Author Topic: EWP Logs  (Read 1162 times)
Offline Rhodemont
  • Logging and milling just a hobby
EWP Logs
« on: January 08, 2019, 08:30:22 AM »
Anybody near Carver, MA looking for some pine logs.  Have a guy who has some at his mom,s place in Carver, MA.  They are uprooted blow downs from last spring.  Have been fully limbed.  He reports 4 full length (40Ft?) 20"+ diameter that can be cut to any length and 2 larger diameter 10 ft lengths.  Just wants to get rid of them, you would have to be able to load and haul out.  I am considering but 1.5 hour from my place and may not get to it.
Woodmizer LT35HD    JD4720 with Norse350 winch
Stihl 362, 039, and now an Echo CS-2511T
Offline alanh
Re: EWP Logs
« Reply #1 on: January 08, 2019, 08:48:26 AM »
It`s a shame but I can`t begin to tell you how many thousands of bdft of the nicest blowover pines went into the tub grinders from this summers storm, I`ve got a good 8 thousand ft before I realized some will rot before I get to it. This was just from one college campus, there were two adjoining state parks that had equal damage, everything went to the grinders
Online Southside logger
Re: EWP Logs
« Reply #2 on: January 08, 2019, 09:52:00 AM »
Same thing happened in southern Maine back in '98 after the ice storm.
Offline nybhh
Re: EWP Logs
« Reply #3 on: January 08, 2019, 10:32:19 AM »
There are still thousands of these trees on public and private property all over the place around me from 2011 & 2012 hurricanes Irene and Sandy.  Pine degrades beyond milling pretty quick but will lay around as en eye sore looking depressing for decades.  :( People around here won't touch it for firewood either, even for outdoor wood boilers so cleanup ends up being too expensive for landowners without heavy equipment and space to dump it.
Woodmizer LT15 Start, Kubota L3800, Stihl MS261
Offline Gagnon Mountain
Re: EWP Logs
« Reply #4 on: January 08, 2019, 10:55:03 AM »
I don't understand people that won't burn pine.  I have a wood fired boiler in the basement, and I burn quite a bit of pine in it.  As long as it's dry, it's not a problem.
Offline nybhh
Re: EWP Logs
« Reply #5 on: January 08, 2019, 11:34:17 AM »
You hear "creosote" as the excuse but I think it is really just laziness.  Too many trips up and down the stairs or whatever.
Offline alan gage
Re: EWP Logs
« Reply #6 on: January 08, 2019, 12:05:16 PM »
I suppose it depends on what's available. Here oak and ash are readily available for firewood. Seems silly to use anything else. It would just be more work for the same amount of heat.
Alan
Timberking B-16
Re: EWP Logs
« Reply #7 on: January 08, 2019, 12:14:06 PM »
I grew up knowing you could not burn pine without a guaranteed chimney fire followed by the collapse of your house and barn. Now I burn pine . ::)
Offline rjwoelk
    • countrysidefirewood
Re: EWP Logs
« Reply #8 on: January 08, 2019, 12:30:17 PM »
In our province we burn jack pine. We have dropped it from our firewood list as it was getting hard to find someone to bring the logs and we could get birch for nearly the same price. But as fall and spring firewood it was hot enough to work.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: EWP Logs
« Reply #9 on: January 08, 2019, 12:43:59 PM »
Are they free? They need to be free for this topic to be legit here.
Online doc henderson
Re: EWP Logs
« Reply #10 on: January 08, 2019, 01:18:52 PM »
  • I guess we could ask Stan from Yukon Men, but I think the only thing they burn in Alaska, is primarily soft woods, cause that is what grows there.  The nice thing with denser wood, is it tends to retain a good coal bed longer.  We burn cottonwood in a fireplace, but not in a stove.  The first is ornamental, the latter is to heat your home all night and start up easy in the am.  People have ruined stoves burning Hedge since it is dense and burns long and hot.  Catalpa is light a smells good, but tends to pop, so can be a problem in an open fireplace.  So It is regional and over the years people migrate to the best option available.  I have removed 9 cottonwood trees from my property..I split it for my Dad who used to love to sit and watch TV, with a fire going in the fireplace.  He could get up every 20 minutes or so and put a couple more logs on the fire.  When they went to bed, the fire was essentially out in 2 hours.  Dry wood has a universal BTU per unit weight.  So less dense wood by definition take up more space per unit weight.  If all you have is pine, it sure beats freezing to death. cut_tree
Online WV Sawmiller
    • Green's Sawmill Services
Re: EWP Logs
« Reply #11 on: January 08, 2019, 01:56:16 PM »
   I did a project in the Gobi desert in Mongolia and my wife and took a vacation up through central and northern Mongolia up to the Russian border. All I saw anybody burn over there was pine. The only hardwood I ever much of there was some small birch but I don't remember people cutting it. I guess historically the herders burned camel, horse and yak manure more than wood. The gers (Yurts) were heated with a small sheet metal stove in the middle of the tent. They could take the top insert out and put a big wok looking pan in there to cook with.
Offline Rhodemont
Re: EWP Logs
« Reply #12 on: January 08, 2019, 02:20:56 PM »
Free other than cost for yo to go get them.
Offline ktm250rider
Re: EWP Logs
« Reply #13 on: January 14, 2019, 09:56:21 AM »
hahaaa, my "4 free logs" turned out to be 6 truck loads of logs!
Offline moodnacreek
  • Sawin by the notches
Re: EWP Logs
« Reply #14 on: January 14, 2019, 12:59:30 PM »
When I visited Montana the best firewood they could get was d. fir.
Offline jwilly3879
Re: EWP Logs
« Reply #15 on: January 15, 2019, 05:07:56 PM »
I have seen some lumber that was accompanied by the certification form that was #2 or better that I would not have used for a woodshed. As the building inspector I told the owner/builder that it was not acceptable for use as rafters. As a logger the logs he had sawn would have been pulpwood, not saw logs, there were 6" knots in a 2x8. He insisted he could use the lumber because he had the certificate. I went to visit the sawyer and found he had never given the person the certificate and insisted that when he sawed the lumber he told the person it should only be used for siding. Turns out the certificate was forged by the owner/builder.
Offline firefighter ontheside
  • I like trees.
Re: EWP Logs
« Reply #16 on: January 15, 2019, 09:55:20 PM »
Kinda far to go from Missouri, but Id love to mill some white pine.  Years ago before I had a mill we had a tornado take down a huge white pine.  Killed me to see it go to waste.
In Missouri people wouldnt dream of burning pine in a fireplace.  Creosote and all, but I walkways knew that people burned pine in the west where they had no Hardwoods.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Wanted - small diamater low grade walnut logs and pallet logs ...
Started by Wes Lyon on Wanted
Last post August 12, 2006, 10:31:53 PM
by Wes Lyon
blue stain pine logs,aspen logs, Colorado
Started by logloper on Wanted
Last post February 23, 2010, 09:52:24 PM
by logloper
8 ft logs vs vs split logs for seasoning firewood
Started by Christopher7789 on Drying and Processing
Last post March 30, 2017, 10:45:58 PM
by GeneWengert-WoodDoc
More Logs
Started by Kevin_H. on Forestry and Logging
Last post November 25, 2002, 11:17:12 AM
by Bibbyman
