, splitting case = big job.
ID sticker normally has year - top cover.
Husky: 372xt, 272xp, 61, 55 (x3) Stihl: 026, 011AVT Poulan: 315, 4218 (x3), 2375, 2150, 2055, 2000 (x3) Homelite XL
Offline jimbarry
    • WoodchuckCanuck
« Reply #2 on: January 06, 2019, 05:35:27 PM »
No lake. My father-in-law (may he RIP) had it for several years. I've used it for 3-4 since his passing. It was my go-to saw. It chug and stopped. This is the result. Gas/oil mix was good. Just had its time maybe, I dunno. This is the top cover.
Jim
2017 Nyle L200
Offline dougand3
« Reply #3 on: January 06, 2019, 06:37:18 PM »
Maybe you got some heavily water laden fuel. Pull the jug and look in the crankcase. A sticker should show serial # and year, if it hasn't come off. Although year shouldn't be too important for parts. Don't think they changed much from 2002-2011.
question
372 XP Husq. cracked cylinder head
Started by louiseM on Chainsaws
Last post February 23, 2019, 08:19:12 PM
by louiseM
moved
MOVED: 372 XP Husq. cracked cylinder head
Started by chet on Ask The Forester
Last post February 19, 2019, 12:07:10 PM
by chet
Ms o29 rebuild cylinder help
Started by basspapaw on Chainsaws
Last post October 21, 2014, 11:59:34 AM
by basspapaw
Prentice 210 C cylinder rebuild
Started by Banjo picker on Forestry and Logging
Last post July 09, 2011, 11:23:12 PM
by Banjo picker
