Baltic Abrasives Technologies
Author Topic: Cut one 6X6 on a LT 40 with a Manual log deck Video  (Read 265 times)
Offline richhiway
  • Rich
« on: January 07, 2019, 07:00:53 PM »
you get your exercise with a manual log deck.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Cut one 6X6 on a LT 40 with a Manual log deck Video
« Reply #1 on: January 07, 2019, 07:53:24 PM »
   Thanks for making me love my hydraulics that much more. I cut 2- 6' 6X6's out of 9" ash logs this afternoon and while I did rotate them by hand I never had to leave the rail side and it took only minutes to do them. I assume you were putting the slabs on the forks of your tractor. I threw mine further back on the rail side and will pick them up when the stack gets so big it gets in my way. Once cut I slid the 6X6's down the mill then on to the forks where my tractor was staged at the rear of the mill on the rail side. The biggest time and work saver I saw was in my side supports and the movable clamp.
   I am sure that cut my steps in half from what you have to do with your manual version. Thanks for sharing.
Offline Southside logger
« Reply #2 on: January 07, 2019, 09:37:52 PM »
Great job there.  Like WV said, you learn to appreciate the features the different mills have, this would actually be a great video for the folks who are looking at manual mills and don't have the opportunity to see one in person.
Offline Sixacresand
  • John and Nancy
« Reply #3 on: January 07, 2019, 10:07:39 PM »
I enjoyed the video.  I milled dozens of 6x6's with a WM LT10.  I know the manual mill pain. I have a hydraulic LT40 now, but if you working alone, it's just about as much back and forth as a you in the video.
Video of WM manual toe board and turner??
Started by Brad_bb on Sawmills and Milling
Last post February 12, 2017, 08:05:14 PM
by Darrel
John Deere shop manual, operators manual, and brochure.
Started by Piston on For Sale
Last post March 09, 2014, 10:59:32 AM
by Piston
Time to re deck the deck
Started by rimshot on Sawmills and Milling
Last post October 01, 2013, 06:43:41 PM
by rimshot
Logs too big for my sawmill (video) UPDATED VIDEO OF SAWING
Started by 123maxbars on Sawmills and Milling
Last post June 28, 2017, 10:39:58 PM
by YellowHammer
