Author Topic: ERC, best use/way to cut these  (Read 1074 times)
Offline alanh
« on: January 07, 2019, 10:58:27 AM »
I went to check this pile this morning, the guy says he want 8x8`s, Im not seeing it, the small ends are 10-12", what would be a good suggestion for cutting them?
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: ERC, best use/way to cut these
« Reply #1 on: January 07, 2019, 11:33:06 AM »
When people ask me for a too big timber I say "let's try and see what it looks like".
Sometimes they like the result and sometimes not but most all get the idea pretty quick.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: January 07, 2019, 12:34:00 PM »
Seat of the pants way of estimating is half again bigger.  Another words it takes a good straight 12 top end log to make a clean 8X8.
Offline alanh
« Reply #3 on: January 07, 2019, 03:57:20 PM »
I use that but was uncertain with the inclusions in the cedar, I came up with a surefire way to make sure he gets the most for his money, I referred  him to Dennis...
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #4 on: January 07, 2019, 04:23:25 PM »
When cutting fence posts, I measure to the outside the heart wood to estimate for post size because the sapwood is not rot resistant.
1992 LT40HD
Offline Haleiwa
  • Clinton county, New York
« Reply #5 on: January 07, 2019, 04:43:12 PM »
There are some jobs you're better off not taking.
Socialism is people pretending to work while the government pretends to pay them.  Mike Huckabee
« Reply #6 on: January 07, 2019, 05:27:57 PM »
I can't explain it but even nasty looking ERC logs often give surprising nice lumber.   The "inclusions" turn out to be sapwood streaks often.  Anyway he called and I booked him for next week, will let you know how it turns out.
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #7 on: January 07, 2019, 06:48:50 PM »
Quote
I would not use that one for 8x8's, I would cut that into cookies. ($$)
Offline alanh
« Reply #8 on: January 07, 2019, 07:57:04 PM »
Thats great Dennis, I feel much better handing this off to a more experienced guy. Im just going to stick with my stationary mill concept for now
« Reply #9 on: January 07, 2019, 08:00:06 PM »
In "situations" I offer the customer....pick one, magic or miracle, but not both.  :D :D :D
Offline alanh
« Reply #10 on: January 07, 2019, 08:18:11 PM »
Thats a good one, give me a heads up when youre there, Id like to come by to say Hi, ( and watch you mill again,)
Offline Cedarman
    • Cedarusa
« Reply #11 on: January 08, 2019, 07:49:28 AM »
Very seldom do I saw without knowing what the customer is going to do with the wood.
An 8x8 for a porch post may need to be rather free of defects or the customer may want a rustic looking post.  You must have a meeting of the minds to determine what will make the customer happy.  If the post is for an outbuilding, then some wane on the corners, some ingrown ( which will be very present in the log in the picture) isn't a problem.
Customers let me know their wish list, then I let them know what the can do list is.
When you try to make a log into something impossible, then you will be very frustrated and sawing is no fun.
« Reply #12 on: January 17, 2019, 06:00:33 PM »
Sawed some of those cedars today.  Most of the logs we sawed gave 6x6's, here's one below on the mill.  Some gave 8x8s and others 5x5s or 4x4s.  Initially there were a few with waney edges but when we considered that sapwood didn't have rot resistance I opted to cut deeper and make most of them mostly red.
49 logs were sawn.  Good help, good setup and it was a good day except for being cold (under freezing).  Glad to be sitting by the fire now.
b
This pic was at lunchtime.
Offline alanh
« Reply #13 on: January 17, 2019, 06:11:16 PM »
Looks good Dennis, you all done there?
« Reply #14 on: January 17, 2019, 06:23:21 PM »
No, going back next week after it warms up again.   :snowman:
We started to set up where most of the logs were but I suggested we go below where it was flat and level, which worked out better.  So didn't see what was left. One of the guys said there's a lot of logs still up there.
Offline alanh
« Reply #15 on: January 18, 2019, 08:33:01 AM »
There are a LOT of logs up there, nice guy, pretty nice set up he has going there, wouldn`t mind having that "garage"
« Reply #16 on: February 03, 2019, 01:29:59 PM »
Last week put in a second day 7 hr, was cold but upped the pace got 60 more logs sawn into beams from 3.5x3.5 to 8x8, plus side1x.  All but one cedar. Got another dozen or so oak,birch maples to go, only wants largest beams possible from them.
