Author Topic: Wood heat  (Read 551 times)
Offline goose63
Wood heat
« on: January 08, 2019, 04:16:58 PM »
Can I use wood to heat the kiln with.
The boss says the power bill to high the way it is  :o
goose
thank you to all the vets
Offline Southside logger
Re: Wood heat
« Reply #1 on: January 08, 2019, 04:36:05 PM »
How will you get the heat into the kiln chamber? Hot water? If so I would say you can make a safe and accurate system. Just blowing in hot air would not be as consistent or produce as good of a finished product.
Offline goose63
Re: Wood heat
« Reply #2 on: January 08, 2019, 04:49:18 PM »
Southside
I'm not sure I would get the heat in I'm hopeing some one has done it and can send me in the right direction
goose
Offline xlogger
Re: Wood heat
« Reply #3 on: January 09, 2019, 04:52:25 AM »
I build my kiln (Nyle) about 10 ft away from my Central Boiler OWB and heat it that way. It cost about $1000 extra on heat exchanger, insulated pipe, valves and extra pump but gets it up to 150 on a warm day pretty easy. Stan at Nyle walked me threw changing a couple wires on my unit. I try not to run threw the heat cycle to 150 on real cold days because I heat my house with it also and too lazy to go out early in the morning to add wood. I've not used the electric heat with it at all.
Offline K-Guy
    • http://www.nyle.com/
Re: Wood heat
« Reply #4 on: January 09, 2019, 08:06:46 AM »
Hi Goose
What have you got for a kiln?
Nyle Kiln Sales & Service
Offline goose63
Re: Wood heat
« Reply #5 on: January 09, 2019, 10:10:34 AM »
K-GUY I don't have one yet I would like to build one this spring
goose
Offline K-Guy
Re: Wood heat
« Reply #6 on: January 09, 2019, 11:21:20 AM »
Goose
If you go dehumidification for your kiln you can use a wood-fired hot water boiler for heat but not forced air.
Offline goose63
Re: Wood heat
« Reply #7 on: January 09, 2019, 12:09:10 PM »
K-Guy
Thats what I was thinking forcedair but now I know better
There was a old school tore down and I can get some of the old heating parts
I have a huge pile of slabs I can use to heat with now Ineed to find some plans to build with
goose
Anyone heat with wood pellets?
Started by Coon on Firewood and Wood Heating
Last post February 29, 2008, 12:52:37 AM
by Coon
Wood heat poem
Started by johncinquo on General Board
Last post November 01, 2007, 02:54:28 PM
by athelstan
Wood to heat your house???
Started by chazmonro on General Board
Last post October 09, 2005, 09:53:04 PM
by wiam
reforestation and wood heat...
Started by joespruce on Forestry and Logging
Last post March 06, 2008, 09:30:53 AM
by bull
